going to install stage 1, how dificult - Diesel Forum - TheDieselStop.com
Old 07-24-2009, 06:15 PM   #1 (permalink)
going to install stage 1, how dificult\ finished
Hi guys.
i have ordered the diy stage 1 injectors that i am going to install. plus new glow plugs at the same time. i am werry unshure about the job to get out the old ones there is a tight fit in the e350.
what is the best way to do it. can i do all from inside the car. or do i have to remover the front of the veichle so i can reach it from there.
just as plain as remove the top covers is a tight fit some of the nuts are between the engine and cars body cant even get the fingers down there.
some of you that would tell me some tricks for doing these job?
that would be great
1996 e350 7.3 powerstroke.
4" exhaust. custom intake. DP-tuner f5.
stage 1 diy injectors
tugger hd2 shift kit
tripple disc billet converter
matsh is offline
Old 07-24-2009, 08:24 PM   #2 (permalink)
blageurt's Avatar
Search my post when I did mine last year about this time.
95 E350 PSD HD Cargo , BB shim , E4OD , B&M aluminium Trans pan , Twin HD coolers , Cat sleeps with the fishes , 3:55 D70FF, Michelin LTX " E " , DP flashed 60 Tow , 140 V idm , Autometer Triple Pillar Guage pod , New Injector O-rings /IPR /lift pump / filterbowl @ 235K , Timbrens SES kit , replaced lift pump /ICP/ IDM @ 256 K
1977 F350 Dually Dump , 460 , 429 POLICE heads , 4:56 D70FF, Edelbrock Intake , Holley 850 dbl pmper ,MSD IGN , Custom HiPo C-6 Trans , Dual Exhausts , Bridgestone "E" Tires
1983 KZ1000R , Yoshimura Stage I
1982 KZ1000 , 1045 Wiseco , Turbo ready
1990 KX500
blageurt is offline
Old 09-13-2009, 05:31 AM   #3 (permalink)
i read you post on the injector swap and couple other that have done it to the e350.
today i got finished with the job.
it was tight but not had to do. some air tools helped alot and made thing easy. i used 4 hours to take out injectors and glow plugs. removed alternator so couple of bolts i reached from front but most from inside the car.
i made 2 cuts in the body at the closest to the engine, so i could bend the body a litle away and got much more room when doing that. when finished just bend the body metal back so the sealing for the doghous works.
only drove it a litle test run now and it works great. and it is big different from stock to stage 1 diy. one of my old injectors also hade a broken spring.
so now i am going for a litle trip to get out all the air from the system, litle hard started now.
matsh is offline
Old 09-13-2009, 10:40 AM   #4 (permalink)
blageurt's Avatar
Congratulations. I will also be installing Stage 1's in my truck too . . .
1990 KX500
blageurt is offline
Old 09-13-2009, 03:01 PM   #5 (permalink)
back from a litle trip with the van now. it works great. stage 1 plus dp tuner is fun
seams like the auto tranny is slipping. is it anything i can do so the tranny holds up better? do i nead new converter? shift kit?
dont know the power it is making but it is so much more than the stock injectors. 2bar (30psi?) of boost as soon i hit the trottle 12 psi with stock ..
this makes the van move fast, and realy smokey. just need locker in the axle now....
matsh is offline
Old 09-14-2009, 07:47 PM   #6 (permalink)
blageurt's Avatar
I' m getting a new convertor for mine a billet triple clutch number . . .
1990 KX500
blageurt is offline
Old 09-15-2009, 08:39 AM   #7 (permalink)
VISIONQUEST's Avatar
injectors
congrads!
same here i put the (modded) older model single shots in mine (not sure if this is what you meen (stage 1) with the DP-tuner, trans lasted about a month before i started having problems ,torque converter was trashed , couldnt handle the launches it had a bevy of probs
4x4 quigley 2001 e350 psd 3.55 posi front & rear/ insulated fully/ all power/ 4flex steel 6 way heated/rear removeable leather captain chairs / carbon fiber dash cover/ 2000watt rockford fosgate sound system system12 speakers/scmt/magna flow complete from turbo back/carbon fiber gauges auto meter trans,boost,exaust pre/isspro tack/crime stopper alarm remote start stop /towing package/
Custom Pro Built Trans steel planets tripple disc Red Eagle discs hardend input & drive drum /
W/A Intercooler... SIngle shot stage 2
2001 E350 4.10 all stock cargo 140k
VISIONQUEST is offline
Old 09-16-2009, 03:28 AM   #8 (permalink)
its the same injector
i have a 96mod car so i had the single shots. just bought the diy stage 1 160cc kit and rebuilded them.
what boost are you running? my gauge stops at 30psi and it goes past that. maybe i am pushing 35psi.
with g tech i read 218hp at wheels with stock injectors and dp tuner on aggressive. tested with new injectors same setting on the tuner then i got 281 on the wheels. so a big gain in hp.
matsh is offline
Old 09-16-2009, 08:34 AM   #9 (permalink)
boost
im pushing about 38 lbs my gauge goes to 35 but keeps going past the 35 aprox 38,39,
but i just found one that goes to 60lbs im thinking about swapping maybe /
i have g-tech too ran a 5.9 0-60 i havnt done hp on it yet (awsome) got to do that
yeah huge gains
Old 09-16-2009, 08:41 AM   #10 (permalink)
intake
i have a intake and 2 pipes and boots clamps etc , minus innercooler for sale 150.00
for a truck it would probably fit on your van wont fit mine it has the 2in intake connectors 3 in pipes if interested ?
Old 09-16-2009, 04:16 PM   #11 (permalink)
not shur what you are selling but the intake from a truck witch ic would be nice, have been looking at a way to fabricate the ic piping not much space to drag the pipe must figure a good way to do that first.
i did a litle test but let the throttle go at 50mph i used 5.4 sec to do 50mph so around 6-6.5 sec to do 60mph maybe right
matsh is offline
