Old 12-12-2007, 05:07 AM   #1 (permalink)
u2slow's Avatar
My Photos: (16)
Got my 19.5's today!
I got the Vision 81's from Rickson. Just a pair for the rear of my E350.
$590.30 CDN once all the dust settled at the border. That includes the $12 to receive them at Ship Happens in Sumas, WA and the 6% GST levied at the border. (no 7% PST by the way). Les Schwab in Lynden quoted me $310 each plus I'd have had to pay state tax on top. Wheels-West up here could get them too, but were even more $$$ than Schwab.
I tried to get tires mounted right away, but Abbsry Tire had run out since me checking 2 weeks ago. I'm not a big fan of the "Triangle" brand, but the price has convinced me... $240 CDN each mounted & balanced. They are a 245/70R19.15 in a healthy traction tread very similar to a Goodyear G622. Load rating is supposed to be H and 4800#. They will have stock again on Friday.
Its gonna be nice rolling on rubber that isn't a baloney-skin. [img]/forums/images/%%GRAEMLIN_URL%%/crazy.gif[/img]
95 F350 Crew 5spd/4.10, SuperChips tuner, solid flywheel, T444E waterpump, 205° stat, Locked F&R, 9.00R16 Michelin XLs
97 E350 SRW cutaway, E4OD/D70/4.10, 19.5s on the rear, deep trans pan, batteries inside, 1800W inverter, manual glowplugs
84 C30 Suburban, 6.2/4-spd, 3.21s
Other rigs I goof around with regularly:
93 F350 4x4, 7.3 IDI turbo, 5spd, 4.10s
90 F250 4x4, 7.3 IDI, 5spd, 3.55s
, D60 swap, straight pipe, turned up fuel screw
u2slow is offline
Old 12-13-2007, 02:59 PM   #2 (permalink)
SIC-E's Avatar
Re: Got my 19.5's today!
lets see pics when shoed. wish i could get my 10 ordered.
2004 E450 Cutaway, 6.0L, quigley 4x4, ambulance pkg., maxbrake controller, curt 20k fifth wheel. Future mods: 52" sleeper, tandem (6x6?) rear (aint look'n likely), frame cover. maybe a Herd front bumper.
2003 F350 Lariat, 4x4, CC, SRW, Dark Green Fx4 SOLD
1995 C3500 6.5l work trk, 2x4, CC, DRW, white DECEASED PREMATURALLY
2003 JEEP WRANGLER, ooooops, not anymore!
1986 26' Seaway Northstar w/ 454 Mercruiser
2008 Montana Mountaineer 332PHT
1991 GMC Topkick, CAT, 4' vert. gang boxes, 12' dump. if only all were as reliable!
SIC-E is offline
Old 12-31-2007, 12:00 AM   #3 (permalink)
u2slow's Avatar
My Photos: (16)
The wheels and tires went on today [img]/forums/images/%%GRAEMLIN_URL%%/grin.gif[/img]
http://www3.telus.net/u2slow/97e350/
The center caps aren't deep or wide enough for the Ford hubs. I'm going to call Rickson about that in the new year.
The strangest thing is how these 16ply tires ride so smooth. I wonder if that's a sign how hard I was working those 16" 10/E tires.
u2slow is offline
Old 12-31-2007, 08:34 AM   #4 (permalink)
Nice. Is there any overall OD dia. difference?
1999 E350 7.3psd , XLT , 15 pass/ext , purchased 6/6/05 w/255k on odo, 8/05 added BTM/straight pipe,5/06 BTS,1"shimmed front coil springs,Michelin XPS 235/85 16 R.,FredGroeske2"rear wheel spacers,1-1/2" rear sway bar,AIC,3 A-pillar guages, Tekonsha envoy,coolant filter,4 pos dp-tuner,In-tank mod & harpooned,dahl-100 prepumpfilter,Scan-guage,Bilstein shocks.
bork is offline
Old 12-31-2007, 05:25 PM   #5 (permalink)
u2slow's Avatar
My Photos: (16)
Yes. They are a healthy 33" tall. The stockers were 30".
I only have them on the rear. I'm not sure they'd fit on the front.
u2slow is offline
Old 12-31-2007, 06:42 PM   #6 (permalink)
I have 265/70R17 on the front of my van. They fit fine (also 33" tall). I do have 4600# springs though so it sits about an inch higher than stock, and doesn't drop much at all when loaded. Since the 19.5s are narrower than mine, I'll bet they wouldn't touch even with stock spring rate. I run 235/80R17 in the back.
Van
PS - dropping bumper valence was cause by trying to drove though a snow bank that was actually solid ice. NOT cause by oversized tires.
2000 E350 DRW XLT wagon
carringb is offline
Old 12-31-2007, 08:37 PM   #7 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: carringb</div><div class="ubbcode-body">I have 265/70R17 on the front of my van. They fit fine (also 33" tall). I do have 4600# springs though so it sits about an inch higher than stock, and doesn't drop much at all when loaded. Since the 19.5s are narrower than mine, I'll bet they wouldn't touch even with stock spring rate. I run 235/80R17 in the back.
Van
PS - dropping bumper valence was cause by trying to drove though a snow bank that was actually solid ice. NOT cause by oversized tires. </div></div> Both of those sizes are about 31.5/31.7 depending on the brand. You can't fit a 33" tire on the front of a 2WD van.
1994 E-350 RB 5.8gas 4X4Quigley cargo 4.09 arb-locker f/r 35x12.5-16.5 or 285/75-16.,,, 1997 E-350 EB 5.4gas 4X4Quigley Sportsmobile camper 4.10 arb front, L/S rear 285/75-16/front 33X12.5-16.5/rear ><>J
toalpi is offline
Old 12-31-2007, 09:53 PM   #8 (permalink)
u2slow's Avatar
My Photos: (16)
A 225/75R19.5 might be do-able. But you need a 6" or 6.75" wheel for those.
I just came across these:
http://www.southwestwheel.com/wheels/alcoa/661401.htm
Would be if/when I decided I need bling wheels for the front. But I think the stock 16" steels with hubcabs is just fine for now. Note that traction tires are tough to find for 17.5".
EDIT: added a couple more pics in the URL above
u2slow is offline
Old 01-01-2008, 12:10 AM   #9 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: u2slow</div><div class="ubbcode-body">A 225/75R19.5 might be do-able. But you need a 6" or 6.75" wheel for those.
EDIT: added a couple more pics in the URL above </div></div> At 4.77" the hub bore is too small on those alcoas.
toalpi is offline
Old 01-05-2008, 04:37 PM   #10 (permalink)
u2slow's Avatar
My Photos: (16)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: toalpi</div><div class="ubbcode-body"> At 4.77" the hub bore is too small on those alcoas. </div></div>
Good catch. [img]/forums/images/%%GRAEMLIN_URL%%/wink.gif[/img] Not hard to change that detail.
I may look at recentering some DRW 19.5s for the front. Their weight rating (3000#ish) is ample.
u2slow is offline
