Re: Heavier/taller coil springs for E350 front?
When I bought my 2000 there was an option for a front spring coil upgrade, I think it was like 100.00 bucks or so at the time of build, but my front end has no problems. Maybe this is the spring set you need. They made them to carry the 7.3L and the V10 engines.
IM about to have some airbags installed, inside the front coils and in the back on the leaf springs. Many people swear the airbags give the van a smooth ride.
Installing the bags inside your coils may be a good way for you to fix the problem.
http://www.airliftcompany.com/al1000.html
http://www.airliftcompany.com/load_controllerII.html
check it out.
2000 E350SD PSD Extended ConversionVan, Deep Emerald Green, 3.55 LS, Premium package, Dual Alts, rear A/C. Transfer Flow rear tank (27+35=62 Gallon Range), Custom Leather Interior, LimoLights, Amsoil lubes Tranny & Rear End, Mag-HyTec Tranny and rear End Covers, K&N air filters, Alcoa 16" Rims & Michelin tires (245/75-16), CenterMatic Wheel Balancers, Autometer gauges(4), 4" MagnaFlow SS Exhaust Wrapped with Thermo-Tec Header Tape has cut the noise in 1/2, no Drone Now! , SuperChips, Bilstein Shocks, Sonnax Valve, ACPM / AIC Ford, FingerPrint Gun Safe, 20" TV Rear, DVD/VCR, 10# PowerTank (C02 AirTank), H3R Halon Fire Extinguisher 3#er. Thanks To All Members for Your Help.
