Old 05-30-2005, 02:01 PM   #1 (permalink)
hesutton's Avatar
My Photos: (30)
Help with a Dana 61 on a '83 E350
I have what I think is a Dana 61. It is from a '83 E350. The axle code on the door sticker is C4. The bill of material (605022-7) number gives me Dana 61, 3.73, LS. Doesn't that sound right? Anyway, it is missing the passenger's side hub and drum. Anyone know how expensive these items are? Also, any information on the Dana 61 would be greatly appreciated. I know jack about the 61. I was thinking about putting this axle under my F250 because of the LS diff. Would it be cheaper/better to just buy a LS diff for my 10.25 axle, or to rebuild and use the Dana 61? Any information would be greatly appreicated.
Heath
1986 F250HD 4x4 7.3L IDI '95 PSD front clip, '97 bed, T19, D60/10.25 with 3.55's. Rebuilt from the frame up. Banks Turbo, DPS IP & Stage 1's, Isspro TTM, Banks Exhaust, Boost gauge, Pyrometer, Precharged Coolant Filter, Holley Red Pump. 16.5 x 37 x 12.5 Goodyear Wrangler's, Air Horns. 6in lift, Fresh Paint, On-board Air. Revamped Interior. Rhino Liner.
1983 F250 4x4 5.0L with C6. 340,000+ miles.
7.3 Project Pictures
Webshots Project 7.3 Gallery
DYNO YOUR IDI AT THE 2009 RALLY
hesutton is offline
Old 05-30-2005, 02:55 PM   #2 (permalink)
Re: Help with a Dana 61 on a '83 E350
Your 10.25 will have bigger stronger axle shafts. Also a larger stronger ring gear and pinion gear. The LS in the 61 will likely need rebuilt, spend the money on the Sterling.
1974 E300 Pathfinder camper van. "The TURTLE" 302/c4/d20/d44/d60. 4.10's. 235/85R16's
1984 E350 Centurian with pickup style dually bed. 6.9 diesel, C6, US Gear OD, 4.10 D60.
2000 E350 Quigley LB. "Angel Hauler" V-10,4r100,1356,d60,d60. 5.13's Now rolling on 44"s. 35 Spline Detroit rear. Alloy shafts. Power lok front. 35 spline alloy stubs. clocked t-case up for more clearance. Now Alaskan built and Moab tested.
My pics here- http://photos.thedieselstop.com/show...at=500&thumb=1
Dansvan is offline
Old 05-30-2005, 04:42 PM   #3 (permalink)
The main reason that you shouldn't use this axle is that the differential is not in the center. The engine and the entire driveline is moved over towards the passenger side approximately 2-4 inches(?) in the vans so that the driver has "enough" room for his feet and the pedals. I would expect vibrations and short U-joint life.
1994 E-350 RB 5.8gas 4X4Quigley cargo 4.09 arb-locker f/r 35x12.5-16.5 or 285/75-16.,,, 1997 E-350 EB 5.4gas 4X4Quigley Sportsmobile camper 4.10 arb front, L/S rear 285/75-16/front 33X12.5-16.5/rear ><>J
toalpi is offline
Old 06-08-2005, 07:51 PM   #4 (permalink)
hesutton's Avatar
My Photos: (30)
I'm not sure about that. Both the Dana 61 (from the E350) and the 10.25 on the truck have the pinion 2 inches closer to the passengers side. The yoke is in the same location. The axle tubes are the same lengths from the yoke on both axles. Maybe this changed in later models, but the old Dana 61 doesn't differ in that respect to the 10.25 on the F-series.
Heath
hesutton is offline
