Leave it on there. It's no big deal. If your replacing the rotor it will have a new ABS ring on it.
OOPS...now I took a look. The ring is pressed on. Maybe just heat it up and it will wiggle free. Use a couple of pry bars and work your way around it.
1997 Jayco 323RKS fifth wheel w/2 slides, Air Lift 5000 bags
Train Horns: Pictures here
PM please not visitor message
Reason: didn't look at the pics...
