Old 01-10-2008, 03:37 PM   #1 (permalink)
Help locate harness for AIC hookup
Awesome site,just got a oem AIC from Ebay.Have a 02 E350 7.3 psd and cannot locate harness to plug this unit in.Checked behind kick panel and looked underneath,no luck.Any help.Thanks,Mike.
skidoo68 is offline
Old 01-10-2008, 07:47 PM   #2 (permalink)
Re: Help locate harness for AIC hookup
It's behind the kick panel on the drivers side. As I remembered I had to search around for it. It was burried in a hole or something. It's there, it may be hard to find. Look where all the wires go into a hole.....
HeyBob is offline
Old 01-10-2008, 09:24 PM   #3 (permalink)
SuperbeastVan's Avatar
OK time to start learning...What is an AIC?
If it is the trailer brake controller harness I found mine up on top of the engine cover. It was also brown, when my owners manual said it was gray.
Ken Schwarz
Dayton, NJ
2000 E350 4x4 Dually
Clamshell Style Rear Doors, Gullwing Passenger Side! Hopefully soon to have Air Suspension and Tilt Nose.
SuperbeastVan is offline
Old 01-10-2008, 11:01 PM   #4 (permalink)
The connector for the AIC on my 03 was taped to another piece of the harness with several wraps of tape. It was on the drivers side, in the wiring bundle on the left up behind the ebrake area. The connector on the AIC will tell you what to look for.
Superbeast, the AIC is a box that allows you to control the idle speed electronicly to whatever you want it to be. Mainly used for trucks with PTO needs, like wreckers. I got one as the simple solution for a tach. It also has a nice "voltage protect" feature that keeps the idle up in response to heavy volatage loads so the batteries doon't get flattened - again made for emergency vehilce use, but nice for jump starts and the like...
Dave
2003 E350 Chateau
www.divehatteras.com
DivinDave is offline
Old 01-10-2008, 11:59 PM   #5 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: DivinDave</div><div class="ubbcode-body">The connector for the AIC on my 03 was taped to another piece of the harness with several wraps of tape. It was on the drivers side, in the wiring bundle on the left up behind the ebrake area. The connector on the AIC will tell you what to look for.
Superbeast, the AIC is a box that allows you to control the idle speed electronicly to whatever you want it to be. Mainly used for trucks with PTO needs, like wreckers. I got one as the simple solution for a tach. It also has a nice "voltage protect" feature that keeps the idle up in response to heavy volatage loads so the batteries doon't get flattened - again made for emergency vehilce use, but nice for jump starts and the like... </div></div>
More on simple tach solution please!!!
And what does AIC stand for??
2003 E-350 7.3, 38R, DIY intake, 4" turbo back, DP Tunes, forged rods, exhaust ported heads, comp 910's, h-11's, stealth twin pumps, 230cc hybrids, racerx trans and tc, water injection
rpm1 is offline
Old 01-11-2008, 02:10 AM   #6 (permalink)
The AIC (Auxiliary Idle Control) is a box that has a numeric readout that lists the current engine speed and has an up and down control to adjust the idle manually or it can be programmed as listed above to increase idle for extended idle with emergency lights/equipment activated. It is a commercial option from Ford. Here's the manual from Ford in PDF format for more information:
https://www.fleet.ford.com/truckbbas...pcm_manual.pdf
Later,
Joe
'00 (born 1/00) PSD X 4x4 Limited 285 Dayton Timberline ATs and Rancho 9000x's Prepump & in tank mods and HX Crossover installed 4.5" Magnaflow Stainless Exhaust w/downpipe
AFE Stage II Magnum Force Airbox
'95 F-350 XLT CC 4x4 DRW PSD 5-speed 4.10s Alcoas
Crash_AF is offline
Old 01-11-2008, 12:11 PM   #7 (permalink)
Thanx for the learning experience guys!
Ken Schwarz
Dayton, NJ
Old 01-11-2008, 02:24 PM   #8 (permalink)
XRACER's Avatar
You can see it in my pictures. I mostly use it to up the idle speed when I need to leave my dogs in the truck with the A/C blasting.
AIC
With the digital readout, it's also pretty clear when that BTS tranny is locked up.....
2005 E350 Standard Cargo Van, 6.0 PSD, 4.10 L.S., Quigley 4X4 New on 11-18-05
(seems to manufacture oil....1 Qt per 4000 miles)
Warranty Turbo 7-07 22,000 miles
Warranty A/C compressor 10-07 25000 miles
2003 E350 Extended Cargo Van, 7.3 PSD, 3.55, Quigley 4X4 New on 2-1-04
Some Pix
Transfer Flow 46 Gal.***Delaminated***Replaced 8-29-06 UNDER WARRANTEE
XM Radio, Alpine GPS Nav. System
7.5' Western Snow Plow
Quad Captain's chairs and Espar Furnace
OX cable locker on front
ARB locker on rear
BTS Tranny 9-29-07 @55,000 miles
Aluminess Bumpers
Mile Marker 12,000 pound hydraulic winch
2000 F250 ...... just cuz people are dumping them for the fuel bill. Got mine on ebay for $8749 with 116K on the clock. Go-fast mods to follow.....
XRACER is offline
Old 01-12-2008, 10:59 AM   #9 (permalink)
Thanks for all the replies guys.I'll start rippin some of the tape off the harness behind kick panel.Thats where my plug was for the electric brake hook up.
skidoo68 is offline
Old 05-28-2008, 05:20 PM   #10 (permalink)
Would anyone have a part number for the factory harness.Picked up another AIC from a junker but no harness.My harness does'nt have the part number tag/sticker on it.Thanks.
skidoo68 is offline
Old 05-28-2008, 09:24 PM   #11 (permalink)
XRACER's Avatar
Here is the Ford number for the harness XC3Z-14A411-AA
Try these guys... Sturdy Corp
Good luck.
Some Pix
ARB locker on rear
Aluminess Bumpers
XRACER is offline
