I have a 1995 Ford E350. The horn and cruise control stoppped working. [img]/ubbthreads/images/graemlins/shrug.gif[/img] I believe it was around the same time. But not possitive. I have checked all of the fuses in the interior fuse box.
I pulled the stearing wheel cover off to look at the switches and wires. It appears that only 3 wires are used for all the switches (5 cruise control and 1 horn). How does this work? I have a Chilton's book but it doesn't cover the horn or cruise control. So I could use some schmatics of the electrical system for horn and cruise. mikep_1998@hotmail.com
I dont know much except what I'v read around here. If you have an air bag be carefull!!! Darthsurplus just went thru alot to findout why cruise control quit. He finally got it scanned & said it was the best sollution instead of wasting time with trying parts.Sounds like a clock spring problem though, even though I have NO experiance.Did I say be carefull of air bag ? you test-light wrong connector & ????? [img]/ubbthreads/images/graemlins/shocked.gif[/img]
If the horn and cruise control stopped working odds are better than not it is the clockspring.The clockspring is located behind the steering wheel.You don't have to pull the wheel to check it but you do to change it. I will copy in a link to another thread with more explanation how it works.
While I love diesels, I don't need one, and unfortunately, after much deliberation its a hobby I currently cannot afford.......... Gone but not forgotten:
1999.5 F250 CC SB XLT 4WD, 7.3 PSD, First F,2nd Diesel, nice but still liked the van better.
2003 E-350 Super Duty Chateau (Club Wagon)7.3PSD, 3rd Clubwagon,First diesel, Never should have sold it....
If your airbag light has also changed its behavior, you have a perfect trifecta pointing towards your clockspring. Even if I had a perfect clockspring trifecta, I would STILL SCAN FOR CODES AND PERFORM A SWITCH SELF-TEST FIRST
There is one wire that sends all of the cruise and horn button inputs to a controller. Each of those six buttons causes this control wire to be at a different voltage. The controller responds based on the voltage it reads.
Don't change parts. Persevere and find a code scanner capable of initiating the on-board diagnostics FIRST !! !! !! !! !!
Good luck! [img]/ubbthreads/images/graemlins/smokin.gif[/img]
And Welcome to the Dieselstop!!!! [img]/ubbthreads/images/graemlins/laugh.gif[/img] [img]/ubbthreads/images/graemlins/laugh.gif[/img] [img]/ubbthreads/images/graemlins/laugh.gif[/img]
(it will be easier for you to find stuff if you go to your page, and edit your preferences to show 100 threads per forum page.)
"Nothing in life is so exhilarating as to be shot at without result." - Sir Winston Churchill
May your road stay clear & dry, may your fuel never gel, and may you never be outsmarted by your idiot lights.
Thanks for jumping in there with this stuff, guys. [img]/ubbthreads/images/graemlins/grin.gif[/img] I was working on it, but was called away in the midst of all that typing.
Interesting, This I didn't know. Is the controller you mention above the infamous and frequently cursed GEM module I have read about or is it unique to just those functions in the wheel?
Where is the horn relay?
I am working on putting a set of electric horns on the van and am trying to find the relay for the horns......
2000 E350 7.3PSD, Hellwig Stablizer bar,140 Lightforce with covers, 55Watt High/Lows HID's (watch which company) , extras in the bumper. 4"Aero Turbin and 4" all the way back. 1705 program, Scangauge II,265/75/16E Toyo Open Country, My Photos http://photos.thedieselstop.com/showgall...&stype=&ppuser=
"FAILURE IS NOT AN OPTION"
It riles them to believe
that you perceive
the web they weave
And keep on thinking free
Depending on year and model, it can be the GEM or it can be the PCM. On mine, it's the PCM. I think. [img]/ubbthreads/images/graemlins/smirk.gif[/img]
There's an interesting experiment to perform the next time I pull my PCM. See if the horn will honk with the PCM out of the truck. [img]/ubbthreads/images/graemlins/tongue.gif[/img]
I don't know where it is, But you could unplug the stock horns then hit the horn and listen for the relay clicking and track the location that way. Quicker with a helper.
I just cut the horns into the stock and other horns that I have on the van........... now there are 3 sets.......... of horns.......
that you perceive
the web they weave
I would be looking at the fuze under the hood.. it is a very small one.
Because of my horn set up , there are times that I lose the horn and yes the curse control.
that you perceive
the web they weave
