Hi All!
1. My horn quit. Relay clicks. Any idea where horn is??
2. Brake rotors warped again. Dealer cut them twice under warranty. Suggestions welcome as to where I go from here.
Many thanks!
Marty
'96 F-250 XLT 4x4 reg,cab 8' bed E4OD All synthetic's 4:10 Rancho 9000's, Michelin LTX MS , New injectors, high pressure oil pump, glow plugs and harness, turbo pedestal, Hayden cooler,idle controller, California regulator kit, CPS at 105K, Banks down pipe, Now 144,000 10K mod, Joe Servo Mod
2003 E-350 Super Cargo 7.3 3:55 L.S. Premium van group,Power group "Bone stock" for now!
Did the dealer install new rotors first time is that why the warranty. If so I think he may have used Chinaman or Meksico made, request the Moog or OEM Ford as they must be pretty thin now. One other thing could be your rear brakes are not adjusted up and taking their fair share of the load.
Dealer would not replace rotors. Only cut them twice!! [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Too bad about rotors........ the horns are usually placed under the batteries different sides different truck years.... [img]/ubbthreads/images/graemlins/shrug.gif[/img] Check the engine compartment fuse box for relay and a 20 amp fuse.. does the Speed control work it's on the same fuse in my truck 93.
If I may; rotors don't warp, they get brake pad material built up on them and it feels like they're warped. I would first ask what material the pads were. If they were organic, or cheap, the problem occurs much faster. Rotors can only be turned to a certain size, so if your rotors can be turned again, have them turned. Unless they're deeply gouged there is very little material removed.
Then demand a high quality semi-metallic, or semi ceramic pad and bed them in correctly.
The single biggest reason people complain about warped rotors is because the new rotors/pads weren't bedded in correctly. Use the 30/30/30 method, it's easy to remember. 30 stops from 30 mph with 30 seconds cool down time in between.
The most important thing is to not come to a complete stop in between stops. That is when most material transfer occurs. Blazing hot rotors with blazing hot pads pressed against them, this is where 90% of the damage is done. So get up to 30 and mash the brakes, don't skid, but brake hard. Right before you come to a complete stop let off the brakes and roll out. Speed up after thirty seconds of coasting and do it again 29 times. You will then be able to use your brakes with vigor and will get very little warp-feel.
When my van brakes are hot I never come to a complete stop at a light or at a sign. I stop 10 yards back and slowly creep forward. So my hot pads are never pressed against hot rotors. Our vans are heavy, with alot of weight up fron so the front brakes take alot of beating. Try this, you'll be glad you did.
