Old 11-24-2007, 09:08 PM   #1 (permalink)
Clark2's Avatar
How long can you go without the sway bar?
As part of my 4x4 conversion I need to attach a front bracket that holds the springs. I measured it up today and it looks like the bracket overlaps where the sway bar is bolted on. So, how long can I drive without the sway bar.
Here's the reason I ask. I also need to replace the water pump (sooner than later). I've been thinking of approaching it the Sixiron way and removing the radiator. It turns out that it would also be a whole lot easier to install the bracket without the radiator. For this reason I would like to do both at the same time. What does everybody think?
2000 E350 Chateau, 7.3 PSD, Ujointclothing DIY 4x4 conversion, Amsoil dual bi-pass oil filter, Amsoil Blue Air Filter, Reunel rear bumper, Bushwacker Fender Flares, and leaf spring front brackets
Clark2 is offline
Old 11-25-2007, 12:00 AM   #2 (permalink)
88beast's Avatar
Re: How long can you go without the sway bar?
id say forever just make sure to keep it in alignmetn and have it adjusted every month also dont push it remember it will move a lot!!!
its common on off road 4x4's to remove it
88 F-250 body,550 rear frame setup, 7.3 idi, 3:73 dana 80 rear, srw, dana 50 front, heavy duty leaf springs, back up camera, 20$ wallyworld fog lamps, class 5 bumper hitch welded to frame and gusseted, 32" steering tires all around, ac power converter,jeep bucket seats, deezee runningboards (cab only),cobra 29 cb w/ 102" whip, 2 trucklight worklights on front stake pocket each side,high lift jack behind seat, toolbox for the junk, visor, running lights, 6600 lbs with all my junk
http://youtube.com/watch?v=ILAQuHNAGE0
i plan to add propane kit, stake body bed, gn hitch,western style mirrors, and a lot more
88beast is offline
Old 11-25-2007, 03:16 AM   #3 (permalink)
One of mine from my current 4wd vans is in the garage. Of my past 4 2wd vans, only one came from the factory with a sway bar. It will ride smoother but it will lean a little bit more in the corners. It might scare you at first. Don't be afraid.
1994 E-350 RB 5.8gas 4X4Quigley cargo 4.09 arb-locker f/r 35x12.5-16.5 or 285/75-16.,,, 1997 E-350 EB 5.4gas 4X4Quigley Sportsmobile camper 4.10 arb front, L/S rear 285/75-16/front 33X12.5-16.5/rear ><>J
toalpi is offline
Old 11-25-2007, 10:12 AM   #4 (permalink)
My Photos: (13)
Sway bar is an addition not needed.
Its only reason is to help control body roll.(on road)
This is a reason why vannies install a rear sway also.
Off road is reversed. You dont want sway bars.
Best is to have the sway setup with quick disconnects.
This way you get best of both worlds. On/off road.
Bill
97 E-350 Quigley Van Picts
Supporter/User of THE CURE E4OD/4R100 Transmission Control
WWW.FORDTRANSMISSIONCURE.COM
TO RENT THIS SPACE SEE YOUR ADMINISTRATOR
ads@thedieselstop.com.
MADVAN is offline
Old 11-25-2007, 10:24 AM   #5 (permalink)
Right sway bar just cuts down on body roll. Kind of like having a hot wife, not necessary but makes life nicer.
*ASE Master Certified, Medium & Heavy Trucks*
Mr_Roboto is offline
Old 11-25-2007, 12:47 PM   #6 (permalink)
roboto, in my experiance hot wife HIGH MAINTAINENCE!!!, not sway bar related
wade
2002 E350 EXT. Cargo 7.3PSD , silver metallic , bought new presently 178K , dual alts. , auxiliary idle control , rear a/c heat , premium group , michellin LTX M/S on AMERICAN RACING WHEELS outlaw II's , centramatic balancers , optima yellow tops not worth the extra money imo weak at best replaced with wal-mart everstart maxx more snap 1/3 the price , ITP in tank mods van specific , ITP prepump filter,ITP regulated return system van specific , DP-TUNER F5, stock,40 tow,80 econo,120 extreme , NON-EBPV turbo pedistel DIESELSITE viton o-rings ,K&N filters tempararelly till i devise a better set up , more modds on way
FULLAUTO is offline
Old 11-25-2007, 01:29 PM   #7 (permalink)
anybody have any ideas on how to mock up a track bar?
wade
FULLAUTO is offline
Old 11-25-2007, 08:24 PM   #8 (permalink)
88beast's Avatar
i dont know about your vans but if a truck has it its made for it at the higher highway speeds
88beast is offline
Old 11-25-2007, 11:14 PM   #9 (permalink)
Clark2's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: FULLAUTO</div><div class="ubbcode-body">anybody have any ideas on how to mock up a track bar?</div></div>
The work from Chris is that it won't work. He says to just cut them off.
Clark2 is offline
