Old 01-22-2003, 10:03 PM   #1 (permalink)
How long did it take you?
Ok, E owners. How long did it take you to change out all the injector o-rings the first time you did it? Still doing mine, seems like eternity. Still not done with 9 hours into it so far. [img]/ubbthreads/images/graemlins/confused.gif[/img] Plus hours and hours of reading posts.
My Mods http://community.webshots.com/user/sconure
1996 E-350 , Bean's stage 2 injectors, 3" intake plenums, dual EGT gauge, boost, tranny, fuel pressure gauges.
94 RT10 Viper
96 GTS Viper
98 GT2 Viper
58 MGA
dansk is offline
Old 01-24-2003, 08:11 PM   #2 (permalink)
Re: How long did it take you?
Took me probably about 5 to 6 hours maybe. The first couple were really easy, the ones farthest away were pretty tuff. For the ones in the back i took a razor blade and cut through the rings and just pushed them off instead of trying to rip my arm outta socket trying to get the old rings off and new ones on, only had to rip my arm off trying to put on the new ones instead. A little diesel fuel or oil on the rings also helps them slide on a little easier.
When we had them done by a dealer they were back leaking within a month, i just thought it was a standard thing to leak i guess. When i did them myself they have not leaked since. Perhaps the dealer didn't pay much attention to detail. But anyways, good luck, an assistant might speed things up too, bring you tools, hold lights, screw things in while you hold them. One thing i remember being kinda difficult was screwing the injector line back onto the injector, the cap kept cross threading, that took a while to shimmy on right finally.
Eric
Ford 1992 E-350, 6,900 lbs.
Dodge 1997 Ram 3500
Ford 2005 F-350
yaric008 is offline
Old 01-25-2003, 08:21 AM   #3 (permalink)
My Photos: (25)
The first time it took me all day because i was trying to do them in the van one at a time.
I found that the best and quickest way is to take one side at a time.
Disconnect the drain line at the back and front on on each side.
Disconnect the injector lines and gentely lift the injector lines just eneough the lift out all the caps and lines as a assembly on each side.
Use the old set to make a new one on a worktable and it is easy. You do not have to fight with those little clamps.
I use one of those little ice pick with a hook. You can even use a large sewing neddle. Go under the O rings and take them out all at once and replace then. Besure to lube the new ones.
Then set the caps and line assembly back in there as a unit connect the lines at the front and back and the injector lines and you will be finished in half the time.
Dwight
dlblack is offline
Old 01-30-2003, 08:57 PM   #4 (permalink)
fourhatz's Avatar
The other two replies they have the IDI 7.3l not the PSD. They are talking about resealing the return lines on there nozzles not what you are doing.
96' F-250 4x4 SB Crewcab, 3.55 gears, E4OD with Sonnax valve and Tricumulator springs added,Air bags, 2" leveler kit, 10 disc cd changer, Tymar intake, Tymar 4 pos TS chip, 4590 cooler, boost, pyro(pre-turbo) & tranny temp AutoMeter gauges mounted in pillar, Diamond eye 4" exhaust with lost kitty, Tymar 3x4" downpipe, Warn hubs, Prodigy brake controller, Hypermax intercooler, CCV mod,17* HPOP, stage 1 injectors, fpr. Diesel mechanic
My Pictures
fourhatz is offline
Old 01-30-2003, 09:46 PM   #5 (permalink)
This is true that i was talking about the 7.3 IDI and it looks like dlblack was too, but how do you know he has a PSD. It doesn't say anywhere.
Eric
Dodge 1997 Ram 3500
Ford 2005 F-350
yaric008 is offline
Old 01-31-2003, 10:45 AM   #6 (permalink)
fourhatz's Avatar
From working with him on another web site. Cannot remember the year he has but he was doing a lot of work to it to try and get it running.
My Pictures
fourhatz is offline
