Old 11-21-2005, 10:16 AM   #1 (permalink)
My Photos: (9)
How much boost will our van engines produce?
Just got a boost gauge (among others), so don't know what to expect.
I'm only able to manage 15 lbs. and WOT on a grade. I also had a Wicked Wheel installed at the same time. Would this rob some boost from the stock amount, since it will spool with less restriction? I don't know if I should expect a leak somewhere or if this would be about normal...
2001 E350 PSD, Deep Emerald Green, 3.55 LS, Premium package, dual alts, rear A/C. Quigley 4x4, Transfer Flow rear tank (27+26), handicap mods, custom interior, Reunel tire carrier w/ Hi-Lift, Sportsmobile nerf bars (black), Amsoil lubes and Dual-Gard bypass oil filter, Amsoil air filters, Eclipse/JL Audio sound system w/ Sirius & 120GB Neo Car Jukebox (MP3 player), J&J stainless grill, Reunel Stainless bumper, 12000# Warn winch, PIAA lights, Bilstein shocks, Ultra Magnum wheels, Michelin tires (265/75-16), Correctrack rear wheel spacers, Bushwhacker flares (painted), Velvet-Ride spring shackles, p/s filter, external tranny and coolant filters, Wicked Wheel, Autometer gauges(5), 203 thermo, BRV+, removed air intake heater, Optima Yellow Tops, "Harpoon" mod, DP-Tuner, 4" exhaust w/ Aeroturbine, Airdog, HX-mod.
Next on the List: a blown tranny!
msnunes is offline
Old 11-21-2005, 05:18 PM   #2 (permalink)
My Photos: (11)
Re: How much boost will our van engines produce?
Matt,
Not sure how much the WW might change things, but a stock Van should produce anywhere from 15 to 19 psi boost so I think you're in the ball park.
Larry
<font color="green">MY PICTURES - Look around ... lots of good stuff </font>
2001PSD(PCM:HPI2)SD E-350,Dk Emerald Grn,4.10LS, <font color="blue">Mustang dyno - 183.9/400.4 stock</font> [img]/ubbthreads/images/graemlins/smile.gif[/img], BTS w/Schaeffer's ATF[img]/ubbthreads/images/graemlins/biggrin.gif[/img] , ITP 3.5"/4" exhaust w/Magnaflow & Aeroturbine,Dieselsite 203* T-stat/Zerex G-05,F.Pwr, Ext/Int. Upgd. pkg,R. Bds,AIC,Tow Pkg, Rear & Slider windows,<font color="red">AMSOIL air, oil-bypass & rear end 75w-140 fluid ,<font color="blue">3/8" fuel sys w/10µ Dieselsite DAHL100 & fuel manifold/sight glass</font>,6 way dr. pwr. seat, Magnefine trans/P.S. filters</font>, husky mats,<font color="red">5 gauge A-pillar ISSPRO EVs w/Grn mkr illum. + air & fuel restriction gauges</font>,Dieselsite coolant filter and zinc electrode, manual GPR switch & GP LED, blinking security LED, weathertechs, a few other "Gadgets" [img]/ubbthreads/images/graemlins/smile.gif[/img], & a 1981 26' Prowler TT(26Y)
Larry M is offline
Old 11-21-2005, 06:28 PM   #3 (permalink)
My Photos: (14)
If you scroll down the page at Bob Riley's site where the wicked wheel is listed LINK there is a picture for making a boost leak detector. Pretty easy from conventional hardware store parts. I haven't done it yet but plan too. People that have used it say its quite effective. Apparently even small leaks can cost you 1-2 psi boost perhaps more. Thats 5-10 percent of the stock range, not insignifcant.
While I love diesels, I don't need one, and unfortunately, after much deliberation its a hobby I currently cannot afford.......... Gone but not forgotten:
1999.5 F250 CC SB XLT 4WD, 7.3 PSD, First F,2nd Diesel, nice but still liked the van better.
2003 E-350 Super Duty Chateau (Club Wagon)7.3PSD, 3rd Clubwagon,First diesel, Never should have sold it....
ddog is offline
Old 12-03-2005, 12:13 AM   #4 (permalink)
Technically, the answer is, "none."
However, your van's turbocharger should produce 17 psi of boost.
That's speaking as a wise guy, but now I'll speak as somebody who has installed a WW, and built a boost leak detector, and successfully discovered leaks.
If you are trying to shave your 1/4 mile times, or maximize your dyno runs, than the wicked wheel was a mistake for you. However, its quick-spooling characteristic provides more low end grunt, which is more useful for everyday driving and pulling. If you're feeling cheated of top-end power, change it back, or go to a ball bearing unit.
Boost leaks can be a real pain. The only way to find them is with a tester. You'll want a larger air compressor, as my little runt of a compressor keeps kicking on, providing for interrupted intervals of searching. Or a longer hose. [img]/ubbthreads/images/graemlins/rolleyes.gif[/img] Some not-so-obvious things to check are the little red and green plastic lines that go to the wastegate controller and the turbine inlet tube, and the manifolds for these plastic lines. Some people make a tester that clamps right onto the turbo, but I couldn't find rubber tubing of the appropriate size. My tester clamps to the 4" end of the turbine inlet tube. The turbine inlet tube necks down from 4" to 3", has a waffle pattern on its exterior surface, a small hole for the green hard plastic line, and some weird bends.
PM your address to me, if you'd like to borrow mine. Or stop by if you're anywhere near Indy, and I'll help you find it.
"Nothing in life is so exhilarating as to be shot at without result." - Sir Winston Churchill
May your road stay clear & dry, may your fuel never gel, and may you never be outsmarted by your idiot lights.
2002 F-250 XLT SC LB 4x4 7.3PSD 6-Sp 3.73 L-S, Snugtop Snuglid Tonneau, 235/85 MC HTRs, <span style="color: red">DPTuner F5</span> AFE Stg II, Turbo LifeSaver, MAP BRV, Autometer Cobalts, Magnaflow 4", WW, TAG, AIH del, CCV, AirDog, In-tank, Harpoon, HPX, ITP fuel sys, LL8 del, 203*, Oilguard & SP Diesel bypass filtration, ART rotors, PFC pads, Heater Core Ctl Valve, Bilsteins, Velvet Ride Shackles, South Bend Clutch, <span style="color: green">21.27 mpg</span>
2004 <span style="color: red">E</span>-350
XLT Wagon 6.0PSD 3.55 L-S TDM EZ-Entry 11 pass., AIC, custom MBRP 4" w/dual Aeroturbines, Airdog, harpoon, Overhead Cobalts
Pictures . . . Parts Links
DarthSurplus is offline
Old 12-03-2005, 08:04 PM   #5 (permalink)
My Photos: (9)
Thanks -- but not sure I'll be in your area anytime soon... But FWIW, since my van is already on the 'rack' for other issues, I asked him to double-check for leaks and he said he found none. I guess I could "suggest" these other places to check as well... However, first order of business right now is getting my main tank reinstalled and my fuel system cleaned out... (see other thread)... [img]/ubbthreads/images/graemlins/eek.gif[/img]
msnunes is offline
