How to tell if I have 2 or 4 wheel ABS? - Diesel Forum - TheDieselStop.com
post #1 of 17 (permalink) Old 04-14-2011, 04:37 PM Thread Starter
Without taking everything apart, is there a sure way to know? I need to get new rotors and they asked if they were 2 or 4?? I cant get to the store if my hubs are pulled apart.
Thanks..
2006 E350 Chateau v10
mbender is offline
post #2 of 17 (permalink) Old 04-14-2011, 05:29 PM Thread Starter
Also, I was going to go with Wagner brand rotors and pads Semi Metallic Thermo Quite. Are they good or anyone suggest any others.
mbender is offline
post #3 of 17 (permalink) Old 04-14-2011, 05:45 PM
My Photos: (19)
look behind your front wheel, if you see another line, with the brake line, you have 4wheel abs. If all you have is a brake line running down behind the wheel then you have rear abs only.
DP-Tuner 80T, 160cc single shots, GTP38R turbo, Ceramic coated IH up-pipes, coolant filter, 6637, DIY exhaust brake, openair CCV, propane, SBC DD all ceramic clutch, ISSPRO EV boost/pyro/HPOP pres./rear end temp, 4" lift, traction bars, 255/70R22.5 tires, York air compressor, 16 flashy lights, 12 strobes, 12 switches on console, 9 switches on the dash, 7 two-way radios, 5 air horns, laptop, siren, 105 gal. in-bed fuel tank, Kennesaw Mountain front bumper
'86 H-D Sportster - 16" apes, custom paint, custom pipes to fishtails, single fire ignition, leather saddle bags on custom brackets, bagger fender, solo seat, home made luggage rack, all LED rear lights
BTBBT is offline
post #4 of 17 (permalink) Old 04-14-2011, 07:18 PM Thread Starter
I do see another line on the other side just wasnt sure what it was for. From the backside of the rotor, I see teeth like on a gear. I think this is for the ABS?
mbender is offline
post #5 of 17 (permalink) Old 04-14-2011, 07:49 PM
blageurt's Avatar
My Photos: (9)
Yes it is ...
95 E350 PSD HD Cargo , BB shim , E4OD , B&M aluminium Trans pan , Twin HD coolers , Cat sleeps with the fishes , 3:55 D60FF, EBPV Delete , DP flashed 60 Tow , 140 V idm , Autometer Triple pod , Bridgestone /Hankook
1977 F350 Dually Dump , 460 , 429 POLICE heads , 4:56 D70FF, Edelbrock Intake , Holley 850 , MSD IGN , Custom C-6 Trans , Dual Exhausts , Bridgestone
blageurt is offline
post #6 of 17 (permalink) Old 04-14-2011, 09:08 PM
carringb's Avatar
If you are asking about your '06.... They all have 4-wheel ABS.
I've been happiest with OEM pads. They seem to have the best bite, hot or cold. Downside is they also dust the most, and they do smell hot sooner. But I've never experienced any brake fade.
I've tried a lot of the aftermarket stuff BTW, and I'll stick with Ford fleet pads from now on.
2000 E350 DRW XLT extended wagon (yes! it's a dually!)
17" Ultra Goliath rims
Banks Powerpack, Diablo Predator
Buckstop front bumper, Reunel rear w/ 20,000# reciever
250,000+
carringb is offline
post #7 of 17 (permalink) Old 04-14-2011, 10:03 PM
Matt0987's Avatar
I recently installed the Wagner ThermoQuiet Semi-metalic pads on my F350 and Excursion. I am pleased with them. Strong peddle. No noise without having to goop them up. You just install them into the calipers. Because I have 71+ K miles on the truck I bought the set with the hardware -springs that hold the pads in place- and replaced the hardware at the same time.
'03 Excursion, 7.3L, 4X4, Auto tranny of course (they all did), 4" MBRP exhaust, TS performance chip, K&N FIPK w/ an Amsoil EA filter, Hellwig anti-sway bar, drilled/slotted front & rear rotors. Rancho XL shocks, Rancho steering damper, Airlift 5000, S&S Diversified headlight mod. This baby surprises a lot of, so called, performance cars.
'04 F 350, extended cab, 6.0L, FX4, manual tranny, 4" MBRP exhaust, Bully Dog Triple Dog downloader w/ Outlook monitor (Very disappointed in the Bully Dog), 2m-70cm Yaesu ft-8500, S&S Diversified headlight mod.
'11 Harley-Davidson Road King Classic 103 ci PowerPak w/ anti lock brakes & Smart Security system. It even has cruise control!!! Candy Dark Root Beer over Candy Light Root Beer
Matt0987 is offline
post #8 of 17 (permalink) Old 04-15-2011, 07:23 AM Thread Starter
Thanks guys. I was thinking about going to something other than OEM because mine are shaking at 32K. I did have some weight (concrete blocks) in the back to help the snow but I wasnt over my GVWR. No panic stops. Figured I could get some with a lifetime warranty for less than OEM and if I have any more issue, I can just replace them.
mbender is offline
post #9 of 17 (permalink) Old 04-15-2011, 07:24 AM Thread Starter
How was brake dust? Those were the ones I was looking at. Did they stop like OEM?
mbender is offline
post #10 of 17 (permalink) Old 04-15-2011, 06:16 PM
carringb's Avatar
Chances are you just need need to do some hard deccelerations, without fully stopping. You likely have uneven pad deposits. Changing pads will not help.
Warped Rotor Myths
250,000+
carringb is offline
post #11 of 17 (permalink) Old 04-15-2011, 08:23 PM Thread Starter
Warped Rotor Myths
Yes, I believe I do have deposits on the rotors. The plan was to replace the rotors and pads. I didnt know that hard braking can get rid of the deposits. I will try to so some on and off freeway trips to see if it will do the trick. Its weird because sometimes its worse than others. Enough to drive me nuts. I have to repack the bearings since Im at 30K so I figured I would just replace everything. I like the idea of not spending money. I will give it a shot.
mbender is offline
post #12 of 17 (permalink) Old 04-15-2011, 08:30 PM
carringb's Avatar
The hard braking doesn't get rid of the deposits, it makes the deposits even around the rotor. It does work. I also now make an effort not to stay on the brakes when I come to a hard stop, like if I come off the freeway with a heavy trailer. I pop it into Park or use the parking brake instead.
250,000+
carringb is offline
post #13 of 17 (permalink) Old 06-07-2012, 06:36 PM
Snotzalot's Avatar
My Photos: (5)
Ok guys how many of you have tried to even out the deposits on the rotors as suggested in the above link?
Does it work?
I'm about to replace a rotor and pads....
Regards,
Paul - Pocono Mtns. USA
02 E350 15 Passenger Cream Puff, 92,000 Miles, 5.4L Gasser
'90 E350 7.3L Ex-Ambulance High Top 420K Miles, No Turbo, Stock Stock stock, No ELC! (Extended Life Coolant) & 10 Oz. Bars Stop Leak. 10 wonderful cool years using Freeze12 without any AC system modifications. Retired with blown trans.
Snotzalot is offline
post #14 of 17 (permalink) Old 06-08-2012, 09:46 AM
This has been discussed in length about the deposits & how they are formed & about burnishing . Real good info. The 2nd to last post is the important info.
Ford Brake bedding procedure
1999 E350 7.3psd , XLT , 15 pass/ext , purchased 6/6/05 w/255k on odo, 8/05 added BTM/straight pipe,5/06 BTS,1"shimmed front coil springs,Michelin XPS 235/85 16 R.,FredGroeske2"rear wheel spacers,1-1/2" rear sway bar,AIC,3 A-pillar guages, Tekonsha envoy,coolant filter,4 pos dp-tuner,In-tank mod & harpooned,dahl-100 prepumpfilter,Scan-guage,Bilstein shocks.
bork is offline
post #15 of 17 (permalink) Old 06-08-2012, 01:42 PM
Snotzalot's Avatar
My Photos: (5)
Thanks, I have been reading most of the various brake posts in the F series too. My E350 definitely has the shakey brakey.
I rotated the tires a few months back and the shakey breaky was immediately gone. It has reappeared. I drove 3 of the old E series for 30 years and NEVER had a shakey brakey. So it has to be something to do with the suspension and alignment of the current E series.
Also depending on road terrain I get shakey and sometimes no shakey. So this would suggest its not entirely due to deposits?
Thanks for the link!
Regards,
  Diesel Forum - TheDieselStop.com > Ford Diesels > E-Series Vans
