how to tell if my E-350 has Front or Rear or both ends ABS - Diesel Forum - TheDieselStop.com
Old 09-10-2003, 07:49 PM   #1 (permalink)
Hi,
Time to do the first brake job at 80,000 miles. I started to collect
the parts, but all the parts places ask me if it has front OR rear or
both ends ABS.
How can I tell what type of ABS is on this 2000 E-350 XLT
Super-Duty?
Also, the ABS and Brake warning indicator lights just came on solid today.
I have searched these forums and found some clues to check this problem, but I already know it needs new pads & rotors turned or replaced, so I'm planning to do the brake job first, and while I have it all apart look for the ABS problem - does this sound like a reasonable plan???
Thanks,
Frank
1983 300TD = Retired: (Diesel yard ornament) 369,000
1985 300SD = Son's Diesel cruiser 350,000
1985 300TD = Dad's Diesel wagon 180,000
1992 Kubota Diesel tractor = mutant lawn mower 340hrs
2000 Ford Powerstroke Diesel = Wife's Toyota crusher 225,000
2004 Chevy Blazer = Daughters gas SUV 46,000
tcnofh1 is offline
Old 09-10-2003, 08:06 PM   #2 (permalink)
Re: how to tell if my E-350 has Front or Rear or both ends ABS
On the fronts you should see an additional line going down to the each spindle area, 2 lines, a brake hose and the ABS sensor cable. I get an occasinal ABS lamp as well, replaced the rear speed sensor but no fix, guess I need to dig around here a bit and find something else to change? Or, I could take it to the stealer' dealer and probably end up buying a $500 ABS computer. [img]/ubbthreads/images/graemlins/frown.gif[/img]
early 99 F350 4x4
DieselDeaf is offline
Old 09-10-2003, 09:24 PM   #3 (permalink)
To get technical your ABS light should come on when your brakes need to be changed. When you change your brakes you fill up the brake fluid resevior and that's it. As your brakes wear down the fluid level drops and there is a little sensor in there and when the fluid gets to a certain lowness the ABS light comes on. But if you look at your fluid resevior and it's full then that wouldn't be what's causing your light here. I think also if the vacuum line gets pulled off the vacuum sensor the ABS light will come on also.
I don't know it right off hand but there is a really good article on brakes around here somewheres. It tells you specifically how to break in brakes which is what you should do when you change out your brakes soon. You're supposed to turn the rotors and drums as well, if you have drums. Do a search for it... i'll look around, if i find it i'll post it.
Eric
Ford 1992 E-350, 6,900 lbs.
Dodge 1997 Ram 3500
Ford 2005 F-350
yaric008 is offline
Old 09-10-2003, 09:35 PM   #4 (permalink)
I was told by my salesman when I bought my van that all 350's from 1999 up would be four wheel ABS.
~ Pete ~
1999 E-350 PSD - Super duty cargo - 3.55 LS...Bilsteins, dual alternators, all power...125K miles - now with a new Jasper trans and torque convertor.
PJC99 is offline
Old 09-10-2003, 09:46 PM   #5 (permalink)
That sounds about right, before that it was just rear ABS i guess.
Eric
Dodge 1997 Ram 3500
Ford 2005 F-350
yaric008 is offline
Old 09-11-2003, 04:26 AM   #6 (permalink)
My Photos: (11)
Frank,
I wasn't sure what I had on my Van either and had the following exchange with the brake expert here (FMTRVT) sometime ago ...
QUESTION:
"I'm not sure, but it doesn't look like I have anything going to the rear disks except the brake line and it looks like I have the T/proportional fitting that feeds each rear brake mechanism on the drivers's side of the rear axle. It does look like I have some kind of sensor (i.e. wire) on each of my front disks. Also it looks like my master cylinder feeds some kind of manifold that has 8 fittings on it one at each end and three on each side of which only the end fittings and three on one side are used. There are three that are capped off. I don't remember asking for anything special in this area so I am guessing all I have is ABS on the front. Is this correct or how do I tell? "
ANSWER:
"You have the 4 wheel ABS (acutually 3 circuit, the two rears work in unison and skid is based off the differential sensor. This is the best unit to have and is an active, rather then passive unit. "
..... Thus I assume the key is that the master cylinder feeds this manifold and it's output then feeds the brakes ... I will try and get Jack (FMTRVT) to look at this thread and give us the definitive answer since he is "Mr Brake" [img]/ubbthreads/images/graemlins/wink.gif[/img]
<font color="green">MY PICTURES - Look around ... lots of good stuff </font>
2001PSD(PCM:HPI2)SD E-350,Dk Emerald Grn,4.10LS, <font color="blue">Mustang dyno - 183.9/400.4 stock</font> [img]/ubbthreads/images/graemlins/smile.gif[/img], BTS w/Schaeffer's ATF[img]/ubbthreads/images/graemlins/biggrin.gif[/img] , ITP 3.5"/4" exhaust w/Magnaflow & Aeroturbine,Dieselsite 203* T-stat/Zerex G-05,F.Pwr, Ext/Int. Upgd. pkg,R. Bds,AIC,Tow Pkg, Rear & Slider windows,<font color="red">AMSOIL air, oil-bypass & rear end 75w-140 fluid ,<font color="blue">3/8" fuel sys w/10µ Dieselsite DAHL100 & fuel manifold/sight glass</font>,6 way dr. pwr. seat, Magnefine trans/P.S. filters</font>, husky mats,<font color="red">5 gauge A-pillar ISSPRO EVs w/Grn mkr illum. + air & fuel restriction gauges</font>,Dieselsite coolant filter and zinc electrode, manual GPR switch & GP LED, blinking security LED, weathertechs, a few other "Gadgets" [img]/ubbthreads/images/graemlins/smile.gif[/img], & a 1981 26' Prowler TT(26Y)
Larry M is offline
Old 09-11-2003, 12:19 PM   #7 (permalink)
carringb's Avatar
All of the Wagons had 4-wheel ABS starting '95. My '94 has 4 wheel as well. I think in '96 all vans had 4-wheel ABS.
-Bryan
1994 E350 Club Wagon ext. 5.8L
2000 E350 DRW XLT extended wagon (yes! it's a dually!)
17" Ultra Goliath rims
Banks Powerpack, Diablo Predator
Buckstop front bumper, Reunel rear w/ 20,000# reciever
250,000+
carringb is offline
Old 09-11-2003, 07:04 PM   #8 (permalink)
Re: how to tell if my E-350 has Front or Rear or both ends ABS - progress
Thanks for the replys!
I have finished rebuilding the rear - new rotors &amp; pads went on
smoothly. One pad had just barely worn through to the backing plate!
Then I went to take the front pad carriers off, but unlike the rear 13mm hex bolts the fronts are held in with BIG TORX bolts. I have to go buy a driver tommorow, but have no idea what size it is - do any of you know? It is larger than a 50 - I know that much.
Thanks again,
Frank
tcnofh1 is offline
Old 09-11-2003, 07:13 PM   #9 (permalink)
Not sure... you could go buy a bunch that look close to it and then return all the wrong ones or something...
I noticed your in winter garden, how far away are you from altamonte springs? that's about where i live.
Eric
Dodge 1997 Ram 3500
Ford 2005 F-350
yaric008 is offline
Old 09-13-2003, 04:42 PM   #10 (permalink)
FMTRVT's Avatar
My Photos: (16)
Boy, not much for me to add here. As mentioned, if you have 1 brake hose and one wire going to the front brake caliper area, you have 4 wheel ABS. Both lights on usually indicates low brake fluid.
The ABS light can come on due to a dirty sensor as well. Many times the rear diff oil has a lot of metal debris that contaminates the sensor, giving a bad reading. A change of oil and cleaning of the sensor many time fixes that, but sometimes needs a new sensor. The front sensors occasionally can have some of the same issue as far as metal debris around them.
Jack
Truck Modifications below in Pictorials on Facebook. Search in Google - Facebook TooManyToys
Step Lights;Painted Flanges; Bypass Oil Filter; Heated Mirror Switch; Reverse Lights; 7.3L Fuel Reg Shim; 6 Disc Radio Speed Volume Mod; Coolant Filter, etc.
FMTRVT is offline
Old 09-20-2003, 10:04 AM   #11 (permalink)
Jack,
FIXED IT! The rear speed sensor for the ABS appears to be magnetic,
and a bunch of metal filings coated it. Cleaned them off, drove about 10 ft. code re-set, dash board "brake" and "ABS" lights went off.
Thanks,
Frank
tcnofh1 is offline
Old 12-24-2007, 04:43 PM   #12 (permalink)
In the future phone your Ford dealer near you and give them your last 8 digit vin# of your truck and they can tell you what parts and size and which option where put in your truck without guessing
Rolly is offline
