HPOP info? - Page 2 - Diesel Forum - TheDieselStop.com
Old 11-06-2009, 08:43 PM   #16 (permalink)
blageurt's Avatar
Maybe take the chip out clean the contacts and re-install it ?
95 E350 PSD HD Cargo , BB shim , E4OD , B&M aluminium Trans pan , Twin HD coolers , Cat sleeps with the fishes , 3:55 D70FF, Michelin LTX " E " , DP flashed 60 Tow , 140 V idm , Autometer Triple Pillar Guage pod , New Injector O-rings /IPR /lift pump / filterbowl @ 235K , Timbrens SES kit , replaced lift pump /ICP/ IDM @ 256 K
1977 F350 Dually Dump , 460 , 429 POLICE heads , 4:56 D70FF, Edelbrock Intake , Holley 850 dbl pmper ,MSD IGN , Custom HiPo C-6 Trans , Dual Exhausts , Bridgestone "E" Tires
1983 KZ1000R , Yoshimura Stage I
1982 KZ1000 , 1045 Wiseco , Turbo ready
1990 KX500
blageurt is offline
Old 11-07-2009, 09:14 PM   #17 (permalink)
Actually, I did that just before the o-ring job. It was time for an inspection and DOT certification, so I removed the chip for the test and put it back right after. The difference I've experienced has been since the work on the high pressure oil fittings, although it has been getting a little better each day. It has the initial punch off the line now, but still seems a little sluggish compared to the pre o-ring work. I'm thinking maybe some residual air in the lines--hoping actually as opposed to maybe being careless and letting some debris get into a high pressure line.
natsys is offline
Old 11-08-2009, 10:43 AM   #18 (permalink)
blageurt's Avatar
Change the Oil ?
1990 KX500
blageurt is offline
