Re: Idle drops to real rough shake when dead cold.
windsurt,
If your glow plug relay switch is not working It just may be super cold in that you have not started it for a week. Give it a minute to warm up and see if it still does the same rough start. If so it could be the E40D. They are a real problem. If you have to get it rebuilt, make sure they upgrade it, and install a after market strong TC.
I would also recommend installing an AutoTrans Interceptor. This allows you to adjust the line pressure and delay the TC lock up time. It really works well and makes the E40D work like it should. This product should lengthen the life of the E40D.
Rick
'95 E350 PSD, Max RPM Super Chip, Gear Vender Under/Over Drive, AutoTrans Interceptor, Sway Bar, A great Baja Machine.
'95 E350 PSD, Max RPM Super Chip, Gear Vender Under/Over Drive, AutoTrans Interceptor & Clutch Controller, Sway Bar, K&N, EBPV removed,90 psi fuel regulator; Resistor Trick; RPM,Pyro,and Boost Gauges, Sound proofing in engine cover, Sportsmobile pop-up top, A great Baja Machine.
