info on upgrading alternator - Diesel Forum - TheDieselStop.com
Old 03-02-2007, 03:24 PM   #1 (permalink)
the alternator in my van is the 130amp stock alt, i want to put in a stronger one (165amp, i think) so that i can run some extra laod on it with no probablem. does anyone know if i can just switch it out or is there anyhting else that ill need to change.
1993 e-350 cutaway van (collins 20 passanger school bus)
7.3L diesel
E40D tranny
josiahsupertramp is offline
Old 03-02-2007, 07:41 PM   #2 (permalink)
Re: info on upgrading alternator
The largest factory Ford alternator is the 130 amp 3G. You could switch to a Leece-Neville for 200+ amps, but you are looking at $500 for the alternator at least.
What are you running that draws more than 130 amps? That's a tremendous amount of power.
If you are having problems with low output at idle, a bigger alternator won't fix that. You need to increase the engine speed for the alternator to give it's max output. Ambulances come with an idle up switch for that purpose. The 130 amp 3G produces about 80 amps at idle.
*ASE Master Certified, Medium & Heavy Trucks*
Mr_Roboto is offline
Old 03-03-2007, 08:56 AM   #3 (permalink)
My Photos: (14)
F and E-series Ambulance packages from around 94-97 could be had with the Mitsubishi, Dual rectifier, brushless 215 amp alternator(Use the Tim Allen Home Improvement Voice followed with the Huh Huh Huh [img]/ubbthreads/images/graemlins/grin.gif[/img]). Uses the same T mount style frame as the 3G only needs longer bolts. This thing is a beast and weighs around 40lbs.Approximately one inch larger in diameter than a large case 3G. Its also an expensive alternator.
I bought one to put in my van (that is now Sold,leaving this am at 9:00) as part of my plan to install an inverter and turn the van into a 7.3L diesel generator for hurricane season. Still have the altenator, if anyone's interested.
My measurements indicate the the Mitsubishi Alternator will fit the current van bracket with no mods, it does not appear as though Ford changed the bracket on the van like they did in the F series (you have to grind the newer 7.3 F Series bracket to even take a large case 3G Alternator). The mitsu takes the standard Ford rectifier plug, stator jumper is not used. Charge wire size needs to be upraded as well and a Maxifuse added at the battery(s)to set it up like the factory.
While I love diesels, I don't need one, and unfortunately, after much deliberation its a hobby I currently cannot afford.......... Gone but not forgotten:
1999.5 F250 CC SB XLT 4WD, 7.3 PSD, First F,2nd Diesel, nice but still liked the van better.
2003 E-350 Super Duty Chateau (Club Wagon)7.3PSD, 3rd Clubwagon,First diesel, Never should have sold it....
ddog is offline
Old 03-03-2007, 10:43 AM   #4 (permalink)
Super_Dave's Avatar
I bought an alternator off ebay from a guy that sells higher amperage stuff. My '96 has a 200a alternator. I have four total batteriers with a 2000 watt inverter. At idle, it puts out more amps, which has been very nice.
I don't have the link for the guy, but it was an easy replacment on my bus. My cost from the Ford dealer I used to work for on the Mitsubishi ambulance alternator was a ton of money. This one was pretty darn reasonable. More expensive, but I don't think it was $270 shipped.
Super Dave
2006 E350 6.0PSD
2003 Excursion Limited 4WD 7.3PSD - Sold
1996 E350 Super Duty bus 7.3PSD - Sold
Super_Dave is offline
Old 03-03-2007, 02:28 PM   #5 (permalink)
blageurt's Avatar
My guy here in Toronto can build anything you want . I'm sure you can find a Good Automotive Electric Rebuilder in your area. Thats whatI would do .Bring it to your local Reabuilder , tell him what you want and he should be able to build it. All they need is the casting as a starting point.
95 E350 PSD HD Cargo , BB shim , E4OD , B&M aluminium Trans pan , Twin HD coolers , Cat sleeps with the fishes , 3:55 D70FF, Michelin LTX " E " , DP flashed 60 Tow , 140 V idm , Autometer Triple Pillar Guage pod , New Injector O-rings /IPR /lift pump / filterbowl @ 235K , Timbrens SES kit , replaced lift pump /ICP/ IDM @ 256 K
1977 F350 Dually Dump , 460 , 429 POLICE heads , 4:56 D70FF, Edelbrock Intake , Holley 850 dbl pmper ,MSD IGN , Custom HiPo C-6 Trans , Dual Exhausts , Bridgestone "E" Tires
1983 KZ1000R , Yoshimura Stage I
1982 KZ1000 , 1045 Wiseco , Turbo ready
1990 KX500
blageurt is offline
Old 03-03-2007, 07:18 PM   #6 (permalink)
thanks for the info.
ill be installing a veggie therm, which is an electric heater for my veggie oil system. i also wanted to charge a third battery for an inverter as i will be converting my bus into a rv and doing long term travel. but im still kicking around the idea of solar panels for the inverter so well see.
7.3L diesel
E40D tranny
