Re: injection pump removal and install for 1993 E350 7.3l
Welcome,
I had my pump out this summer, and tore off a lot of hair before I got that last nut out, the big problem was the one closest to driver. I got it out with a "normal" open wrench, but had to lurke it down below all the cables and tubes and at last I got the open end on the wrench (not the ring end) to grip. Was just enough space to loosen it and do the rest with my fingers. Tried to use a bent S-wrench, but in vain, mine was to thick to get it on the nut. Tried to cut it open, but then it got too weak and slipped...Might be a better tool for this in the stores somewhere.
The other nut is easier, remove the bracket holding the start advance solenoid and you should get to it both from the front and from incab.
Good luck [img]/ubbthreads/images/graemlins/smile.gif[/img]
Another tip: When replacing the IP, check that no return lines etc. get trapped between the IP and the valley pan, did this on mine, did not see it, and could not figure out why it did not match in the gear hole.. [img]/ubbthreads/images/graemlins/blush.gif[/img] Also check the surface of the valley pan where lines contact it, mine was nearly worn through by a return line vibrating against it. (Glued on a piece of plastic on that area.)
