Installed Magnaflow 4" S.S. exhaust today. - Diesel Forum - TheDieselStop.com
Old 07-21-2002, 06:39 PM   #1 (permalink)
It only took me 1 3/4 hours by myself to remove my existing exhaust & install the complete exhaust system less the downpipe (Thanks to my trusty Super Sawzall). [img]/ubbthreads/images/icons/wink.gif[/img]
My buddy didn't have time to modify the downpipe this weekend. [img]/ubbthreads/images/icons/frown.gif[/img] The downpipe will hopefully be installed this week). [img]/ubbthreads/images/icons/grin.gif[/img]
The Magnaflow exhaust is a complete bolt in. [img]/ubbthreads/images/icons/grin.gif[/img]
Even the tailpipe fits perfectly with no modifications whatsoever. [img]/ubbthreads/images/icons/cool.gif[/img]
The "only" modifications I made was raise the rear tailpipe hanger about 4" by drilling a new 5/16" hole in the frame,removing the exhaust mount that holds the straight pipe in place (the one that is directly inward of the 2nd battery) and cutting off about 4" of the bracket. Then I welded the 2 halves of the bracket back together and reinstalled it upside down so the hanger rod on the straight pipe would line up with it. It worked great.
I didn't even have to use any of the special s.s. hangers I purchased.
Believe me,this kit is a direct bolt-in on our vans.
I noticed a 2psi increase in boost and temps are about 100 degrees less than my previous Dynomax mufflers I had installed.
I got on it at one point and pegged my boost gauge at 35lbs of boost. [img]/ubbthreads/images/icons/grin.gif[/img]
I can hear the turbo whistle a little more but when the 3 1/2" downpipe gets installed I should hear it even more. [img]/ubbthreads/images/icons/grin.gif[/img] [img]/ubbthreads/images/icons/grin.gif[/img]
A road test confirmed the sound is awesome with zero drone! [img]/ubbthreads/images/icons/cool.gif[/img]
The idle is close to stock except it has a throatier sound like a big block chevy. [img]/ubbthreads/images/icons/cool.gif[/img]
When you get on the throttle it sounds very cool to say the least.
You can view pics of the system at the following address.
http://community.webshots.com/photo/...43538406EEWsRy
Scroll to the next few pics from this page to see more.
Magnaflow is a winner!
Thank you VAN_350SD for telling me about this system! [img]/ubbthreads/images/icons/wink.gif[/img] [img]/ubbthreads/images/icons/grin.gif[/img]
It totally rocks!
2000 E-350 Van,BTS Tranny,Custom Dana 80 Axle w/ ARB & 3:55 Gears, Swamp 175cc Injectors, Custom 4 Position Chip,TS Billet Intakes,W/Wheel,PS2000,Magnaflow 4" Exhaust,ITP Fuel Regulator,4 gauge pillar post,TTM,CTI Idle Controller,Amsoil Fluids,Evans,203 Thermostat,Coolant Filter,J&J S.S. Grill,Art Rotors,Custom Flame Job,Road Armor Bumper,Warn M15000 Winch,Bushwacker Flares,Bilstein Shocks,Centerlines,Maghytec Covers. dynoed at 345.5 rwhp
FUTURE MODS: Upgraded turbo, HD oil pump,Intercooler with water injection.
http://community.webshots.com/user/aceman116
04 Jeep Rubicon
RE 5.5" Long Arm Lift,1"body/eng.lift,Banks Header/ Exhaust,37" IROKS,Mickey Thomson Classic 2 beadlocks,Road Armor Bumpers,Warn 9500TI winch,Alloy Usa axleshafts,CTM u-joints,Nth degree oil pan skid,Clayton front high clearance brackets,Toys by Troy crossover steering,Poison Spyder Rock Sliders.
Aceman is offline
Old 07-21-2002, 06:59 PM   #2 (permalink)
My Photos: (5)
Re: Installed Magnaflow 4" S.S. exhaust today.
try to get a WAV file uploaded so we can hear it. [img]/ubbthreads/images/icons/cool.gif[/img]
1991 Ford PL Custom Ambulance Type III 7.3L Diesel. Photo Here Pioneer AM/FM/XM/CD Stereo. Code 3 lightbar, Whelen Strobes and flasher lights. Whelen flood lights on front, rear and sides. There bright enough to turn darkness into daylight. Siren with several tones plus electronic airhorn and PA. Custom 3" exhaust from manifolds back with a Gibson Superflow Muffler [img]/ubbthreads/images/graemlins/grin.gif[/img]. Dual alternators and dual sets of batteries. If I need a jumpstart all I do is push a button. On spot tire chains that install and de-install themselves at the flip of a switch. Also has air compressor on board along with suction unit and O2 system.
1972 Cadillac Hightop Ambulance by Superior Lucky if I get 10MPG
CompuDoc is offline
Old 07-21-2002, 07:06 PM   #3 (permalink)
My Photos: (11)
Aceman,
Great info [img]/ubbthreads/images/icons/cool.gif[/img] . Is your friend doing the downpipe doing it in stainless and tell him not to throw away the pattern since if his price is good he may have other customers [img]/ubbthreads/images/icons/wink.gif[/img] I plan to do mine after my 3/36 is gone [img]/ubbthreads/images/icons/grin.gif[/img]
Larry
<font color="green">MY PICTURES - Look around ... lots of good stuff </font>
2001PSD(PCM:HPI2)SD E-350,Dk Emerald Grn,4.10LS, <font color="blue">Mustang dyno - 183.9/400.4 stock</font> [img]/ubbthreads/images/graemlins/smile.gif[/img], BTS w/Schaeffer's ATF[img]/ubbthreads/images/graemlins/biggrin.gif[/img] , ITP 3.5"/4" exhaust w/Magnaflow & Aeroturbine,Dieselsite 203* T-stat/Zerex G-05,F.Pwr, Ext/Int. Upgd. pkg,R. Bds,AIC,Tow Pkg, Rear & Slider windows,<font color="red">AMSOIL air, oil-bypass & rear end 75w-140 fluid ,<font color="blue">3/8" fuel sys w/10µ Dieselsite DAHL100 & fuel manifold/sight glass</font>,6 way dr. pwr. seat, Magnefine trans/P.S. filters</font>, husky mats,<font color="red">5 gauge A-pillar ISSPRO EVs w/Grn mkr illum. + air & fuel restriction gauges</font>,Dieselsite coolant filter and zinc electrode, manual GPR switch & GP LED, blinking security LED, weathertechs, a few other "Gadgets" [img]/ubbthreads/images/graemlins/smile.gif[/img], & a 1981 26' Prowler TT(26Y)
Larry M is offline
Old 07-21-2002, 07:15 PM   #4 (permalink)
Compudoc, Go here
http://www.innovative-truck-products.com/
Next,click on products to the left side of the page,scroll down until you see Powerstroke diesel exhaust systems,click on this,click on details under the Magnaflow Stainless Steel Exhaust systems.
Scroll to bottom of this page until you see Magnaflow start and idle sound and magnaflow driveby sound. The letters will be in red.
My van sounds just like these wave files. [img]/ubbthreads/images/icons/cool.gif[/img]
04 Jeep Rubicon
Aceman is offline
Old 07-21-2002, 07:48 PM   #5 (permalink)
Larry,he will be removing the stock upper downpipe flange and Magnaflow upper downpipe flange and will weld the stock flange to the upper portion to the Magnaflow downpipe. He will have to weld it on perfectly so the downpipe has no clearance problems and lines up with the straight pipe perfectly.
He'll probably tack it first then test fit it to see how it lines up,then finish welding it up.
I wonder how much more my temps will go down &amp; how much more performance I'll see. [img]/ubbthreads/images/icons/grin.gif[/img]
I'll see if I can take some pics of the fabrication to see where the flange ends up being welded onto the downpipe for everyones benefit.
04 Jeep Rubicon
Aceman is offline
Old 07-23-2002, 12:30 PM   #6 (permalink)
VISIONQUEST's Avatar
question , does your van sound to loud ? 2 could you give us the part numbers of the eqip that you actully ordered &amp; installed, and did this improve h power. 4 do you have a g tech you use in testing ?
4x4 quigley 2001 e350 psd 3.55 posi front & rear/ insulated fully/ all power/ 4flex steel 6 way heated/rear removeable leather captain chairs / carbon fiber dash cover/ 2000watt rockford fosgate sound system system12 speakers/scmt/magna flow complete from turbo back/carbon fiber gauges auto meter trans,boost,exaust pre/isspro tack/crime stopper alarm remote start stop /towing package/
Custom Pro Built Trans steel planets tripple disc Red Eagle discs hardend input & drive drum /
W/A Intercooler... SIngle shot stage 2
2001 E350 4.10 all stock cargo 140k
VISIONQUEST is offline
Old 07-23-2002, 02:17 PM   #7 (permalink)
sixiron's Avatar
My Photos: (11)
Ditto: share the part # 's so us moron's will know what to order when we get the cash saved to order the system....I want to talk to FPS in douglasville, Ga about the 31/2 inch downpipe flange weld/swap and I would like to know the part information on the exh system...my .02 bill
2002 E-350 ext. cargo..4" DP+exhaust/gauges/ CCV mod/ AIH delete/TT mirrors wC-btr's/Racor prepump/ITP regulated return w/fuel bowl delete/tank mods/203*/timbrens/bilstein/Hella/ DP tuned/BTS trans/ alum baja wheels/cryo rotors...dyno 335 hp...308,272 miles
04 VW TDI/PD Jetta wagon
TT bushings, Koni'sEuro HID's,tint,
cat 2 mic f/filter,CCV/muffler/fuel filler mods,skidplate, RC1+
sixiron is offline
Old 07-23-2002, 08:30 PM   #8 (permalink)
VISIONQUEST &amp; Sixiron,my van is a "little" louder "now" than the 2 Dynomax 3 1/2" Race Magnum mufflers I had installed on my stock pipes but there is "no" drone on my van.
You could also install 2 magnaflow mufflers if you want it quieter.
The part number of the Magnaflow 4" S.S. tuner series exhaust system which includes the new-style 2 piece downpipe and everything needed for the installation (except downpipe fabrication) is # 15915 for the extended vans and # 15919 for the std. length vans.
Seat of the pants feeling is that I picked up some hp.
Egt reduction is 100 degrees.
My 1/4 mile speed (9000lb van) with the Dynomax mufflers,chip and propane was 16.2seconds @ 89.5 mph according to my Gtech Pro meter.
I tested the 1/4 mile speed today and saw 15.8seconds @ 92.0 mph so it is a little faster (and also sounds really cooool)! [img]/ubbthreads/images/icons/grin.gif[/img] [img]/ubbthreads/images/icons/grin.gif[/img]
Not bad for a work van,huh? [img]/ubbthreads/images/icons/wink.gif[/img]
I really need to have a custom chip made for me especially with the propane so that is the next step.
Diablo has a new flip chip available but I will probably try the TS performance chip as Dennis is a great programmer and might give me a better deal than what I'am currently getting for the Diablo. (right Dennis [img]/ubbthreads/images/icons/wink.gif[/img] ).
04 Jeep Rubicon
Aceman is offline
Old 07-24-2002, 03:26 PM   #9 (permalink)
gos
My Photos: (22)
Aceman,
I think you can get by with the 15919 which is for a Super Cab long or short wheel base. JS.
Jerry Schmidt, GOS Performance 1-800-620-4467, Wholesale Distributors for aFe,ATS,Autometer,Banks,Bullydog,CompuStar Remote Starts,Diamond Eye,DiPricol Gauges,Glacier Pumps,High Tech Turbos,Hughes,Industrial Injection,Edge Products,Mag Hytec,Magnaflow,MBRP,Pac Brake,Pro Parts,RevTek Lift Kits,KC HiLites,RCD,Rapid Hitch,Snow Performance,South Bend Clutch, Superchips, Superlift,Weather Tech
2005 Harley Davidson F350 #226 in True Blue
GOS Racings APC PT Cruiser
gos is offline
Old 09-01-2009, 11:04 PM   #10 (permalink)
ok who dug this up ????????????? lol wow flash back i think we all got the magna,s
