installing these accessories - Diesel Forum - TheDieselStop.com
Old 03-06-2007, 06:49 PM   #1 (permalink)
My Photos: (15)
I contacted Bob at Dieselsite about the these products and he was not familiar with installing them on a van. Do you see any problems with these going onto a 1998 7.3? Also if you know of any links or tips on the installation that would be a big help. These products may be made for a truck, I don't know.
Dieselsite coolant filtration system. Bob thought someone had done this on a van and put it under the bumper.
Dieselsite AC control valve
Dieselsite transmission filter kit. (has spin on filter)
Dieselsite dual bypass oil filter kit ( same as Amsoil filter kit with Dieselsite mounting brackets )
4wd deep transmission pan
V10 gasser trans cooler
Amsoil synthetic oil and trans fluid.
fuzzy dice [img]/ubbthreads/images/graemlins/smile.gif[/img]
Thanks !
1998.5 E350 7.3 extended cargo with Late model doors ,po.wer windows, locks and mirrors.Isspro gauges from DPPI, Power Slot Cryo rotors from DPPI, Hawk LTS from DPPI,NAPA DOT 4 brake fluid,NAPA calipers,Evans coolant,Dieselsite ac control valve,Dieselsite 203* thermostat,BTS valve body, Amsoil tranny fluid,4WD deep tranny pan from Dieselsite, DieselSite transmission bypass filter,Amsoil dual oil filter, Amsoil 15-40 wt oil,4 inch Warpspeed Performance exhaust,Thermo-Tec Exhaust Insulating Wrap, Bilstein shocks,Line-X 2-06-2009 103,400 miles following added Beans stage II single shot injectors, Air Dog, Beans regulated fuel return with fuel bowl delete, glow plugs and Stancor gp relay, Beans modified IDM, Stealth HPOP stage I, Dominator 66 turbo, DpTuner reflashed factory pcm that was split shot injectors to the single shots, 9 tunes from DP Tuner including decel tune,tuflocs on all doors, Snow water-methanol injection stage 3 installed by Beans Diesel, BTS tranny
mtnbiktn is offline
Old 03-06-2007, 10:05 PM   #2 (permalink)
sixiron's Avatar
My Photos: (11)
Re: installing these accessories
You are on track AFAIK.......
I have been using :
Double bypass oil system
secondard fuel filter
4WD tranny pan
coolant filter
syn oil/fluids
Larger trans cooler
no comment on the fuzzy dice
BUT
do open up(go bigger) on the exhaust
and get gauges....pyro...trans temp...boost
my .02....bill
2002 E-350 ext. cargo..4" DP+exhaust/gauges/ CCV mod/ AIH delete/TT mirrors wC-btr's/Racor prepump/ITP regulated return w/fuel bowl delete/tank mods/203*/timbrens/bilstein/Hella/ DP tuned/BTS trans/ alum baja wheels/cryo rotors...dyno 335 hp...308,272 miles
04 VW TDI/PD Jetta wagon
TT bushings, Koni'sEuro HID's,tint,
cat 2 mic f/filter,CCV/muffler/fuel filler mods,skidplate, RC1+
sixiron is offline
Old 03-07-2007, 02:05 AM   #3 (permalink)
BlizzardVan's Avatar
My Photos: (18)
Ac control valve...check... froze my nuts off last July with the AC on
Deep trans pan...check...works fine just get the 4wd filter for that pan
If your paying for the bypass you might as well put in the good stuff
Trans cooler from summit works I don't see why a v10 gas unit wouldn't work?
Hypermax stage 2 injectors, 4" intake with Ram scoupe, QSSB Turbo, Snow Meth inj, BTS trans no spacer, Salem Kroger 4x4, Sway and traction bars, APX drivers seat, 4" straight exhaust & DP, 4" lift, 18" wheels with 325 nittos, custom valve Bilsteins, DP PCM and F5
...Stuff to make it almost as fast as a pickup.
BlizzardVan is offline
Old 03-07-2007, 11:19 AM   #4 (permalink)
My Photos: (10)
As stated in above posts.
Vannis are on their own. You can get kits for most things and mod it for the van.
Heck! My exhaust system is from a f-series modded, due to back then no one made an exhaust for it. (97)
Modded fuzzy dice into a smelly tree!!! [img]/ubbthreads/images/graemlins/grin.gif[/img]
Bill
MADVAN is offline
Old 03-07-2007, 11:28 AM   #5 (permalink)
My Photos: (9)
Thanks !
I have the Coolant and Trans filters on my van installed under my front bumper (helps to have a larger bumper for protection as well as leftover bumper brackets from prior installations). Also an Amsoil Dual-Gard under the driver's door (this is not the Dual-Remote, however). I think I have PICS of them below, but I need to update the set with more current versions.
(No fuzzy dice either.)
2001 E350 PSD, Deep Emerald Green, 3.55 LS, Premium package, dual alts, rear A/C. Quigley 4x4, Transfer Flow rear tank (27+26), handicap mods, custom interior, Reunel tire carrier w/ Hi-Lift, Sportsmobile nerf bars (black), Amsoil lubes and Dual-Gard bypass oil filter, Amsoil air filters, Eclipse/JL Audio sound system w/ Sirius & 120GB Neo Car Jukebox (MP3 player), J&J stainless grill, Reunel Stainless bumper, 12000# Warn winch, PIAA lights, Bilstein shocks, Ultra Magnum wheels, Michelin tires (265/75-16), Correctrack rear wheel spacers, Bushwhacker flares (painted), Velvet-Ride spring shackles, p/s filter, external tranny and coolant filters, Autometer gauges(5), Optima Yellow Tops, Airdog.
msnunes is offline
Old 03-08-2007, 10:40 AM   #6 (permalink)
My filter coolant filter hangs from drip gutter where vacuum hoses attach to manifold, just to the left of master-cylinder. I can take pics if you are interested.
1999 E350 7.3psd , XLT , 15 pass/ext , purchased 6/6/05 w/255k on odo, 8/05 added BTM/straight pipe,5/06 BTS,1"shimmed front coil springs,Michelin XPS 235/85 16 R.,FredGroeske2"rear wheel spacers,1-1/2" rear sway bar,AIC,3 A-pillar guages, Tekonsha envoy,coolant filter,4 pos dp-tuner,In-tank mod & harpooned,dahl-100 prepumpfilter,Scan-guage,Bilstein shocks.
bork is offline
Old 03-08-2007, 02:14 PM   #7 (permalink)
My Photos: (15)
Thanks !! Pics would be good. I have a standard size chrome bumper so I don't know if it will fit behind it or not. The more choices the better.
mtnbiktn is offline
Old 03-09-2007, 06:25 PM   #8 (permalink)
pic's here http://photos.thedieselstop.com/show...hp?photo=31444
and http://photos.thedieselstop.com/show...hp?photo=31443
and lastly http://photos.thedieselstop.com/show...hp?photo=31442
hope these help. And one more thing to consider, when I change canister, I dont have to worry about shuting off any valves, losing coolant, cause its so high.(doing it cold of course)
bork is offline
Old 03-09-2007, 08:23 PM   #9 (permalink)
My Photos: (15)
Thanks for the pictures. They sure help !!!!!
mtnbiktn is offline
