I Have An 05 E350 I Tow About 11000 Pounds With It. I Have About 50,000 Miles On It Half Or More Towing. On My Last Trip It Lost Power It Was All Up Hill. At The Top Of The Last Cople Grades It Dropped Down To About 40 A Little Slower Than Usaul But Aceptable The Problem Was When I Flatined Out It Had No Power Couldn't Get It Over 45 On Flat Ground. Then The Last Grade At The Top It Missed A Shift. And Had No Power. I Pulled Over And Sat For About A Half Hour. A Couple More Small Grades Left And It Still Didn't Pull Well. Once I Got Through The Grades It Took A While To Get Back Up To Speed. The Rest Of The Trip No Problems. I Know I Need Gaudges But Not In The Budget Yet. Is There A Limp Mode If The Tranny Gets To Hot? The Check Engine Light Never Came On. I Have A 1000 Mile Trip Next Month And A Little Nervice About It. Van Is Stock Except Modified Air Box And Body Lift.
Fuel filter and air filter check, did the van make any noises? Air Sucking or anything?
Check the Turbo Bolts, make sure they are not loose.
Towing the tranny will get extra hot. Change your tranny fluid, and install the Sonnax valve & Tricumulator springs while your at it. It helps with shifting.
I installed a Mag-Hytec Tranny Pan and it adds 2 extra gallons of fluid to your system.
I have Amsoil Synthetic Fluid, you can use mobil 1 Synthetic Fluid if you want to switch to synthetics.
You need to get rid of the stock muffler, you can go cheap and install a Walker Big truck muffler and it will open up the system for you. Or install a complete new exhaust. The Pyro & Tranny Guage are the important ones to get, Boost is cool but not as importnt as the other 2.
And last is a Tuner for your engne, I have the Superchips and run it on the 60 HP Tow setting for driving around (Not Towing). Jody at DP Tuners has a great tow Program for the van that will keep the temps down and give you power. Guages are important but if you don't drive crazy you can get away with it for a trip or 2. Just be careful going uphills, don't push it hard.
For me the important things in order are,
1. new muffler (Straight-through type)
2. DP Tuner or Superchips 1705
3. Guages
4. Deep Tranny pan w/ Sonnax & Synthetics
5. extra tranny cooler inline with the original, have two.
And do you have the 3.55 or the 4.10 rear end?
2000, E-350, SuperDuty, Explorer Extended LivingRoom, 7.3L PSD. 3:55 LS Rear, SuperChips 1705, Dual K&N's, FleetGuard WF-2077 Coolant Filter, AutoMeter Phantom Guages - Pyro, Boost, Tranny & Hobbs Hour Meter, 4" SS MagnaFlow Turbo Back Completely Wrapped with Thermo-Tec 2" Header Tape, Sonnax Valve & Tricumulator Shift Springs, Mag-Hytec Tranny & Dana 60 Cover, One-Up Front Spring Option, Bilstein's, Centramatic's, 35 Gallon Main Fuel Tank & Trax II TransferFlow 27 Gallon Aft. Aux. Fuel Tank = 62 Gallon Range, ACPM/AIC, Dual Battery & Dual Alt, FilterMAG, Fumoto, Amsoil Tranny & Rear End, Alcoa's, 4 Leather Captain Chairs w/ Back Bench Seat/Bed, Inflatable Aerobed, 20" LCD TV Overhead, DVD, VCR, KVH TrackVision, SAT/NAV, Walnut Cabinets & Trim, 3000 Watt Sine Wave Power Inverter, BioVault 2.0 Gun Safe, 2xDIN Pioneer DVD Head w/Backup & Side Cameras, 5 Channel Surround Sound System, PowerTank, 12 Volt Refrigerator, RainX Wiper Blades, 3M Rubberized Undercoating, Bob's AC Valve, H3R
the air filter was fresh i'll need to do the fuel filter. it did not make any noise. i will check the turbo bolts out. i'm planning on putting amsoil in all the way around, and a cat back on it befor the trip. i've heard about the Walker Big truck muffler i might look into that. the tranny pan sounds great i'll have to look into that. i'd like to run a tuner but still have 50k of warrenty left so i'm afraid to do much to it.
Yes. At 250 degrees the tranny settles into second gear and won't budge. You might consider checking the cooler for blockage, and give the fluid the sniff test. Mercon has a slightly wierd smell, but you should know if it's burnt.
If it is, replace the filter and change the fluid.
2005 E350 Standard Cargo Van, 6.0 PSD, 4.10 L.S., Quigley 4X4 New on 11-18-05
(seems to manufacture oil....1 Qt per 4000 miles)
Warranty Turbo 7-07 22,000 miles
Warranty A/C compressor 10-07 25000 miles
2003 E350 Extended Cargo Van, 7.3 PSD, 3.55, Quigley 4X4 New on 2-1-04 Some Pix
Transfer Flow 46 Gal.***Delaminated***Replaced 8-29-06 UNDER WARRANTEE
XM Radio, Alpine GPS Nav. System 7.5' Western Snow Plow
Quad Captain's chairs and Espar Furnace
OX cable locker on front
ARB locker on rear
BTS Tranny 9-29-07 @55,000 miles
Aluminess Bumpers
Mile Marker 12,000 pound hydraulic winch
That is stage 1. But you can use 1st if you shift manually.
If the temperature continues to climb, engine power will then be reduced to about 50%. At least on the V10s.
That happened to me only once. 24,000 combined up a 12% grade. I got stuck behind a bus, and the slower speed really made the trans heat up (almost no airflow at 20 mph). I also did not think to remove my grill insert before starting the climb, and that insert blocked about 50% of the air.
i bought the walker muffler today at napa i told them the internet price i found and they matched it 65.00 otd
i do believe the problem is heat in the tranny i think i'm going to have it flushed with new oem oil still worried about warinty i'm hoping to get away with the larger pan. what filters should i go with and how many on the tranny should i just stick with all oem?? are there better fuel filters? i am going amsoil on the motor. what sould i do in the rear end? oh yeah i just have the 3.55s wish i had the 3.73s
thanks for the help
A larger cooler will do much more for the heat problem than a larger pan, and probably cost less. A larger pan will make it take a little longer for the fluid to heat up, but it won't really dissipate heat any better. As long as you use the right replacement cooler, you won't affect the warranty (NOTE: using a finned tube cooler will void the transmission warranty... Ford says not to use those).
For rear axle gear oil... Don't bother... It's good for life for normal use or 150,000 under extreme use.
thanks looks like a great site and there only about 2 hours from me and the next town over from where my van was conveted
i'm putting on the walker muffler tonight
thanks i'm going to pick up the b&m cooler and external fiter and all other filters from the site van 350sd posted. then have it flushed with new oem oil and change it a little sonner next time
You are really pushing the limits for the rear end that you have in the van.
I would bet that you have gotten the turbo hotter than hell and ditto for the transmission.
However, your transmission cooler mode should have kicked in with the fan coming on full blast when the tranny temp got high enough to kick it in. You would have known it for sure.......sounds like a jet engine revving up in your engine compartment.
Don't forget to do the smell test that was described earlier before you change transmission fluid. If your transmission fluid smells like it has been burned you might ask one of the transmission guru's around here, like Mark, if they have any recommendations.
If you are going to pull that much weight, you really do need a tranny temp gauge and an exhaust gas temp gauge. Rmember, our vans don't have intercoolers to help cool the turbo.
Open up your exhaust and your air intake and add an aftermarket tranny cooler once you've decided that your tranny is still OK.
it doesn't matter which oil you use as long as it meets specs. I use Rotella in the crankcase and Pennzoil (as I recall) in the tranny.
If you keep pulling that 11K trailer, change your rear end oil at 80K or thereabouts.......read about it on this web site.
I have Amsoil Synthetic in the tranny and the rear end.
I also installed the Mag-Hytec Tranny & rear end covers on my van.
The stock rear end cover and rear end hold just under 3 quarts.
With the Mag-HyTec Rear End Cover it's 6 Quarts, 3 extra Quarts.
it's well worth it for me to install this for my van.
the rear end cover also has a sending unit port so you can install a guage for your rear end.
if your towing that much weight, it may be worth the investment.
i got the walker btm on i love it it seems to have made my motor quieter when you get on it it sounds nice. i cut the old pipe out of the cat and replaced it with 4" i just put a turn down right in front of the axle for now i have maneral bends on the way to get it out the back. i orderd the B&m 70297 Tranny Cooler With A Fan That Comes On At 175 It Is A Fin And Plate Desing and a magnifine filter. my fluid still looks and smells fine. i will have it flushed in a couple weeks. i also have piller mount gadges on the way. i have a short tow this weekend 150 miles so i'll see if everything is good.
the first time i towed with it and the fan came on i thought i blow somthing up my friend that was folowing me with his powerstroke started laughfing at me when i pulled over
