metric wrenches or - Diesel Forum - TheDieselStop.com
Old 08-29-2005, 09:35 AM   #1 (permalink)
metric wrenches or
I have not done much work on van yet but when changing out under battery it seems frame bolts were metric . my build date is 10/98. How much is which ? do I need to carry both sets of wrenches ?
1999 E350 7.3psd , XLT , 15 pass/ext , purchased 6/6/05 w/255k on odo, 8/05 added BTM/straight pipe,5/06 BTS,1"shimmed front coil springs,Michelin XPS 235/85 16 R.,FredGroeske2"rear wheel spacers,1-1/2" rear sway bar,AIC,3 A-pillar guages, Tekonsha envoy,coolant filter,4 pos dp-tuner,In-tank mod & harpooned,dahl-100 prepumpfilter,Scan-guage,Bilstein shocks.
bork is offline
Old 08-29-2005, 11:41 AM   #2 (permalink)
Re: metric wrenches or
I have a good sized set of standard and metric sockets (1/4", 3/8 and 1/2 ratchets), standard wrenches fom teeeninnny up to 1 1/8" with a few various metrics tossed in the box. I also cary a set of screwdrivers same as the wrenches (tiny to HUGE). If you have room for one of those orange "Homer" tool boxes (or equivelant size) to stay in the van somewhere, you would be amazed at how much you can jam into one of the fairly small sized tool boxes available.
I never thought I would need a giant philips head until I broke my filter wrench while changing the oil at an rv park long after the local auto parts store closed (just hammered the screwdriver through the filter and twisted it loose that way).
To make a short story long [img]/ubbthreads/images/graemlins/smile.gif[/img] carry as much as you comfortably can of both metric and standard. It can save headaches in the future.
Man, I even have a rubber mallett and a framing hammer in it that I had to use last week on the trailer I pull (why would any idiot cary a framing hammer and rubber mallett with them???? [img]/ubbthreads/images/graemlins/laugh.gif[/img] )
99 7.3L PS E-350XLSD with Ambulatory roof.
(((XM))) Satellite Radio
4" turbo back Diamond Eye exhaust (portadiesel)
Pair of K&N High flow filters
HPX Hose from D.I. (blew out.....pulled it and plugged now)
In-tank and prepump mods (homemade version)
203* thermostat (dieselsite)
Tru-Cool 4739 MAX Transmission cooler (dieselsite)
Boost Relief Valve (dieselsite)
Pillar mount Di-Pricol gauge set
Sonax/tricumulator (Black Cloud)
Jody flashed econo tune PCM (DP-Tuner)
Van specific regulated fuel return (ITP)
70k miles driven annually...mostly pulling 8 1/2 foot tall 7x14 enclosed trailer
Cruise on at 61mph and 1736rpm's I don't stop 'till she needs more go juice!
stroked_van is offline
Old 08-29-2005, 01:57 PM   #3 (permalink)
Hahaha, I was hoping to get away from hitching up to the roll-out cabinate full !
bork is offline
Old 09-06-2005, 06:57 PM   #4 (permalink)
After a fair bit of work it appears that there is a nice mixture of SAE and metric on my van (2005), requiring a full set of wrenches & sockets in both to be carried along. The biggest irritation is finding a wrench that almost fits, but not quite and then having to go find the nearest matching size in the other system.
-Erik
www.badgertrek.com Badgers on wheels...
etbadger is offline
