What are you guys with high power (80hp and up) chip programs doing about the check engine light coming on from overboost? I've seen three "fixes" for it so far. One is a wire that grounds something on the MAP sensor, one is some diode trick that I've heard some not so good things about, and the last is a mechanical regulator to alter the boost to the MAP. All of these were for wastegated F series though, so I'm curious what my fellow van guys are doing about it. I've got a 4 program WD chip now, and it's setting the MIL at WOT. Thanks!
Sal
2005 E350 Extended 6.0 Power Stroke Van
Torqueshift 5 speed, 4.10 limited slip, Club Wagon headlights, PSP custom tune, 13.90 ET
2002 E350 Extended 7.3 Power Stroke Van (SOLD)
Power Surge Performance chip, digital dash mounted EGT, twin K&N filters, full 4" exhaust, Factory Tech Valve Body, 4x4 trans pan, Club Wagon Headlamps, 15.83 1/4 mile.
Sal,I'am using the turbo boost relief valve that came with my PS2000 propane injection kit.
I very rarely set off the ses light with it installed.
Bob Riley sells these valves and can bee seen here: http://www.dieselsitetoo.com/product...1=218&3=61
It works great! [img]/ubbthreads/images/graemlins/smokin.gif[/img]
2000 E-350 Van,BTS Tranny,Custom Dana 80 Axle w/ ARB & 3:55 Gears, Swamp 175cc Injectors, Custom 4 Position Chip,TS Billet Intakes,W/Wheel,PS2000,Magnaflow 4" Exhaust,ITP Fuel Regulator,4 gauge pillar post,TTM,CTI Idle Controller,Amsoil Fluids,Evans,203 Thermostat,Coolant Filter,J&J S.S. Grill,Art Rotors,Custom Flame Job,Road Armor Bumper,Warn M15000 Winch,Bushwacker Flares,Bilstein Shocks,Centerlines,Maghytec Covers. dynoed at 345.5 rwhp
FUTURE MODS: Upgraded turbo, HD oil pump,Intercooler with water injection.
04 Jeep Rubicon
RE 5.5" Long Arm Lift,1"body/eng.lift,Banks Header/ Exhaust,37" IROKS,Mickey Thomson Classic 2 beadlocks,Road Armor Bumpers,Warn 9500TI winch,Alloy Usa axleshafts,CTM u-joints,Nth degree oil pan skid,Clayton front high clearance brackets,Toys by Troy crossover steering,Poison Spyder Rock Sliders.
im looking for receipt were i bought mine save yourself the headache
dont use the 24 psi mapsensor blowoff get the adjustable one i went through 2 of the set ones they dont work half the time light comes on and computer starts defueling, computer takes along time of driving for it to regroup after light goes off. i purchased the adjustable one and works great you basicly turn the nob and let just enough boosted air go in map sensor so light dosnt come on it takes all of 3 times to get it right also you can let a min air go in and shifting and boost level changes
4x4 quigley 2001 e350 psd 3.55 posi front & rear/ insulated fully/ all power/ 4flex steel 6 way heated/rear removeable leather captain chairs / carbon fiber dash cover/ 2000watt rockford fosgate sound system system12 speakers/scmt/magna flow complete from turbo back/carbon fiber gauges auto meter trans,boost,exaust pre/isspro tack/crime stopper alarm remote start stop /towing package/
Custom Pro Built Trans steel planets tripple disc Red Eagle discs hardend input & drive drum /
W/A Intercooler... SIngle shot stage 2
These may prevent the SES/defuel problem, but you're still overboosting the engine and exceeding what the turbo charger is designed for from my understanding. Also, I would think if you're dumping boost to the MAP sensor you now have a useless boost gauge to determine actual boost to the engine if it is tied into the Map sensor line after the dump valve. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Just something to think about [img]/ubbthreads/images/graemlins/wink.gif[/img]
Larry
__________________ <font color="green">MY PICTURES - Look around ... lots of good stuff </font>
2001PSD(PCM:HPI2)SD E-350,Dk Emerald Grn,4.10LS, <font color="blue">Mustang dyno - 183.9/400.4 stock</font> [img]/ubbthreads/images/graemlins/smile.gif[/img], BTS w/Schaeffer's ATF[img]/ubbthreads/images/graemlins/biggrin.gif[/img] , ITP 3.5"/4" exhaust w/Magnaflow & Aeroturbine,Dieselsite 203* T-stat/Zerex G-05,F.Pwr, Ext/Int. Upgd. pkg,R. Bds,AIC,Tow Pkg, Rear & Slider windows,<font color="red">AMSOIL air, oil-bypass & rear end 75w-140 fluid ,<font color="blue">3/8" fuel sys w/10µ Dieselsite DAHL100 & fuel manifold/sight glass</font>,6 way dr. pwr. seat, Magnefine trans/P.S. filters</font>, husky mats,<font color="red">5 gauge A-pillar ISSPRO EVs w/Grn mkr illum. + air & fuel restriction gauges</font>,Dieselsite coolant filter and zinc electrode, manual GPR switch & GP LED, blinking security LED, weathertechs, a few other "Gadgets" [img]/ubbthreads/images/graemlins/smile.gif[/img], & a 1981 26' Prowler TT(26Y)
Larry,your right about exceeding the limits of the stock turbo by overboosting. [img]/ubbthreads/images/graemlins/smile.gif[/img]
However,my boost gauge is accurate with the PS2000 boost relief valve installed. [img]/ubbthreads/images/graemlins/wink.gif[/img] The valve will allow my boost gauge to read properly,it only fools the map sensor into seeing less boost to prevent the dreaded ses light and defueling to ocurr. [img]/ubbthreads/images/graemlins/wink.gif[/img]
Brian at BTS stated that he has seen "many" trucks producing over 30lbs of boost "daily" and the stock turbo was holding together with zero problems with many trucks over 150,000 miles of abuse. [img]/ubbthreads/images/graemlins/eek.gif[/img] However,I'am sure the life expectency will be diminished over the following years with overboosting situations (you play you pay!) [img]/ubbthreads/images/graemlins/wink.gif[/img]
I see about 35lbs of boost almost every day when playing around and my turbo was in excellent condition when it was inspected while installing the Wicked Wheel. This was at around 82,000 miles or so.
Just don't exceed the 40lb limit as this is when the head gaskets will blow. [img]/ubbthreads/images/graemlins/eek.gif[/img]
You could also install the H2E or new ATS ball bearing turbo if you want an invincible turbo. I'll stick with my stock van turbo and Wicked Wheel. Treat you turbo with respect as it relates to proper cool down time,etc. and it should last a long life. [img]/ubbthreads/images/graemlins/smile.gif[/img]
I'am not worrying about my overboosting situation. [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Can't wait for this years rally! [img]/ubbthreads/images/graemlins/biggrin.gif[/img] See you there! [img]/ubbthreads/images/graemlins/smokin.gif[/img]
04 Jeep Rubicon
Great points and can add nothing [img]/ubbthreads/images/graemlins/grin.gif[/img] ... and ... see you there this year [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Larry
Thanks for the replies guys. I think the mechanical regulator idea is what I'm going to do, BUT, here is another questions based off that..
If you put a mechanical bleed on the MAP line, that cuts the boost to the MAP, which stops the PCM from seeing too much boost and setting the MIL, but doesn't that also stop the PCM from adding the proper fuel? At the point you limit the boost reading too, the PCM will no longer see the increase in pressure, so it will stop adding fuel at that point, but you are continuing to add air. It's like a MAF on a gas motor. It reads from 0-5 volts, and if you peg the MAF at 5 volts, the PCM can't read anymore air coming in. I really don't know if this is an issue on the PSDs, as my chip tuning skills are for gas motors, but I had to ask [img]/ubbthreads/images/graemlins/smile.gif[/img].
Sal
I installed the regulator on the MAP line today. I didn't even have to buy one, because I realized I had one on my Eastwood powdercoating gun that I don't use anymore. I set it at 24psi. Is that the proper "blow off" setting that everyone agrees on? Does anyone know what the actual boost limit is that makes the PCM set an overboost code?
Sal
Sal,the dreaded ses light will turn on at 25 lbs of boost so your correct in setting the regulator to 24 lbs.
Have fun. [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
04 Jeep Rubicon
