misfire, check engine light, but no code? - Diesel Forum - TheDieselStop.com
Old 06-29-2009, 05:27 PM   #1 (permalink)
Trying to accelerate onto the highway, the 2001 with 220,000 on it had a little trouble. 8 ppl in the van, a 3000 lb trailer in tow, she drives fine on the highway, but climbing up hills and getting going from slow speeds it does what I think is a misfire and the check engine light comes on, however it doesn't reappear when I shut the van off and restart. I bought a $60 reader but it doesnt show a code.
The van was fine for two days when I was being very careful to be light on the throttle, thinking it might be a transmission problem.
It showed the same problem again today when I was coasting down a hill, gave it gas, it studdered and sounded like it missed and ses light came on.
NO CODE THOUGH STILL!?! I changed the fuel filter yesterday. Tranny fluid smells fine and is full.
CPS was not changed on this van b/c when I took it to ford a year ago to have it replaced, they said the vin # didn't require a recall. Could it be the valve cover harness? possibly an injector?
any thoughts would be great. Thanks guys.
Andy
1999 E-350 7.3L 7 Passenger chateau. 145000. No mods. 3.55 LS rear end.
2000 E-350 7.3L Extended 15 passenger. 125,000 Just added her to the family.
2001 E-350 XL 7.3L 12 passenger. 194000. 4.10 rear end. Replaced rear end @ 160,000. most recent repair: replaced 4 cracked injector sleeves.
Greenvans is offline
Old 06-29-2009, 06:01 PM   #2 (permalink)
blageurt's Avatar
I think you need a better code reader than the one you have. I also think it is a UVC connector which is either shorting out or not making good contact. Get it scanned with a good scanner and see what is there.
95 E350 PSD HD Cargo , BB shim , E4OD , B&M aluminium Trans pan , Twin HD coolers , Cat sleeps with the fishes , 3:55 D70FF, Michelin LTX " E " , DP flashed 60 Tow , 140 V idm , Autometer Triple Pillar Guage pod , New Injector O-rings /IPR /lift pump / filterbowl @ 235K , Timbrens SES kit , replaced lift pump /ICP/ IDM @ 256 K
1977 F350 Dually Dump , 460 , 429 POLICE heads , 4:56 D70FF, Edelbrock Intake , Holley 850 dbl pmper ,MSD IGN , Custom HiPo C-6 Trans , Dual Exhausts , Bridgestone "E" Tires
1983 KZ1000R , Yoshimura Stage I
1982 KZ1000 , 1045 Wiseco , Turbo ready
1990 KX500
blageurt is online now
Old 06-29-2009, 07:54 PM   #3 (permalink)
Ill check that out. Also, yesterday I tried to replicate the problem so I could read the code. I dropped the trailer and the passengers and drove it pretty hard.... Getting on the highway and accelerating hard from stop. It drove fine. And no code. Had the misfre/studder today towing a full load
Old 06-29-2009, 08:42 PM   #4 (permalink)
Your scanner is definitely not retrieving the codes. If the SES lights, that means a code is stored in the pcm. With your fleet, I would definitely suggest to invest in Autoenginuty. You will need to add the ford bundle.
2003 E-350 7.3, 38R, DIY intake, 4" turbo back, Swamps Tunes, forged rods, exhaust ported heads, comp 910's, h-11's, stealth twin pumps, 300cc hybrids, racerx trans and tc, water injection
rpm1 is offline
Old 06-30-2009, 01:56 PM   #5 (permalink)
Got the codes:
p0344: CPS Going to get that replaced now.
p0381: Glow plug/heater indicator circuit malfunction
p0470 exhaust pressure sensor circuit malfunction
P0 470 is the one that concerns mean.... any thoughts on that one?
-Andy
Old 06-30-2009, 03:32 PM   #6 (permalink)
Originally Posted by Greenvans View Post
Got the codes:
-Andy
Maybe check to see if the tube that goes from the exhaust pressure sensor to the pass side manifold is clogged or broken. It is common for them to become clogged with soot. Maybe this is causing the ebpv to close and that would definitely cause a huge loss of power.
rpm1 is offline
Old 07-03-2009, 05:25 PM   #7 (permalink)
anybody know where I can get a new exhaust back pressure sensor besides ford?
Old 07-03-2009, 05:34 PM   #8 (permalink)
blageurt's Avatar
search ebay motors under "Ford Diesel" there are a few in there today. OEM too !
1990 KX500
