Well, I sent my ScanGuage in for the upgrade to X-Guage. Today I drove the van to work - I actually had to watch the road! Sure hope my foot remembered what to do to get up to 20+ mpg on the road.
Seriously, I'm looking forward to the trans temp and the ability to list trip parameters in the Guage screen
Mike
D70 Full floating rear axle from a cutaway van
140A Alternator. 125W solar panel. Sportsmobile off-road trailer.
96,258 miles. 16.63 mpg average
From Cal to Alaska, Key West, Labrador/Newfoundland and points in between
05 F350 front axle and aluminum wheels 275/70-18 tires.
46 Gal tank - harpooned pump vent tube.
Scangauge. DieselSite Coolant Filter@72K. Fumoto valve. Amsoil dual remote oil filter setup.
176 days in the shop - not counting the 4wd conversion time - Replaced front springs, 2 injectors, Trans housing, 3rd gear, Reverse planetary assy, Turbo, Alternator, another Alternator, Turbo hose fitting, Block Heater, Door lock, Front axle seals - all under warranty. AC hose, 1 injector, Batteries not under warranty.
Mike
I know what you mean. I've had my XGauge for 3 weeks now and I love it..got it mainly for the tranny temp but like that I can see 3 other gauges as well.
2004 6.0 E350 Quigley 4x4 w/ Sportsmobile Conversion.
285/75R16 BFG AT/KO. 3.73 Gears.
Dieselsite Coolant Filter.
Aluminess Front/Rear Bumpers.
125W Solar Panel.
Sportsmobile Trailer on 285/75R16 BFG AT/KO tires w/ dual deep cycle marine batteries, water pump, 10 gal water storage, air compressor, storage box & 15W Solar Panel.
Wiring Harness Recall - 15K miles
EGR Valve replaced @ 30K miles
Oil & EGR Coolers replaced @ 62K miles
Tank delamination - Reconditioned by Gas Tank Renu @ 62K miles
Vacuum Pump replaced 69K
SnowMan Mod / Door Seal Mod
Can the scanguage be programmed to display engine coolant tempreature, engine oil temperature and boost pressure on the 6.0 liter diesel? I want to monitor these temperatures while towing my trailer.
Thanks, Steve
'04 F350 CC Lariat, March 2004 build date, 2 tone 6l Auto 18" Wheels, May '07 no buzz flash. Replaced: head gaskets, turbo, VGT actuator, fuel separator(2), EGR valve, EGR cooler, plastic CAC pipes and hoses, MAF, EBP sensor, FICM.
2004 Jayco Eagle 325BHS, 35' 5er, 4 bunks & Queen, 2 slides, 12,500 GVW
Thanks, Steve
I don't think you can get engine oil temp. Trans temp yes, oil temp no.
You can check on the ScanGauge site to find out what you can and cannot display.
Mike
Thanks, I'll give them a call. I want to monitor the coolant temp and oil temp so I can see if my oil cooler is getting clogged up. These two temps should be within 15 degrees and mine got up to 17 degrees when I had a tech scan my truck last month. I have already had the EGR cooler and head gaskets changed 2 years ago. Lately there have been some clogged oil coolers reported and I saw a couple at the dealership on the techs bench and it was scary.
