Old 09-04-2005, 11:48 PM   #1 (permalink)
My PSDs sound different.
Why do my 95 PSDs sound louder than my 97?
At or near idle... not cruise.
It seems like the newer the PSD, the quieter from year to year.
What did they do to make the difference?
I love the sound of the 95s, they just sound the part. Later ones, including my 97 sound wimpy.
Dave
Thomas Jefferson:
"The democracy will cease to exist when
you take away from those who are willing to
work and give to those who would not."
ratio411 is offline
Old 09-05-2005, 02:12 PM   #2 (permalink)
Re: My PSDs sound different.
Do both have stock exhaust and both have cats?
1999 E350 7.3psd , XLT , 15 pass/ext , purchased 6/6/05 w/255k on odo, 8/05 added BTM/straight pipe,5/06 BTS,1"shimmed front coil springs,Michelin XPS 235/85 16 R.,FredGroeske2"rear wheel spacers,1-1/2" rear sway bar,AIC,3 A-pillar guages, Tekonsha envoy,coolant filter,4 pos dp-tuner,In-tank mod & harpooned,dahl-100 prepumpfilter,Scan-guage,Bilstein shocks.
bork is offline
Old 09-05-2005, 02:13 PM   #3 (permalink)
MikeL46's Avatar
My Photos: (13)
I wish that were true! My '04 6.0 PSD is pretty darn loud. When we were in Alaska we were talking to a guy in an '02 7.3 PSD. We couldn't even hear his engine until I turned mine off.
Mike
140A Alternator. 125W solar panel. Sportsmobile off-road trailer.
72,534 miles. 16.49 mpg average
From Cal to Alaska and Key West and points in between
05 F350 front axle and aluminum wheels 275/70-18 tires.
46 Gal tank - harpooned pump vent tube.
Scangauge. DieselSite Coolant Filter@72K. Fumoto vavle.
171 days in the shop - not counting the 4wd conversion time - Replaced front springs, 2 injectors, Trans housing, 3rd gear, Reverse planetary assy, Turbo, Alternator, another Alternator, Turbo hose fitting, Block Heater, Door lock, Front axle seals - all under warranty. AC hose, Batteries not under warranty.
MikeL46 is offline
Old 09-12-2005, 10:23 PM   #4 (permalink)
An airdog will really tame your 6.0 idle noise.
Could the sound level difference between those 7.3 years have anything to do with the injectors? Did they switch vendors? I know they did between the 7.3 and the 6.0. When did they introduce split shots? Your '95 should have single shot injectors.
"Nothing in life is so exhilarating as to be shot at without result." - Sir Winston Churchill
May your road stay clear & dry, may your fuel never gel, and may you never be outsmarted by your idiot lights.
2002 F-250 XLT SC LB 4x4 7.3PSD 6-Sp 3.73 L-S, Snugtop Snuglid Tonneau, 235/85 MC HTRs, <span style="color: red">DPTuner F5</span> AFE Stg II, Turbo LifeSaver, MAP BRV, Autometer Cobalts, Magnaflow 4", WW, TAG, AIH del, CCV, AirDog, In-tank, Harpoon, HPX, ITP fuel sys, LL8 del, 203*, Oilguard & SP Diesel bypass filtration, ART rotors, PFC pads, Heater Core Ctl Valve, Bilsteins, Velvet Ride Shackles, South Bend Clutch, <span style="color: green">21.27 mpg</span>
2004 <span style="color: red">E</span>-350
XLT Wagon 6.0PSD 3.55 L-S TDM EZ-Entry 11 pass., AIC, custom MBRP 4" w/dual Aeroturbines, Airdog, harpoon, Overhead Cobalts
Pictures . . . Parts Links
DarthSurplus is offline
Old 09-14-2005, 05:28 AM   #5 (permalink)
My Photos: (20)
Send a message via ICQ to GraemeDiesel
I have read (but not confirmed) that all 97 vans used california split shot injectors. I know that my 97 van is a lot quieter than my 96 pickup (was even before I straight piped the pickup) [img]/ubbthreads/images/graemlins/grin.gif[/img] I haven't gotten around to checking yet to see if it does use split shot injectors.
2003 F350 SRW Crew Cab 6 liter PSD, Torqushift Transmission, 4x4, 606,000 kms
1996 F250 XL, Powerstroke, Swamp's Baby injectors and TS 3 position chip, Tymar intake and downpipe, 4 inch straightpipe, amsoil engine oil bypass filter, coolant bypass filter, 203 thermostat, chevron synthetic oils front to back, 4x4, 5 Speed, Luk single mass flywheel
382,000 kms
GraemeDiesel is offline
Old 09-14-2005, 05:19 PM   #6 (permalink)
I suppose it could be injectors...
The 95s just seem to rattle really 'hard'...
They have full exhaust.
The 97 has straight pipe back to a 3.5" DynoMax bullet...
It has a really deep exhaust note, but the clatter is no louder.
We put a 95 engine in one of our 97s once. Ford refused to work on it because the 97 computer could not "talk" to the 95 injectors. So there must have been a change. The van ran fine, just Ford refused to do any service work (it was well out of warranty).
Dave
ratio411 is offline
