Originally Posted by bikesandcars
too bad, is there anything that can be done to update your list Larry? It seemed very valuable to the enthusiasts here
I've been trying to update as many of the links as I can, but it's a big job. Lots of them are to the archives which have moved around a bit, but the ones to posts on the active server are still alive, but difficult to reconnect the links.
It's a work in progress. (I'm only partway thru the "C" section)
klhansen
Moderator
99.5 F250 PSD Supercab LB 4x4, ZF-6 w/SB Con OFE, 3.73LS, Boost & pyro gauges, Swamps S175/146 injectors, DP 80 HP Econo PCM (classic version
), AIS,
coolant filter w/"hokum" bracket, regulated return,
heated mirror mod, lighted cupholder, Marinco heater plug-in.
Hard or no-start? Check Here
