No More Bottoming - Diesel Forum - TheDieselStop.com
Old 12-11-2005, 08:00 PM   #1 (permalink)
XRACER's Avatar
No More Bottoming
My '03 Quigley has always been a little quick to bottom out, and with 600 lbs of plow cantilevered out there....fogedaboudit.
The new '05 doesn't seem to have the same problem.
On Wednesday I called Tiger at Quigley and told him about my situation. He compared the build sheets from the two trucks and told me that the '03 has 4200 lb front springs and the '05 has 4600 lb front springs. The new springs arrived at my place on Friday ($198).
The install is as easy as pie and took less than 90 minutes for the pair. Best of all, the bottoming problem seems to be cured.
The new springs are less than 1/2" longer than the old ones, so I'm not overly concerned about making a castor adjustment, and the van tracked perfectly so no alignment seems necessary.
If you have the same problem, I recommend this as the cure.
2005 E350 Standard Cargo Van, 6.0 PSD, 4.10 L.S., Quigley 4X4 New on 11-18-05
(seems to manufacture oil...)
Warranty Turbo 7-07 22,000 miles, Warranty A/C compressor 10-07 25000 miles
2003 E350 Extended Cargo Van, 7.3 PSD, 3.55, Quigley 4X4 New on 2-1-04
Some Pix
New Pix 9-12-2010
Transfer Flow 46 Gal*Delaminated*Replaced 8-06 UNDER WARRANTY
7.5' Western Snow Plow
BTS Tranny 9-29-07 @55,000 miles, Aluminess Bumpers, Mile Marker 12,000 pound hydraulic winch
2000 F250 ...... just cuz people are dumping them for the fuel bill. Got mine on ebay for $8749 with 116K on the clock.
1-1-09 BTS Tranny, 500+ HP at the rear wheel
XRACER is offline
Old 12-12-2005, 08:36 AM   #2 (permalink)
My Photos: (10)
Re: No More Bottoming
You can also install air bags in the spring. I use the air bag and can adjust according to load of the day.
Bill
MADVAN is offline
Old 12-12-2005, 10:21 AM   #3 (permalink)
XRACER's Avatar
By the way, it also seems to have cured the pogo problem that occured whenever I smacked the bump stops hard enough.....
Some Pix
New Pix 9-12-2010
XRACER is offline
Old 12-12-2005, 05:14 PM   #4 (permalink)
So are you saying that we could walk into a dealership and say, 'one set of 2005 E350 front springs, please?' Or would we need to specify the 4600 pound info as well?
"Nothing in life is so exhilarating as to be shot at without result." - Sir Winston Churchill
May your road stay clear & dry, may your fuel never gel, and may you never be outsmarted by your idiot lights.
2002 F-250 XLT SC LB 4x4 7.3PSD 6-Sp 3.73 L-S, Snugtop Snuglid Tonneau, 235/85 MC HTRs, <span style="color: red">DPTuner F5</span> AFE Stg II, Turbo LifeSaver, MAP BRV, Autometer Cobalts, Magnaflow 4", WW, TAG, AIH del, CCV, AirDog, In-tank, Harpoon, HPX, ITP fuel sys, LL8 del, 203*, Oilguard & SP Diesel bypass filtration, ART rotors, PFC pads, Heater Core Ctl Valve, Bilsteins, Velvet Ride Shackles, South Bend Clutch, <span style="color: green">21.27 mpg</span>
2004 <span style="color: red">E</span>-350
XLT Wagon 6.0PSD 3.55 L-S TDM EZ-Entry 11 pass., AIC, custom MBRP 4" w/dual Aeroturbines, Airdog, harpoon, Overhead Cobalts
Pictures . . . Parts Links
DarthSurplus is offline
Old 12-12-2005, 05:59 PM   #5 (permalink)
XRACER's Avatar
Well....I'm talking Quigley. I don't know what comes in the stock van. But yes, the springs that Quigley sent me are Ford parts.
I'll post the part numbers tomorrow.
Some Pix
New Pix 9-12-2010
XRACER is offline
Old 12-13-2005, 02:51 PM   #6 (permalink)
7up
Very Interesting....
TONY
Ordered 9/12/02 Bld.12/6/02 Deliv.12/23/02 Quigley Conv.12/27/02*2/03/03 FINALLY!2/8/03
03 E350 Chateau*P.S.D/138"WB/3.55LS*Estate Grn.W/Mineral Grey*Med.Pebble Leather Seats/6 way Pwr*Digital Research 15"+3/7" Vid.Mon.*PS2*Quigley 4X4*SSB Midland Mobile(Booted)/Cophased Whips/6 Boston 2Way 6"/2-12"McCaully Drivers/Head Unit/Nav Powered By Alpine
MY WEBSITE www.MAJESTICSOUNDSDJ.COM
7up is offline
Old 12-13-2005, 08:51 PM   #7 (permalink)
XRACER's Avatar
That part number is 3C24-5310-VA.
Some Pix
New Pix 9-12-2010
XRACER is offline
Old 12-13-2005, 10:53 PM   #8 (permalink)
My Photos: (14)
Actually, the 4600lb Front GVWR option spring was available in 2003. My van has them. It was called the one up option or something like that. Your '03 could have been ordered that way from Ford before being sent to Quigley.There was a discussion on it quite a while back (last year maybe). Fortunately hanging a plow is something I don't have to worry about.
While I love diesels, I don't need one, and unfortunately, after much deliberation its a hobby I currently cannot afford.......... Gone but not forgotten:
1999.5 F250 CC SB XLT 4WD, 7.3 PSD, First F,2nd Diesel, nice but still liked the van better.
2003 E-350 Super Duty Chateau (Club Wagon)7.3PSD, 3rd Clubwagon,First diesel, Never should have sold it....
ddog is offline
Old 12-14-2005, 11:43 AM   #9 (permalink)
XRACER's Avatar
Sure.....rub it in......
It's 15 degrees here.....
Some Pix
New Pix 9-12-2010
XRACER is offline
