Old 01-05-2009, 06:56 PM   #1 (permalink)
OBD I on a 96 E350?
My sticker on top of the radiator says OBD I. I thought OBD II came out in 96. Is this right and does anyone else have the same?
Dann
My Mods http://community.webshots.com/user/sconure
1996 E-350 , Bean's stage 2 injectors, 3" intake plenums, dual EGT gauge, boost, tranny, fuel pressure gauges.
94 RT10 Viper
96 GTS Viper
98 GT2 Viper
58 MGA
dansk is offline
Old 01-06-2009, 09:25 AM   #2 (permalink)
blageurt's Avatar
My Van is a 95 and is OBDII . . . yours is to. Only the early 94's are OBDI if I remember . The sticker is wrong.
95 E350 PSD HD Cargo , BB shim , E4OD , B&M aluminium Trans pan , HD cooler , Cat sleeps with the fishes , 3:55 D70FF, Michelin LTX " E " ,Not installed yet DP flashed PCM (60 Tow )Autometer Triple Pillar Guage pod , New Injector O-rings /IPR /lift pump / filterbowl @ 235K , Timbrens SES kit
1977 F350 Dually Dump , 460 , 429 POLICE heads , 4:56 D70FF, Edelbrock Intake , Holley 850 dbl pmper ,MSD IGN , Custom HiPo C-6 Trans , Dual Exhausts , Bridgestone "E" Tires
1983 KZ1000R , Yoshimura Stage I
1982 KZ1000 , 1045 Wiseco , Turbo ready
1990 KX500
blageurt is offline
Old 01-06-2009, 08:08 PM   #3 (permalink)
That's what I thought. But straight from Ford. That is what the sticker says, I took a second look cross eyed. Is there another way of really verifying? I talked to my smog guy and he told me he has seen 94 vehicles with OBD II.
Reason I'm asking is I want to get a scan tool and don't know if it is the same or not for I and II.
Dann
94 RT10 Viper
96 GTS Viper
98 GT2 Viper
58 MGA
dansk is offline
Old 01-06-2009, 08:18 PM   #4 (permalink)
chuckster57's Avatar
The difference in OBD I and OBD II connectors is the OBD II is in the passenger compartment and is a 16 pin trapazoid and OBD I is a 6 pin with a separate "jumper" wire and is located in the engine compartment. Your DLC should be under the edge of the dash on the right side of the steering wheel.
1994 F-350 7.3 IDI Turbo, crew cab, E4OD, LB, Dually Photos
1997 Jayco 323RKS fifth wheel w/2 slides, Air Lift 5000 bags
Train Horns: Pictures here
chuckster57 is offline
Old 01-07-2009, 03:17 AM   #5 (permalink)
carringb's Avatar
Your sticker says OBD-1 since that's what it was required to meet in that year (vehicles 8600-10,000 pounds). But all of the vans after '94 were OBD-2.
2000 E350 DRW XLT extended wagon (yes! it's a dually!)
17" Ultra Goliath rims
Banks Powerpack, Diablo Predator
Buckstop front bumper, Reunel rear w/ 20,000# reciever
250,000+
carringb is offline
Old 01-07-2009, 08:30 AM   #6 (permalink)
Ok thanks for the input. Mine connector is under dash left side of the steering wheel. Can anyone count how many pins are actually used? Just for comparison.
Dann
94 RT10 Viper
96 GTS Viper
98 GT2 Viper
58 MGA
dansk is offline
Old 01-07-2009, 08:38 AM   #7 (permalink)
Dann
My resource said the right side, but at least it is OBD II. Here is a link that will say what each "pin" is used for:
OBDII - On-Board Diagnostic's System - Does My Car Have OBD-II? The Connector and Communications.
