Oil consumption - Diesel Forum - TheDieselStop.com
Old 03-11-2007, 06:58 PM   #1 (permalink)
blageurt's Avatar
Oil consumption
I am approaching my first oil change after a major overhaul. I added 1.5-2 l over 8000 km ( 5000 mi ). Is that normal consumption for a PSD with 345k kms (225k mi.). I personally don't think that is alot of oil thatt burns/leaks.
Anyone have any thoughts ?
PS 1 qt. = 0.968 l [img]/ubbthreads/images/graemlins/shrug.gif[/img]
95 E350 PSD HD Cargo , BB shim , E4OD , B&M aluminium Trans pan , Twin HD coolers , Cat sleeps with the fishes , 3:55 D70FF, Michelin LTX " E " , DP flashed 60 Tow , 140 V idm , Autometer Triple Pillar Guage pod , New Injector O-rings /IPR /lift pump / filterbowl @ 235K , Timbrens SES kit , replaced lift pump /ICP/ IDM @ 256 K
1977 F350 Dually Dump , 460 , 429 POLICE heads , 4:56 D70FF, Edelbrock Intake , Holley 850 dbl pmper ,MSD IGN , Custom HiPo C-6 Trans , Dual Exhausts , Bridgestone "E" Tires
1983 KZ1000R , Yoshimura Stage I
1982 KZ1000 , 1045 Wiseco , Turbo ready
1990 KX500
blageurt is offline
Old 03-12-2007, 01:22 AM   #2 (permalink)
Re: Oil consumption
I will lose about 1 1/2 quarts in the 1st thousand miles after oil change. After that, none to speak of until the next change. If I top it off after that 1st thousand......will lose 1 1/2 quarts in the next thousand miles. Will not (unless I'm hauling a heavy load) lose any more than 1 1/2 quarts before the next change.
Quite a few people here have the same thing happen to them. Strange, but that's the way it is on some of them.
Mine has about 250,000 miles on it and has done that since the day I purchased it.
If I'm hauling a lot of weight on a trip it might drop down to 2 quarts low. I go ahead and top it off in those situations (I also count on doing an earlier oil change on the rare occassion that I do cary an extra heavy load).
BTW I go 7,500 miles between changes and have blackstone labs test my oil on every 3rd oil change..........so far, so good. Again, if I'm hauling heavy.......I'll cut that mileage in half for the change.
99 7.3L PS E-350XLSD with Ambulatory roof.
(((XM))) Satellite Radio
4" turbo back Diamond Eye exhaust (portadiesel)
Pair of K&N High flow filters
HPX Hose from D.I. (blew out.....pulled it and plugged now)
In-tank and prepump mods (homemade version)
203* thermostat (dieselsite)
Tru-Cool 4739 MAX Transmission cooler (dieselsite)
Boost Relief Valve (dieselsite)
Pillar mount Di-Pricol gauge set
Sonax/tricumulator (Black Cloud)
Jody flashed econo tune PCM (DP-Tuner)
Van specific regulated fuel return (ITP)
70k miles driven annually...mostly pulling 8 1/2 foot tall 7x14 enclosed trailer
Cruise on at 61mph and 1736rpm's I don't stop 'till she needs more go juice!
stroked_van is offline
Old 03-12-2007, 10:32 AM   #3 (permalink)
Re: Oil consumption
Major overhaul, means = it's fresh now, right? You ask if that is normal for 225k mi. Dont you mean closer to 0mi. ? (rings & bearings etc...)
Also I've read that checking it hot = approx quart still up in motor that hasn't drained down. I always run mine "1/2 to add" on the stick. & try to do my oil change when it is lowest(on the add mark). When I change oil & filter, I put new filter in big coffee can to keep it upright & fill it up with new oil real good(while old oil is still dripping out of engine, & I aim for approx 1hr dripping time to get out as much of old oil as possible. & it is still dripping then!)Then I fill to approx 1/2 way on stick with new oil (short engine run to prime up all channels/ports). Next morning before start, the dip stick will show a little over top of full mark. my .02
1999 E350 7.3psd , XLT , 15 pass/ext , purchased 6/6/05 w/255k on odo, 8/05 added BTM/straight pipe,5/06 BTS,1"shimmed front coil springs,Michelin XPS 235/85 16 R.,FredGroeske2"rear wheel spacers,1-1/2" rear sway bar,AIC,3 A-pillar guages, Tekonsha envoy,coolant filter,4 pos dp-tuner,In-tank mod & harpooned,dahl-100 prepumpfilter,Scan-guage,Bilstein shocks.
bork is online now
Old 03-12-2007, 10:54 AM   #4 (permalink)
blageurt's Avatar
Re: Oil consumption
No ,what I meant by overhaul was fuel system /IDM/wiring/ gaskets/ Turbo not bearings or rings ie;internal engine parts are untouched . . . sorry about that. At any rate It seems like I'm OK for now . I have the bottle from blackstone , so I will let you know when I get the results. Thanks for the responses.
1990 KX500
blageurt is offline
