oil leak, no source - Diesel Forum - TheDieselStop.com
Old 09-03-2005, 11:54 AM   #1 (permalink)
oil leak, no source
I have a leak somewhere around my turbo manifold on a 99 Powerstroke van. I took off the heat shield and while running I searched with a flashlight for the problem. I tried reving it too but no luck in seeing a drip. Everything in front of the turbo (like the HPOP) is dry. Are there any common oil leaks in the turbo I should look for? Thanks
veganxxx is offline
Old 09-05-2005, 08:36 PM   #2 (permalink)
Re: oil leak, no source
The turbo pedistal o-rings usually leak after time.
If it is the o-rings,make sure you get the new-style viton o-rings from the dealer.
2000 E-350 Van,BTS Tranny,Custom Dana 80 Axle w/ ARB & 3:55 Gears, Swamp 175cc Injectors, Custom 4 Position Chip,TS Billet Intakes,W/Wheel,PS2000,Magnaflow 4" Exhaust,ITP Fuel Regulator,4 gauge pillar post,TTM,CTI Idle Controller,Amsoil Fluids,Evans,203 Thermostat,Coolant Filter,J&J S.S. Grill,Art Rotors,Custom Flame Job,Road Armor Bumper,Warn M15000 Winch,Bushwacker Flares,Bilstein Shocks,Centerlines,Maghytec Covers. dynoed at 345.5 rwhp
FUTURE MODS: Upgraded turbo, HD oil pump,Intercooler with water injection.
http://community.webshots.com/user/aceman116
04 Jeep Rubicon
RE 5.5" Long Arm Lift,1"body/eng.lift,Banks Header/ Exhaust,37" IROKS,Mickey Thomson Classic 2 beadlocks,Road Armor Bumpers,Warn 9500TI winch,Alloy Usa axleshafts,CTM u-joints,Nth degree oil pan skid,Clayton front high clearance brackets,Toys by Troy crossover steering,Poison Spyder Rock Sliders.
Aceman is offline
