Oil Pressure range
After running at highway speeds for an hour or more when I come to a stop and idle my Oil Pressure drops to 25 to 27 psi. ( idle rpms stay around 660 to 670 )
At speed it runs around 55 to 60 psi.
Rotella 15W40 / changed every 3 k.
Are these pressures within the range (s) that y'all are seeing.?
Paul
2002 E350 (E31) PSD Chateau Quigley 4x4 3:55LS Dual Alts / AIC / MagnaFlow / Westach / Autometer / 4 gauge A-pillar / MagHytec Trans & Diff / Weld / Michelin / Hellwig / K & N / Trans Flow / Turbo Life saver / TransGo / BD Exhaust Brake / FPS performance kit / Aux. Trans cooler w/fan / Rancho / Estate Green/Silver (VLB2) Locust Grove, GA
