Are Parking garages a standard height? - Diesel Forum - TheDieselStop.com
post #1 of 14 (permalink) Old 11-13-2003, 01:00 AM Thread Starter
I ask this because I'm always wonder whether the van will fit in certain garages, on time it was so close the antennas were hitting on every cement support. It was about to touch the roof. But there are some parking garages at school and they seem even lower.. but I'm not sure, they say the clearance is 7 feet, that's for the second level anyways, the first level is 8foot 2inches. But you'd think they'd make all garages capable of fitting the most popular van in America. I mean... there are a ton of people that drive these so why would they make garages that didn't fit them?
So yeah.. anyone have any idear on this? Also what is the height of a stock van? I went and measured but didn't quite have a tape measure so i used a stick, i got about 6foot 11inches.
Eric
, 6,900 lbs.
Dodge 1997 Ram 3500
yaric008 is offline
post #2 of 14 (permalink) Old 11-13-2003, 01:10 AM
Re: Are Parking garages a standard height?
No.
Edit:
Well, maybe.
I don't have a diesel truck, but I think they're pretty swank.
adron is offline
post #3 of 14 (permalink) Old 11-13-2003, 01:32 AM
cdnsarguy's Avatar
My Photos: (109)
Eric
No two garages are the same height, there should be a sign on entry which will say what the lowest clearance is on that level, got to pick up on watching for the signs before getting in line to enter.
These heights could change higher or lower as you go up or down so you have to be alert. For sure get the van measured correctly front and back, mark it somewhere so its visible when needed. Also take into consideration the aerials, no need ruining a $100 cb antennae.
Proud Canadian BOOB man too!!
cdnsarguy is offline
post #4 of 14 (permalink) Old 11-13-2003, 09:01 AM
Flywheel's Avatar
The height is one thing - however, even if you fit under the clearance bar that the put at the entrance, be very careful not to get into a position where you get your van wedge under something. Due to the length of your van, you may fit under the height resriction, but hit when the front wheels are going up or down - it's all geometry...
I usually suck up my pride and have a friend get out to chack if I am unsure - better safe than sorry 0 hitting concrete would really ruin my day...
Trail Boss Replacement Bumpers, Tool Box, Headache Rack, Full Length Running Boards, BFG AT/KO 285/75x16E, 2003 Cup Holder, Marinco Heater Plug, Weather Tech Rain Vents / Hood Guard, B&W GN Hitch, X-Springs, Rear 4" F350 Blocks, Hellwig front and rear sway bars, Airlift / Wireless, Duraflaps
Isspro A-Pillar Gauges, Isspro TTM, Ford AIS, Magnaflow 3.5" DP - 4" Exhaust, Garrett GTP38R Turbo, Turbo-Master, High Flow Outlet, Non EBV Pedestal, IH Up-Pipes, DS 203 degree Stat, OA, BTS Tranny, 6.0L Tranny cooler, DP-Tuner F6, FRX, Cass Stage 1s, T500 HPOP, DieselSite HPX
99 F-250 CC SB 4x4 7.3 White
Ranch Truck, Ranch Hand brush Guard, Original Cup Thrower, DP-TUner F6, 4" Turbo Back Magnaflow, AIS Intake, 6.0 Tranny Cooler, Ford 4R100HD, CM Flatbed
Autoenginuity
Flywheel is offline
post #5 of 14 (permalink) Old 11-13-2003, 10:51 AM
My Photos: (9)
I estimate mine at near 7 foot 6 inches, probably at the antenna which I use as a "feeler gauge". I fit easily under 8 foot limits, but won't attempt anything lower unless I can see it in relation to my antenna (which is about 2 inches higher than the roof).
Of course, new tires and wheels will change all of this... [img]/ubbthreads/images/graemlins/cool.gif[/img]
2001 E350 PSD, Deep Emerald Green, 3.55 LS, Premium package, dual alts, rear A/C. Quigley 4x4, Transfer Flow rear tank (27+26), handicap mods, custom interior, Reunel tire carrier w/ Hi-Lift, Sportsmobile nerf bars (black), Amsoil lubes and Dual-Gard bypass oil filter, Amsoil air filters, Eclipse/JL Audio sound system w/ Sirius & 120GB Neo Car Jukebox (MP3 player), J&J stainless grill, Reunel Stainless bumper, 12000# Warn winch, PIAA lights, Bilstein shocks, Ultra Magnum wheels, Michelin tires (265/75-16), Correctrack rear wheel spacers, Bushwhacker flares (painted), Velvet-Ride spring shackles, p/s filter, external tranny and coolant filters, Autometer gauges(5), Optima Yellow Tops, Airdog.
msnunes is offline
post #6 of 14 (permalink) Old 11-13-2003, 07:16 PM Thread Starter
Well i went to the airport today and was forced to go in a parking garage that had a 7 foot clearance... it fit fine. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Eric
, 6,900 lbs.
Dodge 1997 Ram 3500
yaric008 is offline
post #7 of 14 (permalink) Old 11-13-2003, 08:08 PM
My Photos: (11)
I just simply avoid them ... not worth the chance since we're usually talking about an inch or two within 7 feet which is about the height of my van. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Larry
2001PSD(PCM:HPI2)SD E-350,Dk Emerald Grn,4.10LS, <font color="blue">Mustang dyno - 183.9/400.4 stock</font>
, BTS w/Schaeffer's ATF
, ITP 3.5"/4" exhaust w/Magnaflow & Aeroturbine,Dieselsite 203* T-stat/Zerex G-05,F.Pwr, Ext/Int. Upgd. pkg,R. Bds,AIC,Tow Pkg, Rear & Slider windows,<font color="red">AMSOIL air, oil-bypass & rear end 75w-140 fluid ,<font color="blue">3/8" fuel sys w/10 Dieselsite DAHL100 & fuel manifold/sight glass</font>,6 way dr. pwr. seat, Magnefine trans/P.S. filters</font>, husky mats,<font color="red">5 gauge A-pillar ISSPRO EVs w/Grn mkr illum. + air & fuel restriction gauges</font>,Dieselsite coolant filter and zinc electrode, manual GPR switch & GP LED, blinking security LED, weathertechs, a few other "Gadgets"
, & a 1981 26' Prowler TT(26Y)
Larry M is offline
post #8 of 14 (permalink) Old 11-13-2003, 08:34 PM
No one has a roof rack like I do? Thule.
2005 Ford Excursion 6.0 PSD,
2003 Ford Expedition
Clevelandjim is offline
post #9 of 14 (permalink) Old 11-13-2003, 10:26 PM
My Photos: (17)
I have a roof rack, pop top, 31" tall tires and a 2" suspension lift... I'm closer to 9' tall and that's if I deflate the rear airbags!!!!
youngster
2001 E-350 SuperDuty<font color="green"> 2wd Sportsmobile,
,3.5" DP with 4"exhaust, 3 pos "Bill's" chip, Autometer Phantom gauges, Baldwin pre pump filter assembly,
, Warn 9k winch, PIAA lights, Goodyear Wrangler AT/s tires (265/75 R16), Firestone airbags,
roof rack, Bushwacker Fender flares,
rear wheel spacers, Rancho 2" lift, </font>
youngster is offline
post #10 of 14 (permalink) Old 11-14-2003, 02:56 PM
haha nice one
adron is offline
post #11 of 14 (permalink) Old 11-14-2003, 03:45 PM
Most are 6'6"-7' high.
The only "standard" I've found seems to be "2 inches lower than whatever I'm currently driving".
1979 F-350 4x4, Cummins 6BT power
1992 International Genesis school bus conversion
GO, RED SOX!
Johnny96 is offline
post #12 of 14 (permalink) Old 11-15-2003, 08:08 PM
Yup....I agree with that 100%. I work over in NY city and there isn't a single parking garage over there that I can fit in....well....maybe there's one or two but I haven't found them yet. [img]/ubbthreads/images/graemlins/grin.gif[/img]
~ Pete ~
1999 E-350 PSD - Super duty cargo - 3.55 LS...Bilsteins, dual alternators, all power...125K miles - now with a new Jasper trans and torque convertor.
PJC99 is offline
post #13 of 14 (permalink) Old 11-15-2003, 10:06 PM
There are no standards for garage heights. You can't really trust the restrictors at the entrance either. The last van I had carried a big scar on the roof to prove it. Nope, I did not do it, just had to deal with it...
I have found the solution is to make sure at least one flexible antenna is a few inches higher than the tallest spot on the van and use it as a vertical curb feeler.
Dave
2003 E350 Chateau, last of the 7.3 Turbos
DivinDave is offline
post #14 of 14 (permalink) Old 11-18-2003, 11:20 AM
I was able to get mine to fit in the garage at home by putting drop shackles on the rear and pulling the roof rack off. I usually avoid parking garages unless they have at least a good eight feet or so of clearance. Way too many variables so I usually stick to surface lots.
Here at work the building, the one I manage, I have hung a 8" piece of pipe at the entrance and see people rolling under it constantly but I actually hung it a good 10 inches lower just to give me a margin of safety. Even my own van won't fit. But a year or so ago an extended chevy van came in with a full load of phone books. After they unloaded them guess what happened, it popped back up several inches an on the way out it hit a dozen or so fire sprinkler heads and damaged the ceiling in several spots. The bonehead driver should have stopped and let some air out of his tires. I ended up hitting his insurance company up for several thousand dollars, new sprinkler heads, ceiling tiles, grid, cleanup and labor. Even the van had a grand or so worth of damage.
early 99 F350 4x4
DieselDeaf is offline
  Diesel Forum - TheDieselStop.com > Ford Diesels > E-Series Vans
