I can't find the part number on this forum anywhere. I saw it a week or so ago, but it has disappeared. Any thoughts on where to look?
1998.5 E350 7.3 extended cargo with Late model doors ,po.wer windows, locks and mirrors.Isspro gauges from DPPI, Power Slot Cryo rotors from DPPI, Hawk LTS from DPPI,NAPA DOT 4 brake fluid,NAPA calipers,Evans coolant,Dieselsite ac control valve,Dieselsite 203* thermostat,BTS valve body, Amsoil tranny fluid,4WD deep tranny pan from Dieselsite, DieselSite transmission bypass filter,Amsoil dual oil filter, Amsoil 15-40 wt oil,4 inch Warpspeed Performance exhaust,Thermo-Tec Exhaust Insulating Wrap, Bilstein shocks,Line-X 2-06-2009 103,400 miles following added Beans stage II single shot injectors, Air Dog, Beans regulated fuel return with fuel bowl delete, glow plugs and Stancor gp relay, Beans modified IDM, Stealth HPOP stage I, Dominator 66 turbo, DpTuner reflashed factory pcm that was split shot injectors to the single shots, 9 tunes from DP Tuner including decel tune,tuflocs on all doors, Snow water-methanol injection stage 3 installed by Beans Diesel, BTS tranny
Re: part number for Napa big truck muffler (btm) ?
21470
99 7.3L PS E-350XLSD with Ambulatory roof.
(((XM))) Satellite Radio
4" turbo back Diamond Eye exhaust (portadiesel)
Pair of K&N High flow filters
HPX Hose from D.I. (blew out.....pulled it and plugged now)
In-tank and prepump mods (homemade version)
203* thermostat (dieselsite)
Tru-Cool 4739 MAX Transmission cooler (dieselsite)
Boost Relief Valve (dieselsite)
Pillar mount Di-Pricol gauge set
Sonax/tricumulator (Black Cloud)
Jody flashed econo tune PCM (DP-Tuner)
Van specific regulated fuel return (ITP)
70k miles driven annually...mostly pulling 8 1/2 foot tall 7x14 enclosed trailer
Cruise on at 61mph and 1736rpm's I don't stop 'till she needs more go juice!
Thank You !!!!!!!!!!!!!
Instructions to install were still in the little secrets at the top of this forum. Hopefully Photo links aren't dead.
The factory muffler is one piece with the tailpipe. For the BTM swap, cut the oem muffler out tight to the muffler. There is an S piece in front of the muffler that connects to the midpipe. You loosen the clamp at the midpipe to spin the S-pipe around to get better alignment on the BTM. The BTM is straight thru where the OEM muffler is Offset.
ddog
While I love diesels, I don't need one, and unfortunately, after much deliberation its a hobby I currently cannot afford.......... Gone but not forgotten:
1999.5 F250 CC SB XLT 4WD, 7.3 PSD, First F,2nd Diesel, nice but still liked the van better.
2003 E-350 Super Duty Chateau (Club Wagon)7.3PSD, 3rd Clubwagon,First diesel, Never should have sold it....
Thanks ddog. Sounds like I just need to loosen and flip. I am going to install gauges to get a base line, then start the mods to see the difference.
That's it. S pipe in front of muffler is part of the one piece OEM muffler and tailpipe Assy. Just remember to cut tight to muffler, then trim back to fit the BTM, its a little longer than the stock muffler. Spinning the s-pipe doesn't make it perfect, but close enough for exhaust work.There is a notch in the S pipe that matches to a tab in the midpipe. Yo may have to grind the tab on the midpipe off to get it to spin.
