Rear Shock Removal? - Diesel Forum - TheDieselStop.com
Old 07-31-2007, 08:37 PM   #1 (permalink)
carrfamilynj's Avatar
My Photos: (6)
Rear Shock Removal?
I just spent almost 2 hours under the back of my van and got NOWHERE! The upper stud nut on the shock is hard to reach, and I can't get it spun off with a 15 mm wrench. There's not enough space to get anything other than a regular wrench in there. Anyone have a suggestion? I actually got it most of the way off by setting the wrench against the undercarriage and twisting the shock body with my hands, but that's not going to work for the last couple threads.
'04 E350 XLT SuperDuty "Crew Van"-3 rear benches removed,
equipment shelving installed.
Specs: 5.4 V8, 3.55 open rear, K & N with modded snorkel, Black Magic Extreme 16" electric puller fan, In-Dash Auto-Meter Phantom electric coolant and ATF temp gauges, Derale Deep Transmission pan cooler, TransGo Shift Kit, Gabriel Hi-Jackers rear air shocks, polished aluminum billet grill, Euro-clear corner lenses with 18 LED amber bulbs, Euro-clear headlights with Sylvania Silverstar Ultra bulbs, Lund bugshield, 55 watt driving lights, stainless trim rings with chrome deep lug nuts, Valley Class 4 Receiver Hitch
Purchased 5/2006 w/44k, 69k as of 3/2008
carrfamilynj is offline
Old 07-31-2007, 09:43 PM   #2 (permalink)
XRACER's Avatar
Re: Rear Shock Removal?
I cut the stud with a small hack saw first, lock a vise grip on the nut and spin the shock.
Another option is a pass-through wrench. Facom makes them (and others do too, I imagine). It's a right angle wrench that's open on top for a stud to pass through.
McMaster Carr carries them.
If you can stand to wait, PM me your address and I'll loan you mine.
2005 E350 Standard Cargo Van, 6.0 PSD, 4.10 L.S., Quigley 4X4 New on 11-18-05
(seems to manufacture oil...)
Warranty Turbo 7-07 22,000 miles, Warranty A/C compressor 10-07 25000 miles
2003 E350 Extended Cargo Van, 7.3 PSD, 3.55, Quigley 4X4 New on 2-1-04
Some Pix
New Pix 9-12-2010
Transfer Flow 46 Gal*Delaminated*Replaced 8-06 UNDER WARRANTY
7.5' Western Snow Plow
BTS Tranny 9-29-07 @55,000 miles, Aluminess Bumpers, Mile Marker 12,000 pound hydraulic winch
2000 F250 ...... just cuz people are dumping them for the fuel bill. Got mine on ebay for $8749 with 116K on the clock.
1-1-09 BTS Tranny, 500+ HP at the rear wheel
XRACER is offline
Old 07-31-2007, 09:57 PM   #3 (permalink)
My Photos: (6)
Hey, thanks for the offer! I think I'll try your first suggestion, I already tried to get my hack saw in there but no dice. I have a homemade rig, it's a hack saw blade taped to a stick, that may do the trick. Thanks again...
Old 07-31-2007, 10:31 PM   #4 (permalink)
sixiron's Avatar
My Photos: (11)
dremmel it off and get a new nut for the new shock
2002 E-350 ext. cargo..4" DP+exhaust/gauges/ CCV mod/ AIH delete/TT mirrors wC-btr's/Racor prepump/ITP regulated return w/fuel bowl delete/tank mods/203*/timbrens/bilstein/Hella/ DP tuned/BTS trans/ alum baja wheels/cryo rotors...dyno 335 hp...308,272 miles
04 VW TDI/PD Jetta wagon
TT bushings, Koni'sEuro HID's,tint,
cat 2 mic f/filter,CCV/muffler/fuel filler mods,skidplate, RC1+
sixiron is online now
Old 07-31-2007, 10:44 PM   #5 (permalink)
blageurt's Avatar
Get a box wrench on it and slide a pipe over the wrench and do the Rambo . . . If you have a torch heat up the sucker till its red and then reef on it. Or as Six says Dremel or Cut off wheel / Sawsall or other electric / Air powered cutting tool. I have never struggled with bolts I just break them. (20 years of Powerlifting Helps}. I also have a large assortment of cheater bars / BFH's etc.
Wear gloves if possible even though skin does grow back. [img]/ubbthreads/images/graemlins/grin.gif[/img] [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
95 E350 PSD HD Cargo , BB shim , E4OD , B&M aluminium Trans pan , Twin HD coolers , Cat sleeps with the fishes , 3:55 D70FF, Michelin LTX " E " , DP flashed 60 Tow , 140 V idm , Autometer Triple Pillar Guage pod , New Injector O-rings /IPR /lift pump / filterbowl @ 235K , Timbrens SES kit , replaced lift pump /ICP/ IDM @ 256 K
1977 F350 Dually Dump , 460 , 429 POLICE heads , 4:56 D70FF, Edelbrock Intake , Holley 850 dbl pmper ,MSD IGN , Custom HiPo C-6 Trans , Dual Exhausts , Bridgestone "E" Tires
1983 KZ1000R , Yoshimura Stage I
1982 KZ1000 , 1045 Wiseco , Turbo ready
1990 KX500
blageurt is online now
Old 07-31-2007, 11:34 PM   #6 (permalink)
My Photos: (6)
Can't fit a dremel in there, or it would already be done. I may just torch and bust it off....
Old 08-01-2007, 01:59 AM   #7 (permalink)
You can spin the shock with a 12" pair of Channellocks. The Griplock series works very good. Two of them held together 90 degrees apart will help avoid simply crushing it. Resist the urge to just crush it until you are sure the nut is off. I know there is room to get a nut splitter on the right rear. You still have to get vicegrips or something onto it afterwards. Those with diesel tanks can be less cautious about cutting torches than those with gas tanks.
1994 E-350 RB 5.8gas 4X4Quigley cargo 4.09 arb-locker f/r 35x12.5-16.5 or 285/75-16.,,, 1997 E-350 EB 5.4gas 4X4Quigley Sportsmobile camper 4.10 arb front, L/S rear 285/75-16/front 33X12.5-16.5/rear ><>J
toalpi is offline
Old 08-01-2007, 11:11 AM   #8 (permalink)
My Photos: (9)
I believe locking onto the nut and spinning the shock body is the key to changing most of these -- I think only the right front can be done "properly." I considered doing this myself this last time, and quickly gave up on that idea. I gladly paid my 4wd shop $200 to do it for me, and it only took him 2 hours (30 mins on the passenger side, the rest on the driver's side), which he considered a long time. Mine came with nylon lock nuts, most of which he tossed due to their applying too much friction while trying to spin the shock body to tighten them up -- he used regular nuts and doubled-nutted them instead.
2001 E350 PSD, Deep Emerald Green, 3.55 LS, Premium package, dual alts, rear A/C. Quigley 4x4, Transfer Flow rear tank (27+26), handicap mods, custom interior, Reunel tire carrier w/ Hi-Lift, Sportsmobile nerf bars (black), Amsoil lubes and Dual-Gard bypass oil filter, Amsoil air filters, Eclipse/JL Audio sound system w/ Sirius & 120GB Neo Car Jukebox (MP3 player), J&J stainless grill, Reunel Stainless bumper, 12000# Warn winch, PIAA lights, Bilstein shocks, Ultra Magnum wheels, Michelin tires (265/75-16), Correctrack rear wheel spacers, Bushwhacker flares (painted), Velvet-Ride spring shackles, p/s filter, external tranny and coolant filters, Autometer gauges(5), Optima Yellow Tops, Airdog.
msnunes is online now
