For my '85 E-150, I have a Chiltons that covers E-150 - E-350 with both gas and diesel engines, but I can't find one of my '99. Is a manual available for our E-350 Van's w/7.3?
I've had good luck finding factory manuals on eBay. A full set for my 04 E-Series cost ~$100, but worth it.
Mike
125W solar panel. Sportsmobile off-road trailer.
54,311 miles. 16.47 mpg average
From Cal to Alaska and Key West and points in between
05 F350 front axle and aluminum wheels 275/70-18 tires. 46 Gal tank - harpooned pump vent tube.
Scangauge
162 days in the shop - not counting the 4wd conversion time - Replaced front springs, 2 injectors, Trans housing, 3rd gear, Reverse planetary assy, Turbo, Alternator, Turbo hose fitting, Block Heater, Door lock - all under warranty. AC hose, not under warranty.
They will have factory authorized owners manual and shop repair manuals.
I got the "diesel supplement" for my truck (sig) after I bought it and couldn't find one in the truck any where. I looked and your van has the shop manual in either book or CD
1994 F-350 7.3 IDI Turbo, crew cab,LB, Dually,
ATS Turbo upgrades, 3" DP with 3" exhaust Magnaflow XL muffler
1997 Jayco fifth wheel 323RKS, Robins 16K dual axis hitch
Apillar pod with: Autometer C2 Series gauges: pyro,trans, boost
Hypermax Cowl induction
Flex-A-Lite 26K tranny cooler w/fan
K&N air filter (we'll see in a million miles)
Tekonsha "prodigy" brake control
