Rusted Coolant lines to Rear Heater Core on E-350 Also A/C lines - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 06-27-2009, 08:28 AM Thread Starter
Is this dangerous? I just bought a 95 E350. It's got rusted metal lines to the rear heater core. They're almost ruptured. I'm guessing if the break, all my coolant goes out. This is bad!
So... what are my options?
Can I find these things?
-Ford E350 PSD 1995 --- 500k+ Upgrades-DIY Push Button Manual Shifting E4OD Computer-Stancor Glow Plug Relay-DIY Stage 1 Injectors-Cat Out-Bigger Rear Tires-DIY SD Electric Fuel Pump system
-98 Taurus 3.0 OHV --- 200k+ New H.Gaskets
-MB 300d Turbo Diesel(s): 1980, 84(x2),85, and 87 Fast, nice to work on, great machines. All outgrown and Sold
-GMC Suburban 6.2 Detroit - Slow. Reliable. Sold.
777funk is offline
post #2 of 6 (permalink) Old 06-27-2009, 12:44 PM
My Photos: (18)
If there is a 'pick & pull' place, you could go try to find some used lines off another van.
If not, maybe another member might know of a place or have some parts. Other then that, you might have to go to a Stealership and buy some 'new' lines.....
1999 E-350 Cub Wagon, 7.3L Power Stroke, E4OD, 3.55
1990 E-350 Club Wagon, 7.3L IDI, E4OD, 3.54LS
x2
1994 Chevy C2500 6.5L TD, 3.42
1983 F-150 2x4, 4.9L, C-6 w/GV-OD, 3.55 Farm pickup
1981 C-8000, 3208 CAT, RT-6510, Rockwell SSHD Tandems (Swap)
1981 VW Rabbit Pickup 1.6L diesel (project)
1978 VW Rabbit 1.5L diesel (project)
1977 K100C, NTC-350, RT-1110, Tandem
1977 Transtar II, NTC-290, RT-9509 Single
1977 Transtar II, Formula 290, RT0-9513, Tandem (project)
1974 C-750, 391CID, Clark 5 speed, Eaton 2 speed
Kaliburz is offline
post #3 of 6 (permalink) Old 06-27-2009, 01:19 PM
carringb's Avatar
I thought the dealer ones were pretty reasonable.
I had to change them on my '94. The new ones come with protective plastic conduit to prevent rock damage from initiating rust.
2000 E350 DRW XLT extended wagon (yes! it's a dually!)
17" Ultra Goliath rims
Banks Powerpack, Diablo Predator
Buckstop front bumper, Reunel rear w/ 20,000# reciever
250,000+
carringb is offline
post #4 of 6 (permalink) Old 06-27-2009, 02:50 PM
My Photos: (35)
Two words..........................
Heater Hose...
My 96 gasser had the rear heater tube go south, used good heater hose to make the patch.. and 2 years ago my psd had the same line go south... heater hose for the patch, then a short while later another spot went south(leak) and that out in the middle of fraken no where,, so with some extra hose that I had , cut the feed and return lines and looped it there with the hose, no heat in the rear until 2 weeks ago when I cut the metal lines just after the engine and ran 22' of feed and return lines to the rear heater and cut out all of the Ford metal lines... I used a plastic pipe to make the just from my bought hose to the ford hose that goes up into the heater.. works great and no worries about rusting out in the future...
2000 E350 7.3PSD, Hellwig Stablizer bar, 1.5"spacers from old Correct track OR,140 Lightforce with covers, 5x7 LED's From Truck-lite, extras in the bumper. 4"Aero Turbin and 4" all the way back. 1705 program, Scangauge II,265/75/16E, My Photos
"FAILURE IS NOT AN OPTION"
It riles them to believe
that you perceive
the web they weave
And keep on thinking free
Alaskapsdvan is offline
post #5 of 6 (permalink) Old 06-27-2009, 02:58 PM Thread Starter
Maybe flexible copper tubing?
777funk is offline
post #6 of 6 (permalink) Old 06-27-2009, 03:02 PM
My Photos: (35)
Seen the price of copper?
that you perceive
the web they weave
  Diesel Forum - TheDieselStop.com > Ford Diesels > E-Series Vans
