Scanner recomendations please - Diesel Forum - TheDieselStop.com
Old 07-30-2007, 09:41 AM   #1 (permalink)
I'm hoping to go on vacation soon with van but now the SES came on. It has done it intermittently. Twice when starting cold. & twice when going about 35 mph. sometimes goes off on its own, approx 15 minutes later. (once when I shut it off & restarted)& one time when the SES came on my injectors rattled loudly for about 2-3 seconds which prompted me to look at guages & noticed SES on. I intend on getting an Autoenginuity scanner, but for now I need to get this scanned.ASAP! Any other good scanners out the that will read the early 1999 PSD's? Brand & model please, so I can call around to local shops with a recommended capable scanner, so I can get fix in proggress. My wife will shot me if the van is not ready to depart & without getting stuck somewhere.
1999 E350 7.3psd , XLT , 15 pass/ext , purchased 6/6/05 w/255k on odo, 8/05 added BTM/straight pipe,5/06 BTS,1"shimmed front coil springs,Michelin XPS 235/85 16 R.,FredGroeske2"rear wheel spacers,1-1/2" rear sway bar,AIC,3 A-pillar guages, Tekonsha envoy,coolant filter,4 pos dp-tuner,In-tank mod & harpooned,dahl-100 prepumpfilter,Scan-guage,Bilstein shocks.
bork is offline
Old 07-30-2007, 10:31 AM   #2 (permalink)
My Photos: (10)
Re: Scanner recomendations please
Bork
Any reputable repair shop should have one. Don't worry if they don't repair diesels. They can still pull the info.
Bill
MADVAN is offline
Old 07-31-2007, 12:15 AM   #3 (permalink)
blageurt's Avatar
If you have a laptop I would reccomend the Autotap from B&B Electronics I bought it last year and I like it.I was tired of getting raped $65 each time for scans/code retrieval . I had to pay an extra $100 because of Duty from US on my end so it cost me about $400. The cool thing is you can virtually monitor everything while you drive. Which means you know where your engine stands as far as performance and what real time values for stuff are. It clears codes and scans . The only thing it does not do is the injector test. But I belive they are working on that. They asked me for feedback a few times but I never gave it to them. You would need the Ford "enhanced" software package . thats what they call it anyway. It would be alot cheaper for you since you are American. Check it out Autotap.com
PS you need a laptop P2 or better
Good luck
Fernando
95 E350 PSD HD Cargo , BB shim , E4OD , B&M aluminium Trans pan , Twin HD coolers , Cat sleeps with the fishes , 3:55 D70FF, Michelin LTX " E " , DP flashed 60 Tow , 140 V idm , Autometer Triple Pillar Guage pod , New Injector O-rings /IPR /lift pump / filterbowl @ 235K , Timbrens SES kit , replaced lift pump /ICP/ IDM @ 256 K
1977 F350 Dually Dump , 460 , 429 POLICE heads , 4:56 D70FF, Edelbrock Intake , Holley 850 dbl pmper ,MSD IGN , Custom HiPo C-6 Trans , Dual Exhausts , Bridgestone "E" Tires
1983 KZ1000R , Yoshimura Stage I
1982 KZ1000 , 1045 Wiseco , Turbo ready
1990 KX500
blageurt is offline
Old 07-31-2007, 12:35 AM   #4 (permalink)
Bork,
Here's a link to another PC-based program that I've heard recommended on the Engine and Driveline Forums...
http://www.autoenginuity.com/
FWIW - It's been my experience that "generic" OBD code readers will read only the "standardized" OBD emissions-related codes and not manufacturer-specific codes (many engine codes, as well as transmission and other component controller codes).
Good luck and enjoy the vacation...
Don't forget to take some "Van Goes on Vacation" photos...
Stu
1999.5 E-350 XLT Extended 12 Passenger Wagon 7.3PSD. 100% stock except for dual K&Ns, but looking to change that...
Late99EconoWagon73 is offline
Old 07-31-2007, 09:28 AM   #5 (permalink)
anash13's Avatar
Bork:
You may wish to look at the "SCANGAUGE" System.
"SCANGAUGE" Gives you a lot of very usefull information, such as all the trouble codes stored in the ecm (if any), MPG, GPH, TRIP INFO., DIGITAL MPH READOUT, and a few other thing.
the cost is reasonable also at around $100.00...Check it out. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
2003, E-350, XLT, Chateau, 7-Pass. Club Wagan, 7.3L PSD, 3:55 LS Rear, DP TUNER F-5, AMSOIL TS-126 Air Filter, Fleetguard LF-9027 Bypass Oil filter, Sirius Satellite Radio, Garmin GPS, SuperCrewzer, AutoMeter (Pyro. Trans. Boost)Gauges, 4" Diamond Eye Turbo Back Exhaust, Sonnax valve & Tricululator springs, PML Alum. Tran's Oil Pan, Tru-Cool 4739 Tran's Cooler, ScanGuage Monitor, DAHL 100 Fuel Filter, "Last of the 7.3's".
USMC-(Ret).
You Can't Always Get What You Want, But If You Try Some Times You Just Might Find, YOU GET WHAT YOU NEED.
anash13 is offline
Old 07-31-2007, 12:11 PM   #6 (permalink)
buster26, I have the scan guage & is JUNK for codes on my early 99. Its good for monitoring other stuff, but still lacks info for water temp & a couple of other things.
I'm leaning towards an autoenginuity.
bork is offline
