Step Bumper on eBay - Diesel Forum - TheDieselStop.com
Old 03-06-2007, 12:18 PM   #1 (permalink)
MikeL46's Avatar
My Photos: (14)
Step Bumper on eBay
Anybody want or need a step bumper for a van. There is one listed on eBay:
http://cgi.ebay.com/ebaymotors/ws/eBayIS...s_promot_widget
or item #250089749070
I just got one from him and put on my van. Complete kit, brackets, step pads, bolts, plastic end caps, reasonable shipping, factory p/n on box, 400# tongue weight, 4000# towing. Add says it fits 92-00, but it bolted directly onto my 2004 E-350. The only negative might be the black color, but that was a positive for me.
What you see in the middle of the picture is a license plate bracket. It doesn't look bad on the bumper, but the picture somehow makes it stand out.
Since I got one and he put another back up, he might have more than one.
Good luck,
Mike
D70 Full floating rear axle from a cutaway van
140A Alternator. 125W solar panel. Sportsmobile off-road trailer.
96,258 miles. 16.63 mpg average
From Cal to Alaska, Key West, Labrador/Newfoundland and points in between
05 F350 front axle and aluminum wheels 275/70-18 tires.
46 Gal tank - harpooned pump vent tube.
Scangauge. DieselSite Coolant Filter@72K. Fumoto valve. Amsoil dual remote oil filter setup.
176 days in the shop - not counting the 4wd conversion time - Replaced front springs, 2 injectors, Trans housing, 3rd gear, Reverse planetary assy, Turbo, Alternator, another Alternator, Turbo hose fitting, Block Heater, Door lock, Front axle seals - all under warranty. AC hose, 1 injector, Batteries not under warranty.
MikeL46 is offline
Old 03-06-2007, 01:07 PM   #2 (permalink)
Re: Step Bumper on eBay
The standard factory step and tow bumper (chrome or gray) is very strong all around including on the ends where probably most impacts happen. No plastic end caps. And they are rated for 500/5000lbs. I don't think that I've seen this model with plastic end caps. What is the part number?
toalpi is offline
Old 03-06-2007, 02:05 PM   #3 (permalink)
MikeL46's Avatar
My Photos: (14)
It's listed as a 'Service Part' on the box. Label reads:
ONE
9696FG612P
BUMPER-FORD VAN-BLACK
It is a little different from any step bumper I've seen. But, the price is right and I like it.
Mike
MikeL46 is offline
