Old 12-11-2006, 10:15 PM   #16 (permalink)
Re: Successfully installed a 1999 F-350 cluster gauge (with tachometer) in my 1997 PSD E-350 van.
Hi! I would like to do this.How do you match the odometer?
'01 F350 4x4 32,000miles Dec.06 52,000miles Dec.08
CC SRW 6'bed, tow\race chip,aerotank 55gal.
,rancho 9000's,2" edge,285-75-16's
,c-betr,cb radio,exhaustbrake,isspro gauges,AIS,walker btm,aih delete,remote start
'99 E350 15pass, chip,exhaustbrake,tranny&pyro guages,pullrite hitch, 165,000miles Dec.06,replaced waterpump Dec.07@180Kmiles, rebuilt tranny@200,000miles Jan.09
'96 F350 CC 4X4 chip,intercooler,downpipe,pyro&boost guages,transferflow tank(sold '03 @210,000miles)
puttputtwannabe is offline
Old 12-16-2006, 04:29 AM   #17 (permalink)
Probably you have most info from Bill.
If I can answer some specific questions please ask.
BTW, In my case I did not touch the odometer. But it could be taken apart...the one I have is not electronic. The electronic ones need a chip reprogramed.
petty is offline
Old 12-18-2006, 12:44 AM   #18 (permalink)
petty,
Thanks for the reply!
I'm looking to swap a 99 cluster in my 99 van.
Bill sent me his notes on the connector pin swaps he performed installing his 2000 F-350 cluster in his 97 E-350. Looks like only a few don't get changed around.
Can you provide pin swap data for your 1999 cluster (if it's not the same as Bill's)? Also can you provide info on other cluster mods (resistor change, calibrating tach, etc...)?
Anything you could provide would be helpful.
Thanks! Stu
1999.5 E-350 XLT Extended 12 Passenger Wagon 7.3PSD. 100% stock except for dual K&Ns, but looking to change that...
Late99EconoWagon73 is offline
Old 12-20-2006, 01:51 PM   #19 (permalink)
Other than obtaining the cluster and the factory wiring diagrams, I haven't made any further progress towards installing the '99 F250 cluster in my '98 van. I'm trying to locate some extra connectors to plug into the back of the cluster so that I can run the cluster on the bench. My hope is to resolve the oil pressure "idiot" gage at the same time and make it work like a real gage.
If either Stu or Bill could email me Bill's notes on his install, it would be greatly appreciated.
Thanks - andy
1998 Quigley E-350 7.3, Webasto ThermoTop heater, quad batteries, TranferFlow 46 gal tank, BD brake.
astr is offline
Old 12-29-2006, 03:40 AM   #20 (permalink)
Sorry guys, but my diagrams will not help you very much. Almost every year is different. You must make your own diagrams by comparing side-by-side your existing cluster with the one you change.
Some funny setup may be on ABS, where you may have to eliminate a trensistor and some resistors from the flex. board.
On the lights swithed from hot to ground, you must scrape the hot leg from the flex board, and solder a wire from the socket to ground .
The tach could be brought back to calibration by inserting a resistor in series with the existing adjustment pot.
petty is offline
Old 01-06-2007, 02:28 AM   #21 (permalink)
Andy,
I've got Bill's notes in an e-mail for you... Check your PM.
Happy New Year!!! Stu
Old 02-01-2008, 01:06 AM   #22 (permalink)
u2slow's Avatar
My Photos: (20)
Anyone know if the gasser clusters work?
I can find lots of 5.4L clusters. The obvious difference is the 6k rpm tach, and lack of "diesel fuel only". I'm not too picky so long as I can make it work.
95 F350 Crew 5spd/4.10, SuperChips tuner, solid flywheel, T444E waterpump, 205° stat, Locked F&R, 9.00R16 Michelin XLs
97 E350 SRW cutaway, E4OD/D70/4.10, 19.5s on the rear, deep trans pan, batteries inside, 1800W inverter, manual glowplugs
Other rigs I goof around with regularly:
93 F350 4x4, 7.3 IDI turbo, 5spd, 4.10s
90 F250 4x4, 7.3 IDI, 5spd, 3.55s
, D60 swap, straight pipe, turned up fuel screw, 9.00R16 Michelin XS
Other Engines I mess with:
Mitsibishi S6U-MPTA
Mirrlees National KVSSM MK-II
DDC/MTU 12V2000
u2slow is offline
Old 06-02-2008, 10:54 PM   #23 (permalink)
u2slow's Avatar
My Photos: (20)
I got the 5.4L cluster installed. Swapped some pins... all the gauges work now.
EDIT: I found the PCM and tapped into pin 19 (white w/pink tracer). I had leftover grounds after I shuffled the wires in the connectors, so I stole one and spliced it to my new tach wire. Tach works now, but I think its a bit off.
Since I used a gas cluster, I don't have a wait-to-start or water-in-fuel light. Instead, I made the security light work (key with buster sign over top) for the wait-to-start. I trimmed the hole a little to fit a standard dash lamp, and added a jumper to ground the other side of the socket.
Mitsibishi S6U-MPTA
DDC/MTU 12V2000
u2slow is offline
Old 04-27-2009, 03:31 AM   #24 (permalink)
Ears93's Avatar
Does anyone still have the info for this install? I have sent a pm to Madvan and Petty and have had no response. I would like to do this soon. Please help!
Thanks.
Nick
97 E350
Exteneded Cargo
7.3 Stroker
225,000 Miles
Muffler and Cat Delete
Rebuilt trans with updated parts
More to come but I won't bore you with that crap till its done.
Ears93 is offline
Old 04-27-2009, 10:23 AM   #25 (permalink)
What cluster will fit a 96 E350/
Thanks, Dann
My Mods http://community.webshots.com/user/sconure
1996 E-350 , Bean's stage 2 injectors, 3" intake plenums, dual EGT gauge, boost, tranny, fuel pressure gauges.
94 RT10 Viper
96 GTS Viper
98 GT2 Viper
58 MGA
dansk is offline
Old 04-27-2009, 06:32 PM   #26 (permalink)
Thanks, Dann
Dann-I think 99-01 clusters will work.
I just did mine. 99 f cluster in my 03 van. Had to repin most of it, some colors were the same, some were different. I was also able to remove the 600,000 mile odometer and install my original 173,000. It just pops out with a little force.
Everything was working fine for a few weeks, but now my voltmeter is acting up. Seems the bumps can get it to jump around. Just to be sure, I tapped into the red/y wire with a multimeter and drove around for a while, and of course it never happened. AE does show 14.0 v when the gauge is going haywire. So something must be loose.
I did have to cut off the top left mounting ear to get it installed. So now there are only 3 bolts holding it in, but it's not going anywhere.
2003 E-350 7.3, 38R, DIY intake, 4" turbo back, Swamps Tunes, forged rods, exhaust ported heads, comp 910's, h-11's, stealth twin pumps, 300cc hybrids, racerx trans and tc, water injection
rpm1 is online now
Old 04-27-2009, 06:59 PM   #27 (permalink)
03 van connector pinout
rpm1 is online now
Old 04-27-2009, 07:01 PM   #28 (permalink)
01 truck connector pinout
rpm1 is online now
Old 04-27-2009, 10:37 PM   #29 (permalink)
Oh man, a lot of info RPM. Thanks! My project is going slow but the Hders are getting there. Will keep you posted when I have more info and pics.
Dann
94 RT10 Viper
96 GTS Viper
98 GT2 Viper
58 MGA
dansk is offline
Old 04-28-2009, 01:09 AM   #30 (permalink)
Ears93's Avatar
RPM,
Did you have to add or remove any transistors or resistors? I think I've got my pin locations figured out on paper. I just need to know where to get the wire for the tach pin location and the info on the transistors and/or resistors.
Thanks in advance.
Nick
97 E350
Exteneded Cargo
7.3 Stroker
225,000 Miles
Ears93 is offline
