Old 10-24-2009, 03:23 PM   #46 (permalink)
Ears93's Avatar
You guys are lucky. I'm still trying to get my tach freq. Figured out. The 94-97 has a higher freq. Than the 98-02 7.3. I have reead about a couple things to do, but not very detailed though. I too have the ABS light on when the bulb is in along with a problem with seatbelt light and water in fuel light. I have read that you have to remove a transistor or a resistor on the ABS light and switch the polarity on the water in fuel and seat belt light on mine but I haven't seen anything really detailed about it. Other than that everything else works great.
Nick
97 E350
Exteneded Cargo
7.3 Stroker
225,000 Miles
Muffler and Cat Delete
Rebuilt trans with updated parts
More to come but I won't bore you with that crap till its done.
Ears93 is offline
Old 10-24-2009, 05:38 PM   #47 (permalink)
since I did this upgrade i've also upgraded my lighting for the cluster with bright white 3 watt LEDs. The results were very awesome. Helps see things very well at night. Have also fixed the fuel gauge since then too
Last picture is with the old incandescent bulbs.
Eric
Ford 1992 E-350, 6,900 lbs.
Dodge 1997 Ram 3500
Ford 2005 F-350
yaric008 is offline
Old 10-24-2009, 10:02 PM   #48 (permalink)
Ears93's Avatar
Attachment 5421
Attachment 5423
Attachment 5424
Attachment 5425
Attachment 5426
Looks Good!
Is that in your 92 van? What year cluster is that? I'm guessing it is out of an OBS.
Nick
Nick
97 E350
Exteneded Cargo
7.3 Stroker
225,000 Miles
Ears93 is offline
Old 10-25-2009, 01:20 AM   #49 (permalink)
Yeah, it's the 92. The instrument cluster is from a 92 F series. Found it on ebay out of a farm truck. I took the parts from my E series one such as the clean plastic clear cover and the mileage computer thingy and used them in the F series cluster.
Eric
Dodge 1997 Ram 3500
Ford 2005 F-350
yaric008 is offline
