Suspension questions on the E350... - Diesel Forum - TheDieselStop.com
Old 01-28-2010, 12:11 PM   #1 (permalink)
bbasso's Avatar
Question Suspension questions on the E350...
Getting right to the point...
2000 E350 SD
What shocks are the popular/best choice?
How to tell when the springs are sagging or when near done?
I actually like the nice soft plush ride, but know it shouldn't be...
There is a bunch of miles on my van and I think it looks like a low rider compared to some of the lessor mileage ones. Any way of properly checking suspension sag/ droop?
thanks all
Rob.
2005 E350 6.8 V10 SCT by Mike @ 5 Star. WOW!
bbasso is offline
Old 01-28-2010, 12:39 PM   #2 (permalink)
blageurt's Avatar
Not that I know of , Ussually when springs are toasted they crack and or are bent / smiling the other way.... Also if you look art the truck from the back if it leans one way more than the other this is also an indication of wear /overloading. As far as Shocks go it depends on what you like and how much you want to spend and what kind of ride you need. I have Heavy Duty Monroe gas in mine but it is a work truck. I also upgraded the suspension to a Timbrens SES kit which gave me 1500lb more payload and cost the same as adding springs ( $ 300) and I did it in my Driveway in one hour...
Vehicle Suspension Kits - Timbren Suspension Enhancement Systems
95 E350 PSD HD Cargo , BB shim , E4OD , B&M aluminium Trans pan , Twin HD coolers , Cat sleeps with the fishes , 3:55 D70FF, Michelin LTX " E " , DP flashed 60 Tow , 140 V idm , Autometer Triple Pillar Guage pod , New Injector O-rings /IPR /lift pump / filterbowl @ 235K , Timbrens SES kit , replaced lift pump /ICP/ IDM @ 256 K
1977 F350 Dually Dump , 460 , 429 POLICE heads , 4:56 D70FF, Edelbrock Intake , Holley 850 dbl pmper ,MSD IGN , Custom HiPo C-6 Trans , Dual Exhausts , Bridgestone "E" Tires
1983 KZ1000R , Yoshimura Stage I
1982 KZ1000 , 1045 Wiseco , Turbo ready
1990 KX500
blageurt is offline
Old 01-28-2010, 12:43 PM   #3 (permalink)
bbasso's Avatar
mine still work and look ok, no real signs... just me wondering about 765,000+ miles on the springs...
Looking at the link now, thanks
Rob.
bbasso is offline
Old 01-28-2010, 12:48 PM   #4 (permalink)
bbasso's Avatar
After looking at the link, that setup looks like something I don't need. I don't haul that much weight. The normal suspension setup should be ok for 98% of my needs.
so replacements shocks and springs... your thoughts? anyone?
Rob.
bbasso is offline
Old 01-28-2010, 02:18 PM   #5 (permalink)
carringb's Avatar
I wouldn't worry about spring sag until it actually becomes a clearance problem (driveways etc). There's plenty of rear suspension travel in these, bottoming out on the bump stops rarely happens.
As for shocks...
ANY good monotube shock will make a huge improvement in driving, without making the ride harsh. I use Les Schwab RMX monotubes because they have a lifetime warranty (parts and labor... and yes a squishy ride = new shocks).
Bilstein are also good, so are fox. Rancho makes some too. I don't think brand matters too much, as long as they are backed with a good warranty. These vans can go through them fast.
2000 E350 DRW XLT extended wagon (yes! it's a dually!)
17" Ultra Goliath rims
Banks Powerpack, Diablo Predator
Buckstop front bumper, Reunel rear w/ 20,000# reciever
250,000+
carringb is offline
Old 01-28-2010, 05:48 PM   #6 (permalink)
bbasso's Avatar
good monotube shock. gotchya!
Off to find some...
You sure the springs with 765,000+ miles aren't getting un-sprung?
thank you.
Rob.
bbasso is offline
Old 01-29-2010, 09:34 PM   #7 (permalink)
bbasso's Avatar
How does the Bilstein shocks hold up over time on the E350?
Rob.
bbasso is offline
Old 01-30-2010, 10:19 PM   #8 (permalink)
Send a message via ICQ to jerry350
I'm a Bilstein believer and in the rear, Super Springs....I've used several Manf. and Bilsteins in my opinion hold up the best.
2006 Quigley E-350 Cargo 6.0 4.10
2003 F-350 Lariat 6.0 3.73
jerry350 is offline
Old 01-30-2010, 11:46 PM   #9 (permalink)
bbasso's Avatar
thanks
Rob.
bbasso is offline
Old 01-31-2010, 01:01 AM   #10 (permalink)
I like my bilsteins as well since changing out the ranchos that quigley provided. Bilsteins ride better. I have used these for years on older Mercedes diesel cars & they are legendary.
Premier Kirby is offline
