Old 02-13-2005, 04:50 PM   #1 (permalink)
Tail lights on E450
My right turn signal and brake light does not work in the rear of the van, parking light do work. The flasher cycles real fast and the front light comes on. I checked for power, no power, changed flasher unit still does not work. Any sugestions?
06 F250 PSD CC Lariat FX4 Pioneer Avic D2
Novanut is offline
Old 02-13-2005, 05:36 PM   #2 (permalink)
diesel97's Avatar
Re: Tail lights on E450
You have a blown bulb.Check it out.
2005 E-350 SRW CUTAWAY,6.0 DIESEL AUTO,ALLOYS 10FT KNAPHIEDE KUV BODY.SILVER POWER EVERYTHING.
97 F-350 XLT 4X4 7.3 PSD,99K AUTO ,REG CAB,GREEN,NOT STOCK
96 F-250 XLT 4X4 7.3 PSD 220K AUTO REG CAB,BLACK,BONE STOCK EXCEPT FOR A NEW CAR SCENT AIR FRESHENER.
http://community.webshots.com/user/Dzlpwr
#28
diesel97 is offline
Old 02-13-2005, 08:06 PM   #3 (permalink)
NO POWER. I did a resistance check on the bulb. Checks good.Back pined the socket No power
Novanut is offline
Old 02-14-2005, 06:52 AM   #4 (permalink)
diesel97's Avatar
Did you follow the harness along the frame to see if the wire has a short or cut in it?Does it have good ground?
#28
diesel97 is offline
Old 02-14-2005, 06:52 AM   #5 (permalink)
diesel97's Avatar
#28
diesel97 is offline
Old 02-14-2005, 06:52 AM   #6 (permalink)
diesel97's Avatar
#28
diesel97 is offline
Old 02-14-2005, 07:15 AM   #7 (permalink)
Super_Dave's Avatar
E450 Shuttle bus or RV cutaway?
Might have some fuses with the rest of the wiring harness stuff that is part of the conversion.
Super Dave
2003 Excursion Limited 4WD 7.3PSD - Prodigy brake controller, DP Tuner-60t/80e/AIC/exhaust brake, BG drive line fluids, Timbrin rear springs, 203* Tstat, Evans NPG+, coolant filter, Ford Transmission Cure
2007 Buell XB12R Road Racer
Super Dave's Race Against Childhood Cancer
Super_Dave is offline
Old 02-14-2005, 08:48 AM   #8 (permalink)
It is a E450 with a work box, I checked the harness down to where the trailer lights conect to the harness. Is there a generic wiring diagram available for tail light systems? Does the brake lights go through the turn signal switch? If so is there a way to check this ?
Novanut is offline
Old 02-15-2005, 07:19 PM   #9 (permalink)
Super_Dave's Avatar
The brake light and signal are probably on the same wire, assuming that you have an 1157 bulb in back. I'd go back in the harness and find where you have power and work your way back to where you don't.
Box vans are pretty simple, but they have a lot of open area that something can get kicked up. Might just want to check. Hope this helps...
Super Dave
Old 02-15-2005, 10:18 PM   #10 (permalink)
I have found on a lot of the E series cutaways that the rear wiring for the box/bus is on the factory trailer tow circuits.
Excursion Pics
2000 Excursion Limited 4x4 Dark Satin Green Arizona Beige 7.3 DIT, AXDO, 3.73 LS, DP Tuner F5, TERMINATOR II w R-IPR, Adjustable Boost Regulator, Turbomaster, EBPV Delete, Air Dog, ITP Regulated Fuel Return, Fuel Cooler, Tags 1&2, Harpooned Tank, Magnaflow XL Exhaust w Aeroturbine 4040L, Sonnax/Tricumulator, 8 Autometer Sport Comp 4 Gauge A Pillar 4 Gauge Overhead, Ford APCM, Crimestopper Remote Starter With Remote Fast Idle, Ford AIS w Zoodad, W Code Front Modified B Code Rear springs, Rancho RS9000X, Rancho 5406 Stabilizer, Hellwig Rear Sway Bar, BFG Rugged Trail TA, V10 Trans Cooler w Dual Electric Pusher Fans, Coolant Filter, IAH Delete, (((XM))) Line Of Fire Light, Ford Cab Lights, 05 Headlights w GOS Conversion Harness, Jimmi Jammers, 03 Lighted Painted Tow Mirrors w C-BETR, PSD Badges, Pullrite Hitch, Prodigy Brake Controller, Born 01/29/00
fordmastertech is offline
