tank delam? or? what mods while out? - Diesel Forum - TheDieselStop.com
Old 03-08-2007, 11:52 PM   #1 (permalink)
SIC-E's Avatar
poor search skills/results so:
told my knuckleheads to pump old fuel out of tank (450 not driven), & dont reuse it!!!. they put it in my lull forklift! SO MUCH garbage in fuel had big job mopping-out lift tank, filters, fuel pump, etc. fixed now.
dropped 450 tank and still little garbage. is this what refered to as tank delam?(or what is t-delam?) or did i just get super nasty fuel in the only 900 miles i've driven it(ya'll got me scared of it, lol)?
what to do with tank itself while out, to clean or? ? what mod.s while out? what to expect/do re:filters etc. on 450? thanks
rich
2004 E450 Cutaway, 6.0L, quigley 4x4, ambulance pkg., maxbrake controller, curt 20k fifth wheel. Future mods: 52" sleeper, tandem (6x6?) rear (aint look'n likely), frame cover. maybe a Herd front bumper.
2003 E350, 7.3l, x-cargo
2003 F350 Lariat, 4x4, CC, SRW, Dark Green Fx4 SOLD
1995 C3500 6.5l work trk, 2x4, CC, DRW, white DECEASED PREMATURALLY
2003 JEEP WRANGLER, ooooops, not anymore!
1986 26' Seaway Northstar w/ 454 Mercruiser
2008 Montana Mountaineer 332PHT
1991 GMC Topkick, CAT, 4' vert. gang boxes, 12' dump. if only all were as reliable!
SIC-E is offline
Old 03-09-2007, 11:03 AM   #2 (permalink)
My Photos: (9)
Re: tank delam? or? what mods while out?
If you are concerned about tank delam, you could always have the tank boiled out by a tank-cleaning outfit for relatively cheap. While the tank is out you may want to shorten the fill neck tube so the tank will "fill-fuller" before foam shuts the pump off. This is known around here as the "Harpoon mod" (invented by the guy with that name). There are other things that could be done inside, but they're a lot more involved... Others may chime in here.
2001 E350 PSD, Deep Emerald Green, 3.55 LS, Premium package, dual alts, rear A/C. Quigley 4x4, Transfer Flow rear tank (27+26), handicap mods, custom interior, Reunel tire carrier w/ Hi-Lift, Sportsmobile nerf bars (black), Amsoil lubes and Dual-Gard bypass oil filter, Amsoil air filters, Eclipse/JL Audio sound system w/ Sirius & 120GB Neo Car Jukebox (MP3 player), J&J stainless grill, Reunel Stainless bumper, 12000# Warn winch, PIAA lights, Bilstein shocks, Ultra Magnum wheels, Michelin tires (265/75-16), Correctrack rear wheel spacers, Bushwhacker flares (painted), Velvet-Ride spring shackles, p/s filter, external tranny and coolant filters, Autometer gauges(5), Optima Yellow Tops, Airdog.
msnunes is offline
Old 03-09-2007, 02:01 PM   #3 (permalink)
MikeL46's Avatar
My Photos: (14)
You might consider replacing the tank with a Transfer Flow 46g tank. And while you do the exchange, put a hole in the vent tube (harpoon) to allow it to be filled to near the top.
Mike
D70 Full floating rear axle from a cutaway van
140A Alternator. 125W solar panel. Sportsmobile off-road trailer.
96,258 miles. 16.63 mpg average
From Cal to Alaska, Key West, Labrador/Newfoundland and points in between
05 F350 front axle and aluminum wheels 275/70-18 tires.
46 Gal tank - harpooned pump vent tube.
Scangauge. DieselSite Coolant Filter@72K. Fumoto valve. Amsoil dual remote oil filter setup.
176 days in the shop - not counting the 4wd conversion time - Replaced front springs, 2 injectors, Trans housing, 3rd gear, Reverse planetary assy, Turbo, Alternator, another Alternator, Turbo hose fitting, Block Heater, Door lock, Front axle seals - all under warranty. AC hose, 1 injector, Batteries not under warranty.
MikeL46 is offline
Old 03-09-2007, 02:11 PM   #4 (permalink)
My Photos: (10)
This
http://forums.thedieselstop.com/ubbthrea...e=0#Post3259962
Bill
MADVAN is offline
