Old 08-08-2008, 06:42 PM   #1 (permalink)
For those who have installed dual alternators
Is it possible to mount just one alternator towards bottom of engine? Is there a seperate bracket for just that one?
I would like to make room on top and mount a single on bottom
Thanks, Dann
My Mods http://community.webshots.com/user/sconure
1996 E-350 , Bean's stage 2 injectors, 3" intake plenums, dual EGT gauge, boost, tranny, fuel pressure gauges.
94 RT10 Viper
96 GTS Viper
98 GT2 Viper
58 MGA
dansk is offline
Old 08-09-2008, 12:28 PM   #2 (permalink)
No one with input?
94 RT10 Viper
96 GTS Viper
98 GT2 Viper
58 MGA
dansk is offline
Old 08-14-2008, 11:59 PM   #3 (permalink)
BlizzardVan's Avatar
My Photos: (18)
This was the route I planned on going to make room for intercooler plumbing. I have a ford pully that could be welded on a small plate and then bolted to the top alt bracket. Was hoping the regular serpentine belt would then work. Still haven't gotten around to doing the intercooler. But it is on the list.
Hypermax stage 2 injectors, 4" intake with Ram scoupe, QSSB Turbo, Snow Meth inj, BTS trans no spacer, Salem Kroger 4x4, Sway and traction bars, APX drivers seat, 4" straight exhaust & DP, 4" lift, 18" wheels with 325 nittos, custom valve Bilsteins, DP PCM and F5
...Stuff to make it almost as fast as a pickup.
BlizzardVan is offline
Old 08-15-2008, 11:18 AM   #4 (permalink)
Intercooler is my thought at this point. Can you use the amublance bracket and mount one alternator on bottom? That would be the ideal.
Dann
94 RT10 Viper
96 GTS Viper
98 GT2 Viper
58 MGA
dansk is offline
Old 08-15-2008, 04:27 PM   #5 (permalink)
My Photos: (9)
I have factory dual alts -- and I think the lower one (at least) is physically smaller than the standard upper (or single) one. Not sure if a smaller one alone is enough to run the truck.
2001 E350 PSD, Deep Emerald Green, 3.55 LS, Premium package, dual alts, rear A/C. Quigley 4x4, Transfer Flow rear tank (27+26), handicap mods, custom interior, Reunel tire carrier w/ Hi-Lift, Sportsmobile nerf bars (black), Amsoil lubes and Dual-Gard bypass oil filter, Amsoil air filters, Eclipse/JL Audio sound system w/ Sirius & 120GB Neo Car Jukebox (MP3 player), J&J stainless grill, Reunel Stainless bumper, 12000# Warn winch, PIAA lights, Bilstein shocks, Ultra Magnum wheels, Michelin tires (265/75-16), Correctrack rear wheel spacers, Bushwhacker flares (painted), Velvet-Ride spring shackles, p/s filter, external tranny and coolant filters, Wicked Wheel, Autometer gauges(5), 203 thermo, BRV+, removed air intake heater, Optima Yellow Tops, "Harpoon" mod, DP-Tuner, 4" exhaust w/ Aeroturbine, Airdog, HX-mod.
Next on the List: a blown tranny!
msnunes is offline
Old 08-15-2008, 08:25 PM   #6 (permalink)
Thank for the info. I don't want dual alternators, just one. If I could mount the one I have on the bottom that would be ideal. Is the bracket you have one or two brackets? Is the idler on the top or bottom bracket? Also, if one was to mount the alternator on bottom, could there be a serpentine belt that would fit the new configuration. I have the part number for the ambulance package alternator bracket, but don't really want to buy unless I know it's gonna work. I have her apart and I'm going to do everything I can to get an intercooler in there.
Dann
94 RT10 Viper
96 GTS Viper
98 GT2 Viper
58 MGA
dansk is offline
Old 08-15-2008, 10:11 PM   #7 (permalink)
Hey nsnunes, is your bottom alternator smaller in size or just smaller amperage output. In other words, will the top alt. bolt on bottom bracket?
Dann
94 RT10 Viper
96 GTS Viper
98 GT2 Viper
58 MGA
dansk is offline
Old 08-16-2008, 06:33 PM   #8 (permalink)
My Photos: (18)
The top altenator is the pully so if you want to re route you will need to fab up a small pullyand bolt it to the same bracket that held the ALT. This is why I kept a small Ideler pully.
Old 08-16-2008, 08:43 PM   #9 (permalink)
Hopeing to get some pics of the set up, that would help a lot.
94 RT10 Viper
96 GTS Viper
98 GT2 Viper
58 MGA
dansk is offline
Old 08-18-2008, 10:15 AM   #10 (permalink)
My Photos: (9)
Dann
I believe they are different size, and possibly power output. Not sure how much.
msnunes is offline
Old 08-18-2008, 12:48 PM   #11 (permalink)
88beast's Avatar
yes you can fab one up to do that but you have to remember a few things
one it must turn the same way or else itll work in reverse (motor not generator)
and it must be heat sheilded down there that close tothe block
also a dual would be smaller id use 3/8 plate and make a mount that bolts to the oil pan bolts and maybe a bolt on the front of the block
then add an idler pully to tighten it up
88 F-250 body,550 rear frame setup, 7.3 idi, 3:73 dana 80 rear, srw, dana 50 front, heavy duty leaf springs, back up camera, 20$ wallyworld fog lamps, class 5 bumper hitch welded to frame and gusseted, 32" steering tires all around, ac power converter,jeep bucket seats, deezee runningboards (cab only),cobra 29 cb w/ 102" whip, 2 trucklight worklights on front stake pocket each side,high lift jack behind seat, toolbox for the junk, visor, running lights, 6600 lbs with all my junk
http://youtube.com/watch?v=ILAQuHNAGE0
i plan to add propane kit, stake body bed, gn hitch,western style mirrors, and a lot more
88beast is offline
Old 08-18-2008, 09:36 PM   #12 (permalink)
Dansk-I have the ambulance brackets if you decide you need them.
2003 E-350 7.3, 38R, DIY intake, 4" turbo back, DP Tunes, forged rods, exhaust ported heads, comp 910's, h-11's, stealth twin pumps, 230cc hybrids, racerx trans and tc, water injection
rpm1 is online now
Old 08-18-2008, 10:31 PM   #13 (permalink)
Iv'e been looking at my setup and there is no way to have room for the top alternator to mount on the bottom. Just not enough space. On top she sits back from the front of the block and I just can't see there's enough room on bottom. Fabricating a bracket is not a big deal for me but I don't see the OEM to be mounted on bottom. Anyway, I'm now thinking of a slimline or steamline alternator that can put out the amps like the OEM to mount on bottom. Somehow I need space to get an intercooler in there. Any suggestions would be appreciated or if there is a shorter alternator out there that would work, please let me know. I have her torn down now and if it takes 3-4 months of R&D, I don't care. I want to exhaust the options and pass them along on this site. Headers are definately going on in a month and there will be a jig made to copy. Just getting started.
On a side note, I got the broken glow plug out. I will post do's and don't about glow plug removal if anyone is interested. Gonna install my Stage II's this week. Making all the room in the engine compartment I can. I can see moving things around, making new brackets for glow plug relay and whatever is in the way.
Dann
94 RT10 Viper
96 GTS Viper
98 GT2 Viper
58 MGA
dansk is offline
