Old 02-18-2007, 10:38 AM   #1 (permalink)
My Photos: (14)
Time For Brakes- Any Suggestions
Well time for at least front brakes and possibly rears. Close to 40 k on the brakes the dealer did just before I purchased it. Been experiencing DTV (Disc Thickness Variation) for a while, don't want to be chastised for saying my rotors are warped. Also starting to hear rthe chirpers.
Read through some of the Brake threads in F forums, Frozen Rotors, Performance Friction, Etc. So what seems to work well on the vans?
How about the service manual recommendation for turning the rotors on the vehicle, is this absolutely necessary? They were turned at 29k, so not sure if they are still servicable any way.
Thanks in advance for any advice!
ddog
While I love diesels, I don't need one, and unfortunately, after much deliberation its a hobby I currently cannot afford.......... Gone but not forgotten:
1999.5 F250 CC SB XLT 4WD, 7.3 PSD, First F,2nd Diesel, nice but still liked the van better.
2003 E-350 Super Duty Chateau (Club Wagon)7.3PSD, 3rd Clubwagon,First diesel, Never should have sold it....
ddog is offline
Old 02-18-2007, 12:40 PM   #2 (permalink)
XRACER's Avatar
Re: Time For Brakes- Any Suggestions
I've only been driving for 33 years, but in that time I've never had a set of rotors turned that came out perfect. Those lathes must be calibrated with a sledge hammer. I wouldn't be surprised if your DTV issue is dealer related.
In all my years of racing (bikes....mind you.....) I always just changed the pads when they turned into potato chips, and replaced the rotors when they got too thin. Of course, they were full floating rotors, but floating or not, you know when they're warped.
Buy new rotors, and change the pads more often.
Just my 2 cents.
2005 E350 Standard Cargo Van, 6.0 PSD, 4.10 L.S., Quigley 4X4 New on 11-18-05
(seems to manufacture oil....1 Qt per 4000 miles)
Warranty Turbo 7-07 22,000 miles
Warranty A/C compressor 10-07 25000 miles
2003 E350 Extended Cargo Van, 7.3 PSD, 3.55, Quigley 4X4 New on 2-1-04
Some Pix
Transfer Flow 46 Gal.***Delaminated***Replaced 8-29-06 UNDER WARRANTEE
XM Radio, Alpine GPS Nav. System
7.5' Western Snow Plow
Quad Captain's chairs and Espar Furnace
OX cable locker on front
ARB locker on rear
BTS Tranny 9-29-07 @55,000 miles
Aluminess Bumpers
Mile Marker 12,000 pound hydraulic winch
2000 F250 ...... just cuz people are dumping them for the fuel bill. Got mine on ebay for $8749 with 116K on the clock. Go-fast mods to follow.....
XRACER is offline
Old 02-18-2007, 01:28 PM   #3 (permalink)
Someone here (Aceman? iirc) have had good experience with ART brakes.
http://www.appliedrotortechnology.com/
98 E350 PSD Cargo "Under construction"
F5 DP Tuner (10 pos)(mounted on a-pillar) w/pane files -PS 2000 -SC 1705 (code reader) - Snow stg 2 - 3xUltraLites in a-pillar - 3x UltraLites on dash -4"Magnaflow (15970)turbo/back -4" DIY AFE intake -ITP overboost kit. Detroit locker.
And the hottest mod so far: Tranny built by RATS, BIG thanks to Ole Ringstad
TC lock-up switch, Jingle bells killed, Excursion gauge cluster (tack).
Waiting to be mounted: roll cage, Two garret gt3782bb - real twins.
Working on: brackets to relocate alternator, sidepipes. AC and vacuum pump delete (for space)
Headers, and a second HPOP
437/1116Tq Dyno
PICS: http://community.webshots.com/album/346517884jXrDba
70' Mustang FB 408 stroker... Is it possible to sqeeze a PSD into this one? Hmmm
oystein is offline
Old 02-18-2007, 01:38 PM   #4 (permalink)
My Photos: (13)
I have slotted type (gas relief) on my van. Work well and fair priced.
Most of the rotors are machined from oem rotors.
http://www.sp-performance.com/SPhome.htm
Last post from Ace was back in 9-7-05
Bill
97 E-350 Quigley Van Picts
Supporter/User of THE CURE E4OD/4R100 Transmission Control
WWW.FORDTRANSMISSIONCURE.COM
TO RENT THIS SPACE SEE YOUR ADMINISTRATOR
ads@thedieselstop.com.
MADVAN is offline
Old 02-18-2007, 03:26 PM   #5 (permalink)
My Photos: (17)
I am still running my stock, unturned rotors after three pad changes on the fronts. The rears just got done last month.
Recomendations:
Both front and rear: Get a good impact gun to remove the bolts holding the caliper brackets on and don't forget to loosen the caliper to caliper bracket torx bolts first.
Rears: if you have a full float rear axle ( with disc brakes), get some new axle gaskets and make sure to check the drum-in-hat parking brake assembly...much easier to do when everything is already up and 75% disassembled already.
youngster
[img]/ubbthreads/images/graemlins/cool.gif[/img]2001 E-350 SuperDuty<font color="green"> 2wd Sportsmobile, <font color="green">BTS Trans, <font color="green">ITP VAN SPECIFIC fuel system mods,3.5" DP with 4"exhaust, 3 pos "Bill's" chip, Autometer Phantom gauges, Baldwin pre pump filter assembly, <font color="green">Reunel bumpers, Warn 9k winch, PIAA lights, Goodyear Wrangler AT/s tires (265/75 R16), Firestone airbags, <font color="green">Con-Ferr roof rack, Bushwacker Fender flares, <font color="green">Correctrack rear wheel spacers, Rancho 2" lift, </font><font color="orange">PHOTOS</font>
youngster is offline
Old 02-18-2007, 04:12 PM   #6 (permalink)
I've done well with Hawk brand "Super Duty" brake pads. They have an aggressive compound that improves braking. The only drawback is every few weeks they will squeal for a few stops.
For my rear drums I use "heavy duty" semi metallic linings, many of the brake manufacturers make them although the parts stores don't carry them.
As far as I'm concerned you shouldn't turn rotors unless they are warped or heavily glazed. The reason the shops push turning is that it gives you a "factory fresh" braking. Basically they don't want customers complaining that there's a little squeal etc.
I haven't turned any of my personal rotors since the mid 90's.
*ASE Master Certified, Medium & Heavy Trucks*
Mr_Roboto is offline
Old 02-18-2007, 11:35 PM   #7 (permalink)
I was under the impression factory pads were best. After reading many post (&amp; in F forums), it seems many are getting 100k miles outta factory pads. I know my E350 15 passenger extended gasser has 100k miles on them &amp; still look like they could go another 25,000 easy. I always thought the factory repackages them &amp; doubles the price.(from Bendix or whoever). Could they have exclusive rights on pad formulation? I may have to do my psd soon cause I hear a noise.(I hope it is the wear indicators)
1999 E350 7.3psd , XLT , 15 pass/ext , purchased 6/6/05 w/255k on odo, 8/05 added BTM/straight pipe,5/06 BTS,1"shimmed front coil springs,Michelin XPS 235/85 16 R.,FredGroeske2"rear wheel spacers,1-1/2" rear sway bar,AIC,3 A-pillar guages, Tekonsha envoy,coolant filter,4 pos dp-tuner,In-tank mod & harpooned,dahl-100 prepumpfilter,Scan-guage,Bilstein shocks.
bork is offline
Old 02-19-2007, 12:48 AM   #8 (permalink)
blageurt's Avatar
Brembo are expensive but they are quality rotors and calipers. Some say they are the best. If you can afford it go wild. If not I've heard Ceramix brand pads from Napa stop the beast quite well. As far as rotors go I've always used Napa in the past.
I only put Brembos on my dump Dually because I overload it regularly and the stock system could not handle the stress and heat due to the extreme weight.
95 E350 PSD HD Cargo , BB shim , E4OD , B&M aluminium Trans pan , HD cooler , Cat sleeps with the fishes , 3:55 D70FF, Michelin LTX " E " ,Not installed yet DP flashed PCM (60 Tow )Autometer Triple Pillar Guage pod , New Injector O-rings /IPR /lift pump / filterbowl @ 235K
1977 F350 Dually Dump , 460 , 429 POLICE heads , 4:56 D70FF, Edelbrock Intake , Holley 850 dbl pmper ,MSD IGN , Custom HiPo C-6 Trans , Dual Exhausts , Bridgestone "E" Tires
1983 KZ1000R , Yoshimura Stage I
1982 KZ1000 , 1045 Wiseco , Turbo ready
1990 KX500
blageurt is online now
Old 02-19-2007, 10:38 AM   #9 (permalink)
My Photos: (14)
Thanks for all the responses [img]/ubbthreads/images/graemlins/smile.gif[/img] I'll need to take the wheels off and see just what's going on and how bad things are.
The dealer brake job ( I didn't pay for it, they did the front brakes before putting out on the lot for sale) was pretty good I guess, It was braking straight with no wobble for at least the first 20k miles or so, gradually started getting DTV (warping).
Rear is disc brake semi floater, anything special about that?
Bill, did you get your SP Performance stuff locally or from a sponsor? no pricing on the link.
Colin, How many miles on your OEM Front Rotors, How many miles between pad changes?
If I can find a quality shop (machine shop, not Advance Auto, etc)to turn the rotors, anyone think that's an option or just replace them at this point?
Thanks,
Derrek
ddog is offline
Old 02-19-2007, 11:18 AM   #10 (permalink)
My Photos: (13)
Local
Paid 150.00 for both. I used the oem pads.
If you cannot find locally, I think they are available thru Jeggs/summit.
Bill
MADVAN is offline
Old 02-25-2007, 12:55 AM   #11 (permalink)
Well I got the front &amp; rear pads from dealer for around $156.00. My front is making a noise. Started around 4:00 on driver front(noise maker) found inside wearing thru pad at rear of pad cause caliper piston is pushing out crooked.(boots ripped &amp; piston caps bent) Of course too late for dealer so I got Advance Auto parts store(Cardo brand rebuilt)Really dont care for their stuff, but I 'm in a jam. also decided to repack wheel bearings. &amp; glad I did. past due. Needless to say, about 10:00 pm, one side done.(did I mention I had to drive another 9 miles south to another parts store to get another caliper?) the 2 at original store was really only one cause when I opened 2nd box to inspect, it had an old core in it. &amp; as luck would have it, that was the driver side I needed.
bork is offline
Old 02-25-2007, 09:24 AM   #12 (permalink)
My Photos: (14)
Bruce-Lube the slide pins well and change your brake fluid (all of it)Stuck/sticking hardware is what gives you uneven wear. Its hard to get the fluid out of the van master cylinder, but suck out as much as you can, fill with fresh fluid, start at RR(furthest from MC) bleed till clean, refil M/C, got to left rear,bleed till clean, go to right front, etc, go to left front.
With the Florida humidity, should be changing brake fluid at least every two years. Put 2x4 or something similar on the floor under the pedal so you don't overstroke the master cylinder piston when pumping brakes.
Haven't taken a look at mine yet. Pricewise it looks like I might try rotorpros- 4 slotted and plated rotors and low dust pads for $350 shipped (rotors $270,pads $80) tough to beat, haven't seen any problems reported here yet from people that have them.
Bill- Tried SP-Performance, using their dealer locator, they sent me a dead link first, then sent me a second link and said to do a search on SP-Performance....... apparently no local dealer for me... Online pricing is no where near what you paid, almost double like 130.00 each.
I'm sure the rotorpros are import sourced, almost have to be for the price. Not keen on buying imported if I an help it, but the much talked about (for quality, by FMVRT) domestic Wagner Rotors (in F-Forums) are pretty pricy in my neck of the woods, couldn't seem to get anyone to give jobber on them and the counter price for just the fronts was around 180.00 each.
Won't get a look at them this weekend(side job) or next, going camping/ATVing next weekend at Croom. Will keep you posted...
Derrek
ddog is offline
Old 02-25-2007, 01:14 PM   #13 (permalink)
Well dang. I tried for a while to find slotted rotors for my van but i could never find any. All i would find is slotted and drilled for dually E-series. I ended up getting the brembo rotors because mine were warpped. Got part numbers or something on those slotted ones you are going to order?
Eric
Ford 1992 E-350, 6,900 lbs.
Dodge 1997 Ram 3500
Ford 2005 F-350
yaric008 is offline
Old 02-26-2007, 12:02 PM   #14 (permalink)
My Photos: (14)
www.rotorpros.com I had to e-mail them for a price, they emailed me back with price above, no part numbers. The Sp-performance rotors that Madvan linked above, there's no local dealer for me, but there are part numbers on their website. They have a variety of internet distributors but so far are more money than the rotorpros.
Tough thing about buying brakes over the internet is you can't stand in the store and compare/inspect brands in your hands for quality, etc.
The "better brakes" thread has some good information, I think its in U&amp;A general.
ddog is offline
Old 02-26-2007, 12:24 PM   #15 (permalink)
My Photos: (13)
dog
My rotors are less expensive due to i only have rear wheel ABS. Also not the same part# due to 4X4. I have f-series rotors.
Will PM you on info when i get it. T54-031/MD-655
Bill
MADVAN is offline
