Time for new tires Suggestions? - Page 2 - Diesel Forum - TheDieselStop.com
Old 08-25-2005, 09:49 PM   #16 (permalink)
Re: Time for new tires Suggestions?
I have revos on now and they handle better in all conditions than the stocker ht's did, they are a little louder though. Don't know how long they will wear yet. My boss just put some newly designed Goodyear wranglers on that are advertized to be quite civilized and have a supple ride. He confirmed it, so they might be worth a look.
'01 E350 PSD ext 3.55 LS,BTS,Jody 4pos. custom,PS2000,ATS housing,WW,TAG-3,van turbo adapter flange,4" D.P.,EPI-flex,Walker Megaflow,IAH plug,Amsoil airfilters,Tru-cool Max cooler behind J&J grille,Riley atf,coolant filters,Evans NPG,Bilstien,IPDswaybars,Performance wheel spacers,Weld,Dueller AT Revos,light harness w/diode,Silverstars,ttm,Autometer,SPA,Isspro,TC lockup sw.
tyamabro is offline
Old 09-01-2005, 06:19 AM   #17 (permalink)
I have run more different tires than I can remember on my vans...
I will give you this:
I ran some Kumhos from tire rack and loved them for traction and price, but they seemed to wear fast and 2 have separated after only 9k miles. They are all terrain and were 87 bux each. They worked great on beach sand around here.
While fighting with Kumho over warranty, I replaced them with Goodyear AT/D2s from Sams. These are billed as an all terrain tire, but the tread is much more road than off road, especially compared to the very aggressive Kumho treads. I like them very well on the highway and the price was great. I haven't had an off road test of them yet.
I keep 80 psi all around... always have, right or wrong.
Hope this helps
Dave
Edit: If I was to go to Sams and get these Goodyears again, I would get the same tire in 265. They were actually a couple bux less per tire, but I didn't notice until they were almost done mounting the 245s.
Thomas Jefferson:
"The democracy will cease to exist when
you take away from those who are willing to
work and give to those who would not."
ratio411 is offline
Old 09-01-2005, 07:13 AM   #18 (permalink)
Mastercraft Courser HTR tires. They're made by Cooper, but less expensive than the cooper brand. They're very quiet, and good when it's wet.
"Nothing in life is so exhilarating as to be shot at without result." - Sir Winston Churchill
May your road stay clear & dry, may your fuel never gel, and may you never be outsmarted by your idiot lights.
2002 F-250 XLT SC LB 4x4 7.3PSD 6-Sp 3.73 L-S, Snugtop Snuglid Tonneau, 235/85 MC HTRs, <span style="color: red">DPTuner F5</span> AFE Stg II, Turbo LifeSaver, MAP BRV, Autometer Cobalts, Magnaflow 4", WW, TAG, AIH del, CCV, AirDog, In-tank, Harpoon, HPX, ITP fuel sys, LL8 del, 203*, Oilguard & SP Diesel bypass filtration, ART rotors, PFC pads, Heater Core Ctl Valve, Bilsteins, Velvet Ride Shackles, South Bend Clutch, <span style="color: green">21.27 mpg</span>
2004 <span style="color: red">E</span>-350
XLT Wagon 6.0PSD 3.55 L-S TDM EZ-Entry 11 pass., AIC, custom MBRP 4" w/dual Aeroturbines, Airdog, harpoon, Overhead Cobalts
Pictures . . . Parts Links
DarthSurplus is offline
Old 09-05-2005, 05:00 PM   #19 (permalink)
I just purchased 4 Goodyear Wrangler Silent Armor tires for my van.
$750.00 installed (includes tax) with tire hazard warranty on all tires,valve stems and high speed balance.
http://www.goodyearwrangler.com
They state you will get 50,000 miles on these tires or they will pro rate them.
I had Wrangler RTS tires before these and they gave me 43,000 miles.
2000 E-350 Van,BTS Tranny,Custom Dana 80 Axle w/ ARB & 3:55 Gears, Swamp 175cc Injectors, Custom 4 Position Chip,TS Billet Intakes,W/Wheel,PS2000,Magnaflow 4" Exhaust,ITP Fuel Regulator,4 gauge pillar post,TTM,CTI Idle Controller,Amsoil Fluids,Evans,203 Thermostat,Coolant Filter,J&J S.S. Grill,Art Rotors,Custom Flame Job,Road Armor Bumper,Warn M15000 Winch,Bushwacker Flares,Bilstein Shocks,Centerlines,Maghytec Covers. dynoed at 345.5 rwhp
FUTURE MODS: Upgraded turbo, HD oil pump,Intercooler with water injection.
http://community.webshots.com/user/aceman116
04 Jeep Rubicon
RE 5.5" Long Arm Lift,1"body/eng.lift,Banks Header/ Exhaust,37" IROKS,Mickey Thomson Classic 2 beadlocks,Road Armor Bumpers,Warn 9500TI winch,Alloy Usa axleshafts,CTM u-joints,Nth degree oil pan skid,Clayton front high clearance brackets,Toys by Troy crossover steering,Poison Spyder Rock Sliders.
Aceman is offline
Old 09-20-2005, 11:19 AM   #20 (permalink)
I have 50K on a replacement set of REVO'S and I love them. Should go over 60K for sure. Will get another set from the Tire Rack when it is time. And this time I will go for the 265's instead of std 245's. [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
oldhampete is offline
