Tire size question - Diesel Forum - TheDieselStop.com
Old 09-13-2005, 03:55 PM   #1 (permalink)
Tire size question
I have an '89 E-250 with 4.10 rear. The stock optional tire size is 245/75-16 with a 30.47" OD. I have a '86 F-250 with 235/85-16 tires with a 31.73 OD. The F series has a 3.55 rear and I think the RPM's are too high at highway speeds as it is. I haven't yet driven the van but I imagine the 4.10 rear is going to make the engine scream at 65. Any chance I could use the same tire on the truck on the van. It's bad enough it has the higher gears but with smaller tires it is even worse. Once apon a time, in it's 170,000 mile life, it has a Gear Vendors on it. Wish it still did, but for now just wondering if I could fit the larger tire under there without any problems. Any opinions appreciated. The search feature didn't yield any results that would help me.
Thanks,
Doug
'86 F-250 4x4
'89 E-250 ATS
Doug Bensen is offline
Old 09-13-2005, 08:24 PM   #2 (permalink)
Re: Tire size question
On the front they may make incidental contact up inside the fender well in a couple of places when fully bottomed out but none of the contact points are sharp and it will not cause problems. I used to have 265/75-16 (31.7") on the front of an 87 E250. In the rear there is plenty of room.
1994 E-350 RB 5.8gas 4X4Quigley cargo 4.09 arb-locker f/r 35x12.5-16.5 or 285/75-16.,,, 1997 E-350 EB 5.4gas 4X4Quigley Sportsmobile camper 4.10 arb front, L/S rear 285/75-16/front 33X12.5-16.5/rear ><>J
toalpi is offline
Old 09-13-2005, 08:30 PM   #3 (permalink)
I run the 235/85R16's on 7" rims on both my 92 E250 and my 94 E350, with no clearance issues. I really prefer the tall, narrow tire.
Of course the body / frame etc is different on your van... so clearances may be different.
*ASE Master Certified, Medium & Heavy Trucks*
Mr_Roboto is offline
Old 09-14-2005, 10:27 AM   #4 (permalink)
Toalpi,
The diameter of the tire you were running and the 235/85-16 are the same. When you were running that diameter tire is that when you had the occasional rubbing with no damage. I guess what I could do is swap the tires off the truck and put them on the van to see how thing work out, but man, that would be a lot of work. Thanks guys, for helping me out.
Doug
Old 09-14-2005, 01:32 PM   #5 (permalink)
Yes it was with the 265/75-16 up front. I never heard or felt any rubbing. I could see the evidence such as black marks and scuff marks "up in" a few places. But this is only going to happen when on very uneven terrain when the tire is turned and fully stuffed up. I suspect most of it happened when offroad. It was a 2 wheel drive van but it spent plenty of time off road with 33X12.50-16.5 tires on the back. The rear fender and springs needed some "adjustments" for 33's.
toalpi is offline
Old 09-15-2005, 06:34 PM   #6 (permalink)
e444's Avatar
i have 265/75/16 on 8in rims on my e350 but i put moog cc860 springs on the front wich lifted it 1 3/4 in and that took care of rubbing issues and of course an alingment
2002 e350 power stroke former patty wagon egt boost tach gauges walkers btm diy intake 130k miles dp tuner f5 80e 100 140 extreme overboost annihilator 410 gears
e444 is offline
Old 09-16-2005, 01:11 PM   #7 (permalink)
I still haven't made up my mind. It seems like the extra 1 3/8' OD can make a difference. I wouldn't have guessed it would have been that close. I guess the only sure way would be to put my tires on from the truck and go for a ride. That sure is a lot of work but probably worth it. Thanks,
Doug
