Tires - Diesel Forum - TheDieselStop.com
Old 02-25-2003, 09:54 AM   #1 (permalink)
Tires
Time to get some new tires. My stock Goodyear Wrangler HT's performed well except I only got 32K miles. Good even wear just didn’t last long.
Went through the “ <font color="blue">E350 what tires have worked best for you?</font>" thread but am wondering if anyone has experience with the Toyo <font color="blue">Open Country A/T</font>?
This tire has the exact dimensions of the <font color="blue">Wrangler HT</font>.
Any comments?
Rob
2000 E350 PSD Converted Cargo. All the options, 3.55 LS, A Pillar ISSPRO EGT (Pre-Turbo) & Tranny Gauges, Prodigy, Mag-Hytec Diff Cover.
E350PSD is offline
Old 02-25-2003, 04:40 PM   #2 (permalink)
Re: Tires
Whoa, [img]/ubbthreads/images/graemlins/frown.gif[/img]
I have 31K on my OEM GY-HT's and they look great! Unless they go south in a hurry, I'm hoping for 50K.
Pulled a trailer about 20K of that 32K.
I rotate them every 5K....... by hand with a torque wrench...a real PIA project but it does spread the wear to 5 tires and I'm not worrying about some garage jockey with an air wrench warping the rotors or the wheels.
I don't have a steering stabilizer or anything.
Was the wear even?
Have you checked a price on the Michelins?
The search feature on this web site should turn up a bunch of posts.
Let us know what you decide.
Yardbrew
ON EDIT: I run 80 lbs all four tires. Probably a no no, but I don't know any better.
America....love it or leave it
02 E350 PSD Cargo with windows/power/CC/3.55 LS/Prodigy/Reese WD & Dual Cam/....from Cochise
Van Color:Gray--Bumper Color:Gray--Wheel Color:Gray--Hubcaps:metallic--Tire Color:black--Grill Color:gray plastic
I pull a 1987 Wells Cargo Express Wagon (20 ft)
Yardbrew is offline
Old 02-25-2003, 05:18 PM   #3 (permalink)
My Photos: (11)
Re: Tires
Hmmmmm,
I'm having the same experiences as Yardbrew on my OEM G/Y HT's. I have 25K on them now with over 12K towing where my rear axle wt. runs 5K to 5.5Klbs and like Yardbrew I do a 5 tire rotation every 5K miles. I expect maybe 60K out of them based on what they visually look like now. 32K sounds really low. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
ON EDIT As far as pressures, my Van runs around 7500 unload with the front to rear weights within 200lbs of each other and in that config I run 55psi all around. Towing I run 75-80 rear and 65-70 front and my Van then comes it a just under 9Klbs fully loaded, 55gal fuel, two passengers, etc.
Larry
<font color="green">MY PICTURES - Look around ... lots of good stuff </font>
2001PSD(PCM:HPI2)SD E-350,Dk Emerald Grn,4.10LS, <font color="blue">Mustang dyno - 183.9/400.4 stock</font> [img]/ubbthreads/images/graemlins/smile.gif[/img], BTS w/Schaeffer's ATF[img]/ubbthreads/images/graemlins/biggrin.gif[/img] , ITP 3.5"/4" exhaust w/Magnaflow & Aeroturbine,Dieselsite 203* T-stat/Zerex G-05,F.Pwr, Ext/Int. Upgd. pkg,R. Bds,AIC,Tow Pkg, Rear & Slider windows,<font color="red">AMSOIL air, oil-bypass & rear end 75w-140 fluid ,<font color="blue">3/8" fuel sys w/10µ Dieselsite DAHL100 & fuel manifold/sight glass</font>,6 way dr. pwr. seat, Magnefine trans/P.S. filters</font>, husky mats,<font color="red">5 gauge A-pillar ISSPRO EVs w/Grn mkr illum. + air & fuel restriction gauges</font>,Dieselsite coolant filter and zinc electrode, manual GPR switch & GP LED, blinking security LED, weathertechs, a few other "Gadgets" [img]/ubbthreads/images/graemlins/smile.gif[/img], & a 1981 26' Prowler TT(26Y)
Larry M is offline
Old 02-25-2003, 07:41 PM   #4 (permalink)
Super_Dave's Avatar
Re: Tires
Need to get some new, and taller skins for my child too.
I'd love Michelins, but I think for all six, I'll be sitting at a grand. Might go with some BFG commercial tires.
I've always ran my pressures on the high side. Seems to allow them to last a bit longer.
Do the BFG's blow? Anyone?
Super Dave
2006 E350 6.0PSD
2003 Excursion Limited 4WD 7.3PSD - Sold
1996 E350 Super Duty bus 7.3PSD - Sold
Super_Dave is offline
