Old 06-02-2003, 06:07 PM   #1 (permalink)
Tires
Hi Guys. I am about to take off my Goodyear tires and I am wanting some feedback on the changes you noticed when you put Michelin LTX E rated on in their place.
Did you notice and increase in road noise?
Did ride improve?
Did direction stability get better or worse or the same.
This would help me if you would reply if you have done the Goodyear, Michelin change over.
Thanks, Andrew.
andrewzx92000 is offline
Old 06-02-2003, 09:29 PM   #2 (permalink)
cdnsarguy's Avatar
My Photos: (66)
Re: Tires
I went from Goodyears to Michelin LTX, at first I thought they were a little noisy but a softer ride. We get some cold temps up here but I never skated around with any other brand like I did with LTXs last winter. I mean winter driving has a whole new meaning now, I have to fight to keep it on the road in snow and ice situations, braking was a real thrill too. Costco and cost was the only reason I changed, it is hard to find tire shops which give road hazard, rotation and balance etc for free.
Proud Canadian BOOB man too!!
cdnsarguy is offline
Old 06-03-2003, 01:28 AM   #3 (permalink)
Re: Tires
Lets make sure everyone is on the same page, or tires. The vans have been coming with Goodyear HT tires for a long time. Michelin has a few different LTX tires, M/S, AT,and AS. The M/S goes by a few different names when you buy it at some places like Sears, Walmart, BJ's or other chain outlets. I believe the LTX M/S is the best all around all season tire made. They will cost more. The HT's are not good in the rain and are terrible in the snow.
1994 E-350 RB 5.8gas 4X4Quigley cargo 4.09 arb-locker f/r 35x12.5-16.5 or 285/75-16.,,, 1997 E-350 EB 5.4gas 4X4Quigley Sportsmobile camper 4.10 arb front, L/S rear 285/75-16/front 33X12.5-16.5/rear ><>J
toalpi is offline
Old 06-03-2003, 08:01 AM   #4 (permalink)
Re: Tires
Take a tape measure with you and measure your new choices. Although the tire manufacturers put the same number on the sidewall, LT245/75R16 E, the actual dimension vary considerably. The Wrangler HT has the widest tread around at about 8”. Most of the other manufacturers may have a similar section width, but the tread width comes in around 7”. Also, the diameter varies too.
I settled on Cooper Discovery AT because the actual dimensions were close to the Wrangler HT, and the price was reasonable at $100 each installed. Yeah I know, one is a highway tire and the other an all terrain, but the Wrangler really doesn’t fit the highway mold. The AT is only slightly more aggressive than the Wrangler HT.
After 1000 or so miles I can’t tell any difference in road noise or handling. I do get better traction on the launch ramp and muddy roads. I won’t know about snow until winder comes along.
Anyway, I’m happy with the Cooper Discovery AT.
Rob
2000 E350 PSD Converted Cargo. All the options, 3.55 LS, A Pillar ISSPRO EGT (Pre-Turbo) & Tranny Gauges, Prodigy, Mag-Hytec Diff Cover.
E350PSD is offline
Old 07-02-2003, 05:11 PM   #5 (permalink)
My Photos: (15)
Re: Tires
Thought that you might like this bit of information, back in March I put on the E350 gas van that I had a full set of All Terrain Radial Avon's, they are the 265/75R16 load E (M+S), I did get to drive them in some snow before the winter was over, and so far this summer in some rain, and they make the van fell better in the curves around here, they have done well on the unpaved roads that we have around here as well.
The van is back..........(song of elton john... the B.... is back....)
But boy does it need that program.......
"FAILURE IS NOT AN OPTION" 2000 E350 7.3PSD, Hellwig Stablizer bar, Headlight Harness upgrade from: http://www.suvlights.com/ 265/75/16E, 140 Lightforce w/blue, yellow, clear covers. My Photos http://photos.thedieselstop.com/showgall...&stype=&ppuser=
Alaskapsdvan is offline
Old 07-06-2003, 03:03 PM   #6 (permalink)
Re: Tires
Have 40K on my Goodyear HT's that came on the van. I sure hope to get another 15K out of them........
Just rotated today and darned if I didn't twist off a stud on the back wheel drivers side. The nut came loose about a turn and a half and then froze up tighter than anything. When I applied the torque to get the nut off, the stud twisted off right at the base of the nut........ [img]/ubbthreads/images/graemlins/confused.gif[/img]
Sooooo, it will be a call to the dealer tomorrow to find out what to do.
Yardbrew
America....love it or leave it
02 E350 PSD Cargo with windows/power/CC/3.55 LS/Prodigy/Reese WD & Dual Cam/....from Cochise
Van Color:Gray--Bumper Color:Gray--Wheel Color:Gray--Hubcaps:metallic--Tire Color:black--Grill Color:gray plastic
I pull a 1987 Wells Cargo Express Wagon (20 ft)
Yardbrew is offline
Old 07-06-2003, 07:43 PM   #7 (permalink)
Re: Tires
Yardbrew,
Studs breaking off the hub are a common problem on boat trailers. I learned a long time ago to use some <font color="blue">Zinc anti-seize compound </font> on them. I now also use it on all my studs both for anti-seize protection and more consistent torque values.
Also, avoid using an impact wrench. I torque'em both on and off with a stepped sequence.
Rob
E350PSD is offline
Old 07-06-2003, 08:56 PM   #8 (permalink)
Location: British Columbia Southern Corner of the Westcoast
Re: Tires
I'am not completely sold on Michelins hype on how good the LTX are and for the price of them I think I would go with Bridgestone M773s or if you not in snowy areas the R237s both good tough tires.
The other good one is the Bridgestone D611s if you want to run the 235s I had these on my other F-Superduty as steers worked fine but they did wear fast. I didn't have any complaints about the front end breaking loose and they tracked pretty good but like I said they wore pretty quick but then again our highway is loaded full of S curves and a heavy truck takes its toll.
KW
89 F-Superduty 7.3 N/A 5spd 319,000kms 12x8 flatdeck. Looking for a newer F-Superduty I just can't get over the feeling a F-350 is too light duty for the work. A F-Superduty is what a F-350 should be like something that will carry 8000lbs [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Kenworth is offline
Old 07-06-2003, 10:27 PM   #9 (permalink)
Re: Tires
I've got over 60,000 mi on my E rated Big 0's on my E-350. Cheap and durable.
05 GMC 2500HD Dmax "Casper" 11.77 @ 114.5 on fuel only
04 GMC 3500SRW Dmax "Big Blue" 13.12 @ 103 on fuel only
06 GMC 2500HD Dmax "Wendy" 12.92 @ 102 on fuel only
McRat is offline
