Old 01-12-2005, 08:32 PM   #1 (permalink)
Torqueshift recall?
I took my new 2004 E350 SMB 4X4 conversion to my local Ford dealer to have its breakin oil changed yesterday, and was informed that there's a recall on the Torqueshift to fix some bolts on the reverse gear housing that back themselves out and eat the adjacent thrust washer. All of which involves between 5 and 11 hours of work under warrantee.
Since I've got an Atlas transfer case, shifters, wiring, and driveshaft bolted to the back of the transmission which will probably have to come off to get to the tailshaft area of the transmission, I'm not sure I trust a Ford dealer to put it back together right.
Has anybody else heard of a Torqueshift recall?
oldfart3 is offline
Old 01-13-2005, 08:08 PM   #2 (permalink)
pon
Re: Torqueshift recall?
Recall on 2004 TorqShifts:
Certain trucks built from 3-8-04 through 6-24-04 may experience a failure of the low/reverse planetary assembly. Specifically one or more of the planet gear pinion shafts may walk out of the carrier. If this occurs metallic contamination of the fluid will occur and will cause harsh or slipping shifts and/or harsh or delayed engagements in forward or reverse. Trucks affected by this recall will have the low reverse planetary replaced if no damage has occured, or will have the transmission overhauled and repaired as needed, along with replacement of the transmission cooler, if damage has occured.
Customer Statisfaction Program 04B24.
This is from Dieselmann's 6.0 Powerstroke bulletins. I guess I better check my build date and if vans are affected. My van was shipped to SMB's dealer 3/15/04 so hopefully out of the range.
2004 E-350 RB PSD Sportsmobile 4x4, 4.10 LS w/
8" Eagle Alloy w/ BFG LT295/75R16 All Terrain, 13 MPG @ 32K (highest diesel paid - $5.29/gal 07/2008)
1991 Jeep Comanche Long bed, 2200# Bigton package, Dana 44, 3.73, PowrLock LS, 4" lift, National Springs in rear, Tomken front, Callen Camper shell, 31x15 BFG KO Mud Terrains. (my kayak hauler)
2001 330i BMW (the wif's)
1998 Honda Civic (my commuter)
pon is offline
Old 01-14-2005, 12:01 AM   #3 (permalink)
pon
BTW - What do you mean by break in oil? The manual does not reference it or did I miss it? I asked my dealer at 3000 miles when I was in for a speedo recal and he said 5000 mile first oil change. I'm 200 miles shy of that so.......... just curious now.
Pat
pon is offline
Old 01-14-2005, 07:11 AM   #4 (permalink)
I agree there's no requirement or recommendation to change "breakin" oil, I'm just compulsive about getting any manufacturing residues out of the motor. Probably totally unnecessary, but make me feel better anyway.
oldfart3 is offline
Old 01-14-2005, 10:34 AM   #5 (permalink)
My Photos: (9)
Gee, I wonder what ATF they would use after the overhaul/repair???
2001 E350 PSD, Deep Emerald Green, 3.55 LS, Premium package, dual alts, rear A/C. Quigley 4x4, Transfer Flow rear tank (27+26), handicap mods, custom interior, Reunel tire carrier w/ Hi-Lift, Sportsmobile nerf bars (black), Amsoil lubes and Dual-Gard bypass oil filter, Amsoil air filters, Eclipse/JL Audio sound system w/ Sirius & 120GB Neo Car Jukebox (MP3 player), J&J stainless grill, Reunel Stainless bumper, 12000# Warn winch, PIAA lights, Bilstein shocks, Ultra Magnum wheels, Michelin tires (265/75-16), Correctrack rear wheel spacers, Bushwhacker flares (painted), Velvet-Ride spring shackles, p/s filter, external tranny and coolant filters, Wicked Wheel, Autometer gauges(5), 203 thermo, BRV+, removed air intake heater, Optima Yellow Tops, "Harpoon" mod, DP-Tuner, 4" exhaust w/ Aeroturbine, Airdog, HX-mod.
Next on the List: a blown tranny!
msnunes is offline
Old 01-15-2005, 07:14 AM   #6 (permalink)
my build date was 5/15/04 approx. 19,000 mile s so far, some very minor infrequent erractic shifting after slowing down during highway run in traffic, but after few minutes, all is good.
wonder if i ll get recall notice ?
'06 navigator,4x4, ultimate, black/grey interior.
'99 e-300 turbo diesel benz, silver, wife s ride
'77 450SL benz in the family since new.
'06 gmc 3500 dmax/allison, cc, slt. black/dark pewter int.
'91 350sdl turbo diesel benz
'06 mazda 6, daughter s ride.
'89 560sl benz, it s official, i m outta room in the driveway.
hapaschold is offline
Old 01-15-2005, 11:38 AM   #7 (permalink)
MikeL46's Avatar
Mine was built in that timeframe. Ford has already taken my trans completely apart to replace the porous casing. Wonder if it has to come apart again? What will they say about the F-350 transfer case now on the end of the transmission?
Mike
125W solar panel. Sportsmobile off-road trailer.
54,311 miles. 16.47 mpg average
From Cal to Alaska and Key West and points in between
05 F350 front axle and aluminum wheels 275/70-18 tires. 46 Gal tank - harpooned pump vent tube.
Scangauge
162 days in the shop - not counting the 4wd conversion time - Replaced front springs, 2 injectors, Trans housing, 3rd gear, Reverse planetary assy, Turbo, Alternator, Turbo hose fitting, Block Heater, Door lock - all under warranty. AC hose, not under warranty.
MikeL46 is offline
Old 01-17-2005, 05:46 PM   #8 (permalink)
My service dept told me today that there were no recalls on the torqueshift transmission, just explorers and lincolns. I think she did say something about customer satisfaction program. I wonder if this is somehow related to the clunking noise I sometimes get?
"Nothing in life is so exhilarating as to be shot at without result." - Sir Winston Churchill
May your road stay clear & dry, may your fuel never gel, and may you never be outsmarted by your idiot lights.
2002 F-250 XLT SC LB 4x4 7.3PSD 6-Sp 3.73 L-S, Snugtop Snuglid Tonneau, 235/85 MC HTRs, <span style="color: red">DPTuner F5</span> AFE Stg II, Turbo LifeSaver, MAP BRV, Autometer Cobalts, Magnaflow 4", WW, TAG, AIH del, CCV, AirDog, In-tank, Harpoon, HPX, ITP fuel sys, LL8 del, 203*, Oilguard & SP Diesel bypass filtration, ART rotors, PFC pads, Heater Core Ctl Valve, Bilsteins, Velvet Ride Shackles, South Bend Clutch, <span style="color: green">21.27 mpg</span>
2004 <span style="color: red">E</span>-350
XLT Wagon 6.0PSD 3.55 L-S TDM EZ-Entry 11 pass., AIC, custom MBRP 4" w/dual Aeroturbines, Airdog, harpoon, Overhead Cobalts
Pictures . . . Parts Links
DarthSurplus is offline
Old 01-17-2005, 06:05 PM   #9 (permalink)
http://www.blueovalnews.com/2005/advisory/index.html
serpexc is offline
Old 01-19-2005, 01:10 PM   #10 (permalink)
Thank you, serpexc, for posting that link.
I am concerned that my van may have this problem, but that Ford's computer systems won't indicate that it is affected.
Under certain conditions, a noise kind of like rivets on brake rotors, emanates from the tranny. It has had the delayed/harsh engagement from the beginning.
Although I got the van in July, it was nearly completely assembled somewhere between June 17th and June 22nd. It went from the Ford factory to TDM, who installed the seats, and then it went back to Ford for final inspection on June 25th.
In brief, the tranny got stuffed in there during the affected time period.
Oh, the inhumanity! [img]/ubbthreads/images/graemlins/shocked.gif[/img] [img]/ubbthreads/images/graemlins/eek.gif[/img] What's a powerstroker to do??? [img]/ubbthreads/images/graemlins/blush.gif[/img] [img]/ubbthreads/images/graemlins/crazy.gif[/img] [img]/ubbthreads/images/graemlins/confused.gif[/img] [img]/ubbthreads/images/graemlins/shrug.gif[/img] [img]/ubbthreads/images/graemlins/rolleyes.gif[/img] [img]/ubbthreads/images/graemlins/vomit.gif[/img]
Oh, wait, I just remembered how much fun it is to show the service writers what idiots they are. [img]/ubbthreads/images/graemlins/grin.gif[/img] [img]/ubbthreads/images/graemlins/tongue.gif[/img]
Old 01-20-2005, 07:00 PM   #11 (permalink)
MikeL46's Avatar
I called my dealer; gave them my VIN and they ran it and came back with the recall. Had to order the reverse planet assy - on national back order - should be available mid to late Feb.
The tech is going to be good at taking 5R110's apart - it's the 2nd complete disassembly for mine.
Wonder what they will say about the transfer case on the back of the tranny now?
Mike
Scangauge
MikeL46 is offline
» Sponsor Links
»Garage Storage and Cabinets
